[Ovmsdev] LoadProhibited exception on core 0
    Soko
    ovms at soko.cc
    Tue Jul  4 18:10:47 HKT 2023
Hi Mark,
I have the exact bin & elf I'm using (I've compiled it myself back in
the day...). I've also found the script you are mentioning, but it seems
to be a linux script, I'm on windows.
Looking at the script though - educated guessing - it just looks at the
address in the ELF file.
Opening the ELF file with an hex-editor in windows reveals it ends at
0x0240D5DB.
Do I have to translate the address somehow? Or is the a2l script doing
more than just looking.
I've also uploaded the bin & elf (http://soko.yourweb.de/ovms3.zip) if
you wonna have a quick look.
The backtrace (0x4028128f 0x402823bf) is more or less the only constant
numbers I get with each crash. So if they are too short can I
add/activate some trace which leads to more info without connecting to a
laptop (my old devenv doesn't seem to work anymore, and it was Windows
anyhow...)
thx
Soko
On 04.07.2023 03:01, Mark Webb-Johnson wrote:
> To understand what is going on, you’ll need to get the ELF file for
> the *exact* build of firmware you are using, and then use the
> support/a2l script to decode the backtrace addresses to something
> human readable. If you can’t do this, you could try by letting us know
> the firmware version you are running, where you got it from (API or
> Dexters), and provide the backtrace addresses. If you are using
> standard firmware builds, you can normally find the .elf file by
> simply change ovms3.bin to ovms3.elf in the download URL.
> Alternatively, connect the module over USB to a laptop/workstation
> running the development build environment and GDB stub running to
> capture the panic.
> The backtrace you show below (0x4028128f 0x402823bf) does not seem to
> be valid (too short), and probably won’t help much.
>> On 4 Jul 2023, at 5:41 AM, Soko <ovms at soko.cc> wrote:
>> Hi guys,
>> Running happily my OVMS on my VW e-Up since 2020 it drives my crazy
>> since today :(
>> It restarts roughly every minute with this status afterwards:
>> Last boot was 28 second(s) ago
>> Time at boot: 2023-07-03 21:25:07 CEST
>> This is reset #1 since last power cycle
>> Detected boot reason: Crash (12/12)
>> Reset reason: Exception/panic (4)
>> Crash counters: 1 total, 0 early
>> Last crash: LoadProhibited exception on core 0
>> Registers:
>> PC : 0x4028128f PS : 0x00060d30 A0 : 0x802823c2 A1 : 0x3ffe71d0
>> A2 : 0x3ffe9f9c A3 : 0x00000000 A4 : 0x00000000 A5 : 0x00000001
>> A6 : 0x3ffe9fe8 A7 : 0x3ffe71d0 A8 : 0x0000005b A9 : 0xffffffff
>> A10 : 0x00000e10 A11 : 0x0000000e A12 : 0x00000010 A13 : 0x3ffbd3ac
>> A14 : 0x3f84e83c A15 : 0x3ffbd46b SAR : 0x00000010 EXCCAUSE: 0x0000001c
>> EXCVADDR: 0x00000004 LBEG : 0x4008b0e9 LEND : 0x4008b11d LCOUNT :
>> 0x00000000
>> Backtrace:
>> And now the crazy part: It only happens when I'm connected to a
>> specific WiFi/network?!?!
>> What I've tried so far:
>>  1. Factory Reset (multiple times)
>>  2. Set a static IP address
>>  3. Reconnect all cables and make sure all are snug and tight
>>  4. Brought OVMS closer to the AP (only one, no mesh)
>>  5. Restarted AP
>>  6. Restarted DNS & DHCP Server
>>  7. It even happens when I have no vehicle selected after a factory reset
>> It gets more crazy: My WiFi is via Unifi/Ubiquity. So I can have
>> multiple SSIDs with the same AP. So all hardware involved is the same...
>> When I connect to SSID "E3200", which is network 192.168.254.0/24,
>> the exception happens every minute or so.
>> When I connect to SSID "SurfHere" which is network 192.168.179.0/24,
>> everything works fine!
>> Do you guys have any idea why this is happening?
>> I've tried to look at logs via Shell and "log level verbose" but
>> nothing shows up. Is there more I can activate to log this issue?
>> Maybe my hardware is faulty... Where do I get a new OVMS here in
>> Europe/EU/Austria? Do I have to import in from the UK
>> (https://shop.openenergymonitor.com/ovms/)?
>> thanks heaps in advance,
>> Soko
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20230704/6c29413a/attachment-0001.htm>
Type: image/png
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20230704/6c29413a/attachment-0001.png>
