[Ovmsdev] Request For Comments - Wireguard VPN
Ludovic LANGE ll-ovmsdev at lange.nom.fr
Mon May 1 03:39:07 HKT 2023
Thanks Mark, it's perfect.
I've just reapplied the original patches from Stephen here :
https://github.com/openvehicles/wolfssl/pull/1
Once those are reviewed and merged, I'll upgrade the baseline PR for
WolfSSL migration to submodule (and convert it from draft to final PR).
Thanks in advance !
Le 30/04/2023 à 10:28, Mark Webb-Johnson a écrit :
> I think this is done. Please try, and let me know if ok for you now.
>> On 29 Apr 2023, at 4:44 AM, Ludovic LANGE <ll-ovmsdev at lange.nom.fr>
>> wrote:
>> Hi Mark,
>> Thanks for the 2 repos.
>> Regarding the versions, I had success with wolfssl until 5.3.0. After
>> that version, source code compatibility is still OK but I had crashes
>> in SSH sessions (stack overflow).
>> So I did some baseline PRs with the same versions we had before
>> (4.7.0/1.4.6) ; then other ones to increase up to 5.3.0 / 1.4.13:
>>   * Baseline:
>>       o WolfSSH 1.4.6 :
>>         https://github.com/openvehicles/Open-Vehicle-Monitoring-System-3/pull/885
>>       o WolfSSL : (draft in-progress, it's missing 2 patches from our
>>         repo that are needed - at least one for compilation - with
>>         v4.7.0)
>>   * Upgrades:
>>       o WolfSSH up to 1.4.10 :
>>         https://github.com/openvehicles/Open-Vehicle-Monitoring-System-3/pull/886
>>           + I'll prepare an upgrade to the latest but some changes
>>             are needed that I need to test on all releases.
>>       o (For WolfSSL I'll prepare the upgrade later)
>> That way we can revert the "upgrade" commits without going back to
>> the module / submodule commit + we do not introduce
>> doubts/regressions with the submodule operation.
>> Please note: in the WolfSSL fork the tags are missing ; could you
>> please fetch them and push them ? Thanks in advance.
>> Please also create - for WolfSSL still - a dedicated branch
>> `v4.7.0-stable-ovms` so that I can apply the missing patches (mainly
>> a workaround for a define SHA_CTX + some changes from Stephen
>> (WOLFSSL_SMALL_STACK))
>> Thanks in advance.
>> PS: If you have some time, and want to review my other pendings PRs:
>> https://github.com/openvehicles/Open-Vehicle-Monitoring-System-3/pulls?q=is%3Aopen+is%3Apr+author%3Allange+draft%3Afalse
>> I believe they can be reviewed / applied independently should you
>> wish so.
>> Le 28/04/2023 à 07:37, Mark Webb-Johnson a écrit :
>>> I’ve forked the two wolf repos:
>>>   * https://github.com/openvehicles/wolfssl
>>>   * https://github.com/openvehicles/wolfssh
>>> However, those are the latest versions (5.6.0 and 1.4.13
>>> respectively) so I am not certain of compatibility with our code
>>> base, or how hard it would be to integrate those. We can always
>>> branch+tag earlier versions closer to ours if too hard. Our
>>> previous wolfSSH was v1.4.6 (February 3, 2021), and wolfSSL Release
>>> 4.7.0 (February 16, 2021). From my understanding, WolfSSH requires
>>> the crypt parts of WolfSSL to build.
>>> Doing it this way, and bringing these in as submodules to our code,
>>> would be the best way to maintain compatibility with upstream. If it
>>> is really too difficult (given the number of changes Stephen made to
>>> get this to work), we can always just roll back to committing the
>>> existing versions directly to those GitHub repositories and making
>>> them submodules.
>>> Could you have a try and see if that is possible?
>>>> On 26 Apr 2023, at 2:26 PM, Ludovic LANGE <ll-ovmsdev at lange.nom.fr>
>>>> wrote:
>>>> Hi Mark,
>>>> I'm going to add the missing parts for the main tunnel (new config
>>>> items to a) auto-start + b) to register as a default route if wanted).
>>>> For the "manual" commands I'll experiment with these. I like the
>>>> idea of having a quick remote access for troubleshooting purposes.
>>>> Regarding wolf*, yes, I do think that would be the best idea - to
>>>> have these as submodules.
>>>> I intend to "relocate" those modules as subfolders of the component
>>>> in my patches:
>>>> components/wolfssh
>>>> ├── CMakeLists.txt
>>>> ├── README.md
>>>> ├── component.mk
>>>> └── wolfssh
>>>>     ├── ChangeLog.md
>>>>     ├── LICENSING
>>>>     ├── Makefile.am
>>>>     ├── README
>>>> This way, we can manage our "glue" code ( CMakeLists.txt and
>>>> component.mk ) without interfering with the external component. I
>>>> believe that it keeps a proper separation between "our code" and
>>>> "upstream code", making it easy to upstream patches and/or to
>>>> rebase to a newer release.
>>>> Especially given that some of these external components now have
>>>> their own CMakeLists.txt - not easily re-usable for our build
>>>> structure.
>>>> If you're OK with that, you can either:
>>>>   * take this opportunity to add the submodule at the target place
>>>>     - only dealing with relocating component.mk (you can take
>>>>     inspiration from my tree : wolfssh
>>>>     <https://github.com/llange/Open-Vehicle-Monitoring-System-3/tree/experimental-esp-idf-build-workflow/vehicle/OVMS.V3/components/wolfssh>
>>>>     (component.mk andREADME.md) and wolfssl
>>>>     <https://github.com/llange/Open-Vehicle-Monitoring-System-3/tree/experimental-esp-idf-build-workflow/vehicle/OVMS.V3/components/wolfssl>
>>>>     (component.mk andREADME.md and port/ directory that you need to
>>>>     move - careful, in my tree the user_settings.h is already
>>>>     patched, you don't want that for the moment.))
>>>>   * just replace as-is, and I'll do the relocation with a PR.
>>>>   * Or if you want I can also handle the (b) and (c) parts of your
>>>>     proposal myself with a PR
>>>> Let me know.
>>>> Regards,
>>>> Le 26/04/2023 à 04:10, Mark Webb-Johnson a écrit :
>>>>> I reviewed your config, and see the issue. Quite a lot of
>>>>> parameters to set.
>>>>> Perhaps it is sufficient to have just:
>>>>>  1. One single wireguard tunnel in configuration, with an
>>>>>     associated auto setting to automatically start it.
>>>>>  2. A wireguiard command to bring up/down other tunnels, manually
>>>>>     specified on the command line.
>>>>> That way, if the user really needs more than one tunnel (or custom
>>>>> tunnels such as I suggest), he can use command shell scripts, or
>>>>> remote commands to bring them up/down.
>>>>> Regarding wolfssh and other similar external components, I think
>>>>> that they can/should be split off and run as submodules sourced
>>>>> from a GitHub.com/openvehicles repository. We’ve already done that
>>>>> for mongoose, zlib, and libzip. Would you like me to create empty
>>>>> repositories for those, and then you can submit the PRs to (a) add
>>>>> the existing code to the new repository, (b) remove the code from
>>>>> Open-Vehicle-Monitoring-System-3, and (c) add the submodule to
>>>>> Open-Vehicle-Monitoring-System-3? I think candidates for this
>>>>> approach include:
>>>>>  1. wolfssh
>>>>>  2. wolfssl
>>>>> Regards, Mark
>>>>>> On 25 Apr 2023, at 3:28 PM, Ludovic LANGE
>>>>>> <ll-ovmsdev at lange.nom.fr> wrote:
>>>>>> Hello Mark,
>>>>>> Thanks for the comments. I'll see how we can manage tunnels from
>>>>>> the cli, should be doable.
>>>>>> Regarding the PR, here is one PR with only WireGuard support :
>>>>>> https://github.com/llange/Open-Vehicle-Monitoring-System-3/pull/1
>>>>>> - it's just for review, as it is from my fork to itself.
>>>>>> For the WolfSSH / WolfSSL, I have some pending PRs on master, and
>>>>>> I create new ones as soon as the previous ones are merged, as to
>>>>>> not increase too much the burden on the reviewers.
>>>>>> They are here :
>>>>>> (wolfssl will be a new one, not created yet, I'm waiting for the
>>>>>> feedback on the wolfssh one - is a new submodule acceptable or
>>>>>> not, or is it better to have a subtree, or a copy, ....)
>>>>>> Regards,
>>>>>> Le 25/04/2023 à 02:49, Mark Webb-Johnson a écrit :
>>>>>>> Really glad to see this, and thanks for working on it.
>>>>>>> I do think it would be useful to have many wireguard circuits
>>>>>>> configurable.
>>>>>>> For my own use case, I would like to be able to bring up a
>>>>>>> wireguard circuit purely from the command line (with no
>>>>>>> configuration set). This is because I am frequently called in to
>>>>>>> help with setup/configuration/diagnostic issues remotely, and
>>>>>>> having a full VPN would be extremely useful for that. If I could
>>>>>>> just send a single command to start the vpn back to me, then ssh
>>>>>>> into the module (or get can bus data over tcp/ip, etc), it would
>>>>>>> help tremendously.
>>>>>>> Regarding the PR, can we split this into (a) for wolfssh/wolfssl
>>>>>>> as a module, and (b) for wireguard support. At the moment, it is
>>>>>>> quite hard to review with both in the same PR.
>>>>>>> Regards, Mark.
>>>>>>>> On 24 Apr 2023, at 5:35 PM, Ludovic LANGE
>>>>>>>> Dear list,
>>>>>>>> A few months ago I created
>>>>>>>> https://github.com/openvehicles/Open-Vehicle-Monitoring-System-3/issues/752
>>>>>>>> to explore WireGuard VPN support ; which leaded me to add
>>>>>>>> ESP-IDFv5 support to OVMS.
>>>>>>>> Now that this ESP-IDFv5 support is added (in my branch, and it
>>>>>>>> is in the progress of getting included in master - with the
>>>>>>>> help and the testing of everybody here), I've resumed my
>>>>>>>> exploration of adding support for WireGuard VPN to OVMS.
>>>>>>>> It's now ready for comments, you can now check:
>>>>>>>>   * a new branch here
>>>>>>>>     https://github.com/llange/Open-Vehicle-Monitoring-System-3/tree/752-wireguard
>>>>>>>>   * a DRAFT PR here
>>>>>>>>     https://github.com/openvehicles/Open-Vehicle-Monitoring-System-3/pull/882
>>>>>>>> if you want to explore and test this VPN support for OVMS.
>>>>>>>> My own use case for this feature is :
>>>>>>>>   * Security : I would like my module to be unreachable from
>>>>>>>>     the public Internet. This is a first step.
>>>>>>>>   * Practicality : I can reach my module with a single IP
>>>>>>>>     address / name that is part of my private network. SSH,
>>>>>>>>     Web, SCP, ... all work as if my module is local to my servers
>>>>>>>>   * Roaming : The idea is to have a single point of contact
>>>>>>>>     even if the module changes network, changes IP address, etc...
>>>>>>>> Part of this feature set is already available with a
>>>>>>>> combination of the OVMS Server (v2, v3) and the Hologram.io
>>>>>>>> services, but I wanted to be independent of the mobile
>>>>>>>> connexion provider, and also file transfer is important for my
>>>>>>>> use case (SCP or other), as I'm often wanting to sync the
>>>>>>>> content of the SD card over the network.
>>>>>>>> If you can have a look and give feedback (either here, or on
>>>>>>>> the PR), especially on:
>>>>>>>>   * The documentation : is it enough ? properly organized ?
>>>>>>>>     should it be split ? etc...
>>>>>>>>   * The command set
>>>>>>>>   * The configuration items : what's missing ? is the naming OK ?
>>>>>>>>   * Other features (should I introduced events ? metrics ?)
>>>>>>>> Also if you have any feature request, please share.
>>>>>>>> Limitations:
>>>>>>>>   * Currently limited to 1 tunnel, but should work with
>>>>>>>>     multiple - it's just a question of arranging the
>>>>>>>>     configuration to support multiple instances
>>>>>>>>   * Roaming not tested yet (will report)
>>>>>>>>   * Compatibility with mobile network not tested yet (will need
>>>>>>>>     help on this)
>>>>>>>>   * I'm not really happy with the way I set the configuration
>>>>>>>>     items. I'd like to "hide" (write-only) the important bits
>>>>>>>>     (private key, shared key), but fear that it would clutter
>>>>>>>>     the config namespace - especially if I introduce multiple
>>>>>>>>     tunnels.
>>>>>>>>     Maybe one solution would be to have a rich configuration
>>>>>>>>     per tunnel (like a JSON / YAML), which would be a nightmare
>>>>>>>>     to edit by hand and would need support in the web interface.
>>>>>>>>   * Tunnel always active as soon as the configuration is
>>>>>>>>     correct. May be will need to add an enabled/disabled flag
>>>>>>>>     to the configuration, and/or an auto-start flag.
>>>>>>>> Current status:
>>>>>>>>   * Builds on GitHub actions (if you can to test, pre-compiled
>>>>>>>>     firmwares are available here for example:
>>>>>>>>     https://github.com/llange/Open-Vehicle-Monitoring-System-3/actions/runs/4784405668
>>>>>>>>     - just download a Zip file (v5.0 or v5.0.1), and flash with
>>>>>>>>     a command-line like esptool.py --chip esp32 --port
>>>>>>>>     /dev/xxxx --baud 921600 write_flash --compress --flash_mode
>>>>>>>>     "dio" --flash_freq "40m" --flash_size detect 0x10000
>>>>>>>>     ovms3.bin )
>>>>>>>>   * Works on My Machine (tunnel is UP, SSH is working OK, HTTP
>>>>>>>>     is working OK, performances look OK. Ping time (ICMP) is
>>>>>>>>     comparable with or without tunnel)
>>>>>>>> Thanks for your comments.
>>>>>>>> Regards,
>>>>>>>> OvmsDev mailing list
>>>>>>>> OvmsDev at lists.openvehicles.com
>>>>>>>> http://lists.openvehicles.com/mailman/listinfo/ovmsdev
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20230430/590f46fd/attachment-0001.htm>
