[Ovmsdev] LoadProhibited exception on core 0
    Soko
    ovms at soko.cc
    Tue Jul  4 05:41:56 HKT 2023
Hi guys,
Running happily my OVMS on my VW e-Up since 2020 it drives my crazy
since today :(
It restarts roughly every minute with this status afterwards:
Last boot was 28 second(s) ago
Time at boot: 2023-07-03 21:25:07 CEST
This is reset #1 since last power cycle
Detected boot reason: Crash (12/12)
Reset reason: Exception/panic (4)
Crash counters: 1 total, 0 early
Last crash: LoadProhibited exception on core 0
Registers:
PC : 0x4028128f PS : 0x00060d30 A0 : 0x802823c2 A1 : 0x3ffe71d0
A2 : 0x3ffe9f9c A3 : 0x00000000 A4 : 0x00000000 A5 : 0x00000001
A6 : 0x3ffe9fe8 A7 : 0x3ffe71d0 A8 : 0x0000005b A9 : 0xffffffff
A10 : 0x00000e10 A11 : 0x0000000e A12 : 0x00000010 A13 : 0x3ffbd3ac
A14 : 0x3f84e83c A15 : 0x3ffbd46b SAR : 0x00000010 EXCCAUSE: 0x0000001c
EXCVADDR: 0x00000004 LBEG : 0x4008b0e9 LEND : 0x4008b11d LCOUNT : 0x00000000
Backtrace:
0x4028128f 0x402823bf
And now the crazy part: It only happens when I'm connected to a specific
WiFi/network?!?!
What I've tried so far:
 1. Factory Reset (multiple times)
 2. Set a static IP address
 3. Reconnect all cables and make sure all are snug and tight
 4. Brought OVMS closer to the AP (only one, no mesh)
 5. Restarted AP
 6. Restarted DNS & DHCP Server
 7. It even happens when I have no vehicle selected after a factory reset
It gets more crazy: My WiFi is via Unifi/Ubiquity. So I can have
multiple SSIDs with the same AP. So all hardware involved is the same...
When I connect to SSID "E3200", which is network 192.168.254.0/24, the
exception happens every minute or so.
When I connect to SSID "SurfHere" which is network 192.168.179.0/24,
everything works fine!
Do you guys have any idea why this is happening?
I've tried to look at logs via Shell and "log level verbose" but nothing
shows up. Is there more I can activate to log this issue?
Maybe my hardware is faulty... Where do I get a new OVMS here in
Europe/EU/Austria? Do I have to import in from the UK
(https://shop.openenergymonitor.com/ovms/)?
thanks heaps in advance,
Soko
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20230703/476bc2a5/attachment-0001.htm>
