[Ovmsdev] CAN bus logging not working
Michael Geddes
Wed Feb 8 07:53:15 HKT 2023
Ahh. Makes sense.
I guess one of these days I'll get around to actually installing my OVMS
properly. I still get the occasional need to get at the device (like for
fixing a reboot loop due to a botched updated which requires physical USB
access). For the moment it sits in the little space under the USB ports.
//.ichael
On Tue, 7 Feb 2023 at 17:39, Christos Oscar Kambiselis <
ckambiselis at gmail.com> wrote:
> I meant the cars own covers, the module is tacked away behind the upper
> panels.
> Oscar
> On Tue, Feb 7, 2023, 09:14 Michael Geddes <frog at bunyip.wheelycreek.net>
> wrote:
>> You can get the sdcard out and in with the help of something to push it
>> with, without opening it up.
>> On Tue, 7 Feb 2023, 2:42 pm Christos Oscar Kambiselis, <
>>> This is the latest return
>>> vfs ls /sd
>>> 191.4M 09-Jan-2004 14:20 191.4M 09-Jan-2004 14:20 191.4M 09-Jan-2004
>>> 14:20 191.4M 09-Jan-2004 14:20 ! 191.4M 09-Jan-2004 14:20 ) 191.4M
>>> 09-Jan-2004 14:20 1 191.4M 09-Jan-2004 14:20 9 191.4M 09-Jan-2004 14:20 A
>>> 191.4M 09-Jan-2004 14:20 i 191.4M 09-Jan-2004 14:20 Q 191.4M 09-Jan-2004
>>> 14:20 y 191.4M 09-Jan-2004 14:20 a 191.4M 09-Jan-2004 14:20 i 191.4M
>>> 09-Jan-2004 14:20 ��� r 191.4M 09-Jan-2004 14:20 y
>>> I guess I have to open the covers again.
>>> Thanks for the help
>>> Oscar
>>> On Tue, Feb 7, 2023 at 8:22 AM Mark Webb-Johnson <mark at webb-johnson.net>
>>> wrote:
>>>> That SD looks messed up. There is no ‘format’ command that I know of in
>>>> the ESP IDF. I did try a while (years) ago, but it wasn’t trivial at the
>>>> time. If it detects an empty SDCARD it will format automatically, or you
>>>> will need to format on a workstation.
>>>> Your ‘can can1 status’ is showing packets, so I suggest you try:
>>>> can log start vfs crtd /sd/can.crtd
>>>> (Wait a minute)
>>>> can log stop
>>>> vfs ls /sd
>>>> (and see if /sd/can.crtd has data)
>>>> Regards, Mark
>>>> On 7 Feb 2023, at 2:16 PM, Christos Oscar Kambiselis <
>>>> Hi,
>>>> The first time I tested it I started logging from the Web UI and
>>>> stopped it from there too and the next time I tested it I did it from the
>>>> shell, running status commands to make sure it had started and stopped.
>>>> vfs ls /sd gives,
>>>> 0 30-Nov-1979 00:00 log 0 30-Nov-1979 00:00 0 30-Nov-1979 00:00 0
>>>> 30-Nov-1979 00:00 0 30-Nov-1979 00:00 ! 0 30-Nov-1979 00:00 ) 0 30-Nov-1979
>>>> 00:00 1 0 30-Nov-1979 00:00 9 0 30-Nov-1979 00:00 A 0 30-Nov-1979 00:00 i 0
>>>> 30-Nov-1979 00:00 Q 0 30-Nov-1979 00:00 y 0 30-Nov-1979 00:00 a 0
>>>> 30-Nov-1979 00:00 i 0 30-Nov-1979 00:00 ���r 0 30-Nov-1979 00:00 y
>>>> which I noticed on the "Editor", and the reason I wanted to format the
>>>> card in the OVMS.
>>>> can can1 status
>>>> CAN: can1 Mode: Active Speed: 500000 DBC: none Interrupts: 214034 Rx
>>>> pkt: 120472 Rx ovrflw: 0 Tx pkt: 90774 Tx delays: 0 Tx ovrflw: 0 Tx fails:
>>>> 254 Err flags: 0x008040d9 Rx err: 0 Tx err: 128 Rx invalid: 0 Wdg Resets: 0
>>>> Wdg Timer: 2 sec(s) Err Resets: 0
>>>> can can2 status
>>>> CAN: can2 Mode: Listen Speed: 500000 DBC: none Interrupts: 0 Rx pkt: 0
>>>> Rx ovrflw: 0 Tx pkt: 0 Tx delays: 0 Tx ovrflw: 0 Tx fails: 0 Err flags:
>>>> 0x00000000 Rx err: 0 Tx err: 0 Rx invalid: 0 Wdg Resets: 91 Wdg Timer: 3
>>>> The command to start logging is the all CAN messages command from the
>>>> guide
>>>> *can log start vfs crtd /sd/can.crtd *
>>>> and it returns
>>>> CAN logging to VFS active: Type:vfs Format:crtd(discard) Vehicle:KN
>>>> Path:/sd/can.cr
>>>> also
>>>> can log status
>>>> #2: open Type:vfs Format:crtd(discard) Vehicle:KN Path:/sd/can.crtd
>>>> Messages:214 Dropped:0 Filtered:0 Rate:0.0% /sd/can.crtd: running
>>>> Messages:214 Discarded:0 Dropped:0 Filtered:0 Rate:0.0%
>>>> On Tue, Feb 7, 2023, 02:08 Mark Webb-Johnson <mark at webb-johnson.net>
>>>> wrote:
>>>>> First guess is that you have to ‘can log stop’ to close the logging
>>>>> file before you will be able to see the content.
>>>>> If that is not it, please provide details of the logging commands you
>>>>> are typing, and what ‘vfs ls /sd’, ‘can can1 status’, ‘can can2 status’,
>>>>> show.
>>>>> Regards, Mark.
>>>>> P.S. If you have a modern OVMS module, I also suggest you double-check
>>>>> the sdcard maxfreq.khz setting to optimise performance:
>>>>> https://docs.openvehicles.com/en/latest/userguide/logging.html?highlight=sdcard#performance-impact
>>>>> On 7 Feb 2023, at 4:08 AM, Christos Oscar Kambiselis <
>>>>> Hi,
>>>>> Has anyone had any problems with CAN bus logging?
>>>>> I have a 32GB SD card installed and "SD status" gives:
>>>>> *SD CARD is inserted*
>>>>> *Status: available*
>>>>> *Name: SD32G*
>>>>> *Size: 30419 MB*
>>>>> *Free: 29767 MB*
>>>>> *Card type: SDHC/SDXC*
>>>>> *Max speed: 25000 kHz*
>>>>> *Capacity: 30436 MB*
>>>>> *CSD: ver=1; sector_size=512; capacity=62333952 read_bl_len=9*
>>>>> *SCR: sd_spec=2; bus_width=5*
>>>>> I have setup CAN1 and 2 to "listen" and started the logging like it's
>>>>> mentioned in the user guide, checked the status, I stopped it some time
>>>>> later, and when I go to open it from the Web UI it is empty, also tried
>>>>> from the Editor and it is also empty, removing the card is a bit tricky
>>>>> since the hardware is pretty tucked away in the console. I searched the
>>>>> manual for a format command but can't find anything.
>>>>> I do get messages and readings on the OVMS Android app, so at least
>>>>> the OBD CAN is fine.
>>>>> Oscar
>>>>> OvmsDev mailing list
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20230208/31f16792/attachment-0001.htm>
