[Ovmsdev] ESP-IDF v4 / v5 - baby steps
Ludovic LANGE
ll-ovmsdev at lange.nom.fr
Mon Feb 6 03:37:05 HKT 2023
"idf" dependency, as expressed in (new file) `main/idf_component.yml`,
is just ESP-IDF - this just checks that ESP-IDF is at minimum at version 5.0
This new file expresses the dependencies with new components (like a
`requirements.txt` in Python, `Gemfile` in Ruby, `package.json` in JS,
etc...), and they started to remove components from ESP-IDF and make
them available as external components.
`mdns` is such a component :
https://components.espressif.com/components/espressif/mdns
So I'm not 100% convinced it's related - but in any case you could
remove this file completely and see if it changes something (you
wouldn't be able to compile `mdns`-related components, but still make
some progress)
Could you share the 3 log files please ?
> See also
> "/home/balzer/esp/Open-Vehicle-Monitoring-System-3/vehicle/OVMS.V3/build/CMakeFiles/CMakeOutput.log".
> cmake failed with exit code 1, output of the command is in the
> /home/balzer/esp/Open-Vehicle-Monitoring-System-3/vehicle/OVMS.V3/build/log/idf_py_stderr_output_8211
> and
> /home/balzer/esp/Open-Vehicle-Monitoring-System-3/vehicle/OVMS.V3/build/log/idf_py_stdout_output_8211
Le 05/02/2023 à 16:43, Michael Balzer a écrit :
> It's cmake version 3.20.4.
> As I wrote, everything works with the example project "hello_world".
> Apparently the error occurs while the builder checks the dependencies,
> specifically the "idf" dependency. Where does that originate from?
> "hello_world" does not need this.
> The checked out version is your branch llange/experimental-esp-idf-v5.
> Am 05.02.23 um 15:45 schrieb Ludovic LANGE:
>> Hi Michael,
>> Sorry to hear you have issues but very happy that you're trying to
>> compile it ! We're going to solve those :-)
>> I don't use this command `idf.py set-target esp32` myself - but after
>> trying it, it works as expected.
>> (By the look of it, it says "Set Target to: esp32, new sdkconfig
>> created. Existing sdkconfig renamed to sdkconfig.old." so I would be
>> careful not to use it too much as you loose your sdkconfig)
>> The only commands I'm using are:
>> * menuconfig (once in a while)
>> * fullclean (while switching ESP-IDF version ; also doing `rm -rf
>> build/`)
>> * clean (if some changes have been made and not caught by cmake)
>> * build (90% of the time)
>> * app-flash
>> * monitor
>> My versions of git / bison / flex are (for the record):
>> -- Found Git: /usr/local/bin/git (found version "2.39.1")
>> -- The C compiler identification is GNU 11.2.0
>> -- The CXX compiler identification is GNU 11.2.0
>> -- Found BISON: /usr/bin/bison (found version "2.3")
>> -- Found FLEX: /usr/bin/flex (found version "2.6.4")
>> (I also had success with bison 3.8.2 so not an issue)
>> and my cmake is : cmake version 3.25.2
>> and ninja is at version 1.11.1
>> I set a required version of cmake 3.16 in the main CMakeLists.txt, as
>> recommended by ESP-IDF v5 instructions, but if it's the issue we can
>> modify this.
>> Could you please check your version and see if there is something to
>> try here ?
>> During the `set-target esp32` run, my output is similar to yours but
>> continues:
>>> Adding "set-target"'s dependency "fullclean" to list of commands
>>> with default set of options.
>>> Executing action: fullclean
>>> Executing action: set-target
>>> Set Target to: esp32, new sdkconfig created. Existing sdkconfig
>>> Running cmake in directory SRCS/OVMS-wt2/vehicle/OVMS.V3/build
>>> Executing "cmake -G Ninja -DPYTHON_DEPS_CHECKED=1 -DESP_PLATFORM=1
>>> -DIDF_TARGET=esp32 -DCCACHE_ENABLE=0 SRCS/OVMS-wt2/vehicle/OVMS.V3"...
>>> CMake Warning (dev) at CMakeLists.txt:8 (message):
>>> WARNING - OVMSv3 build is only supported on ESP-IDF 3.3.x
>>> This warning is for project developers. Use -Wno-dev to suppress it.
>>> -- The ASM compiler identification is GNU
>>> -- Found assembler:
>>> SRCS/ESP-IDF-TOOLS/5.0/tools/xtensa-esp32-elf/esp-2022r1-11.2.0/xtensa-esp32-elf/bin/xtensa-esp32-elf-gcc
>>> -- Detecting C compiler ABI info
>>> -- Detecting C compiler ABI info - done
>>> -- Check for working C compiler:
>>> - skipped
>>> -- Detecting C compile features
>>> -- Detecting C compile features - done
>>> -- Detecting CXX compiler ABI info
>>> -- Detecting CXX compiler ABI info - done
>>> -- Check for working CXX compiler:
>>> SRCS/ESP-IDF-TOOLS/5.0/tools/xtensa-esp32-elf/esp-2022r1-11.2.0/xtensa-esp32-elf/bin/xtensa-esp32-elf-g++
>>> - skipped
>>> -- Detecting CXX compile features
>>> -- Detecting CXX compile features - done
>>> -- Building ESP-IDF components for target esp32
>>> Processing 2 dependencies:
>>> [1/2] espressif/mdns (1.0.7)
>>> [2/2] idf (5.0.0)
>>> -- IDF Version: 5.0.0 - NOT enabling strverscmp
>>> -- Project sdkconfig file SRCS/OVMS-wt2/vehicle/OVMS.V3/sdkconfig
>>> -- Looking for sys/types.h
>>> -- Looking for sys/types.h - found
>>> -- Looking for stdint.h
>>> -- Looking for stdint.h - found
>>> -- Looking for stddef.h
>>> -- Looking for stddef.h - found
>>> -- Check size of time_t
>>> -- Check size of time_t - done
>>> -- Found Python3:
>>> SRCS/ESP-IDF-TOOLS/5.0/python_env/idf5.0_py3.10_env/bin/python
>>> (found version "3.10.9") found components: Interpreter
>>> -- Performing Test C_COMPILER_SUPPORTS_WFORMAT_SIGNEDNESS
>>> -- Performing Test C_COMPILER_SUPPORTS_WFORMAT_SIGNEDNESS - Success
>>> -- App "ovms3" version: 3.3.003-316-gcb90ef8c-dirty
>>> -- Adding linker script
>>> SRCS/OVMS-wt2/vehicle/OVMS.V3/build/esp-idf/esp_system/ld/memory.ld
>>> SRCS/ESP-IDF/5.0/components/esp_system/ld/esp32/sections.ld.in
>>> SRCS/ESP-IDF/5.0/components/esp_rom/esp32/ld/esp32.rom.ld
>>> SRCS/ESP-IDF/5.0/components/esp_rom/esp32/ld/esp32.rom.api.ld
>>> SRCS/ESP-IDF/5.0/components/esp_rom/esp32/ld/esp32.rom.libgcc.ld
>>> SRCS/ESP-IDF/5.0/components/esp_rom/esp32/ld/esp32.rom.newlib-data.ld
>>> SRCS/ESP-IDF/5.0/components/esp_rom/esp32/ld/esp32.rom.syscalls.ld
>>> SRCS/ESP-IDF/5.0/components/esp_rom/esp32/ld/esp32.rom.newlib-funcs.ld
>>> SRCS/ESP-IDF/5.0/components/soc/esp32/ld/esp32.peripherals.ld
>>> -- Adding linker script SRCS/OVMS-wt2/vehicle/OVMS.V3/main/ovms_boot.ld
>>> -- wolfssl : EXCLUDE_ASM =
>>> SRCS/OVMS-wt2/vehicle/OVMS.V3/components/wolfssl/wolfssl/wolfcrypt/src/aes_asm.S;SRCS/OVMS-wt2/vehicle/OVMS.V3/components/wolfssl/wolfssl/wolfcrypt/src/aes_gcm_asm.S;SRCS/OVMS-wt2/vehicle/OVMS.V3/components/wolfssl/wolfssl/wolfcrypt/src/aes_gcm_x86_asm.S;SRCS/OVMS-wt2/vehicle/OVMS.V3/components/wolfssl/wolfssl/wolfcrypt/src/chacha_asm.S;SRCS/OVMS-wt2/vehicle/OVMS.V3/components/wolfssl/wolfssl/wolfcrypt/src/fe_x25519_asm.S;SRCS/OVMS-wt2/vehicle/OVMS.V3/components/wolfssl/wolfssl/wolfcrypt/src/poly1305_asm.S;SRCS/OVMS-wt2/vehicle/OVMS.V3/components/wolfssl/wolfssl/wolfcrypt/src/port/arm/armv8-32-aes-asm.S;SRCS/OVMS-wt2/vehicle/OVMS.V3/components/wolfssl/wolfssl/wolfcrypt/src/port/arm/armv8-32-curve25519.S;SRCS/OVMS-wt2/vehicle/OVMS.V3/components/wolfssl/wolfssl/wolfcrypt/src/port/arm/armv8-32-sha256-asm.S;SRCS/OVMS-wt2/vehicle/OVMS.V3/components/wolfssl/wolfssl/wolfcrypt/src/port/arm/armv8-32-sha512-asm.S;SRCS/OVMS-wt2/vehicle/OVMS.V3/components/wolfssl/wolfssl/wolfcrypt/src/port/arm/armv8-curve25519.S;SRCS/OVMS-wt2/vehicle/OVMS.V3/components/wolfssl/wolfssl/wolfcrypt/src/port/arm/armv8-sha3-asm.S;SRCS/OVMS-wt2/vehicle/OVMS.V3/components/wolfssl/wolfssl/wolfcrypt/src/port/arm/armv8-sha512-asm.S;SRCS/OVMS-wt2/vehicle/OVMS.V3/components/wolfssl/wolfssl/wolfcrypt/src/sha256_asm.S;SRCS/OVMS-wt2/vehicle/OVMS.V3/components/wolfssl/wolfssl/wolfcrypt/src/sha3_asm.S;SRCS/OVMS-wt2/vehicle/OVMS.V3/components/wolfssl/wolfssl/wolfcrypt/src/sha512_asm.S;SRCS/OVMS-wt2/vehicle/OVMS.V3/components/wolfssl/wolfssl/wolfcrypt/src/sp_x86_64_asm.S;SRCS/OVMS-wt2/vehicle/OVMS.V3/components/wolfssl/wolfssl/wolfcrypt/src/wc_kyber_asm.S
>>> -- Found Perl: /usr/local/bin/perl (found version "5.36.0")
>>> -- Component idf::main will be linked with -Wl,--whole-archive
>>> -- Component idf::pcp will be linked with -Wl,--whole-archive
>>> -- Component idf::ovms_buffer will be linked with -Wl,--whole-archive
>>> -- Component idf::can will be linked with -Wl,--whole-archive
>>> -- Component idf::canopen will be linked with -Wl,--whole-archive
>>> -- Component idf::wolfssl will be linked with -Wl,--whole-archive
>>> -- Component idf::console_ssh will be linked with -Wl,--whole-archive
>>> -- Component idf::console_telnet will be linked with -Wl,--whole-archive
>>> -- Component idf::crypto will be linked with -Wl,--whole-archive
>>> -- Component idf::dbc will be linked with -Wl,--whole-archive
>>> -- Component idf::esp32adc will be linked with -Wl,--whole-archive
>>> -- Component idf::esp32bluetooth will be linked with -Wl,--whole-archive
>>> -- Component idf::esp32can will be linked with -Wl,--whole-archive
>>> -- Component idf::esp32system will be linked with -Wl,--whole-archive
>>> -- Component idf::esp32wifi will be linked with -Wl,--whole-archive
>>> -- Component idf::ext12v will be linked with -Wl,--whole-archive
>>> -- Component idf::max7317 will be linked with -Wl,--whole-archive
>>> -- Component idf::mcp2515 will be linked with -Wl,--whole-archive
>>> -- Component idf::microrl will be linked with -Wl,--whole-archive
>>> -- Component idf::obd2ecu will be linked with -Wl,--whole-archive
>>> -- Component idf::ovms_http will be linked with -Wl,--whole-archive
>>> -- Component idf::ovms_location will be linked with -Wl,--whole-archive
>>> -- Component idf::ovms_mdns will be linked with -Wl,--whole-archive
>>> -- Component idf::ovms_netlib will be linked with -Wl,--whole-archive
>>> -- Component idf::ovms_ota will be linked with -Wl,--whole-archive
>>> -- Component idf::pushover will be linked with -Wl,--whole-archive
>>> -- Component idf::ovms_webserver will be linked with -Wl,--whole-archive
>>> -- Component idf::ovms_plugins will be linked with -Wl,--whole-archive
>>> -- Component idf::ovms_tls will be linked with -Wl,--whole-archive
>>> -- Component idf::ovms_script will be linked with -Wl,--whole-archive
>>> -- Component idf::ovms_server will be linked with -Wl,--whole-archive
>>> -- Component idf::ovms_server_v2 will be linked with -Wl,--whole-archive
>>> -- Component idf::ovms_server_v3 will be linked with -Wl,--whole-archive
>>> -- Component idf::ovms_tpms will be linked with -Wl,--whole-archive
>>> -- Component idf::powermgmt will be linked with -Wl,--whole-archive
>>> -- Component idf::retools will be linked with -Wl,--whole-archive
>>> -- Component idf::retools_pidscan will be linked with
>>> -Wl,--whole-archive
>>> -- Component idf::retools_testerpresent will be linked with
>>> -Wl,--whole-archive
>>> -- Component idf::sdcard will be linked with -Wl,--whole-archive
>>> -- Component idf::simcom will be linked with -Wl,--whole-archive
>>> -- Component idf::spi will be linked with -Wl,--whole-archive
>>> -- Component idf::strverscmp will be linked with -Wl,--whole-archive
>>> -- Component idf::swcan will be linked with -Wl,--whole-archive
>>> -- Component idf::vehicle will be linked with -Wl,--whole-archive
>>> -- Component idf::vehicle_bmwi3 will be linked with -Wl,--whole-archive
>>> -- Component idf::vehicle_boltev will be linked with -Wl,--whole-archive
>>> -- Component idf::vehicle_cadillac_c2_cts will be linked with
>>> -Wl,--whole-archive
>>> -- Component idf::vehicle_chevrolet_c6_corvette will be linked with
>>> -Wl,--whole-archive
>>> -- Component idf::vehicle_dbc will be linked with -Wl,--whole-archive
>>> -- Component idf::vehicle_demo will be linked with -Wl,--whole-archive
>>> -- Component idf::vehicle_fiat500 will be linked with
>>> -Wl,--whole-archive
>>> -- Component idf::vehicle_hyundai_ioniq5 will be linked with
>>> -Wl,--whole-archive
>>> -- Component idf::vehicle_hyundai_ioniqvfl will be linked with
>>> -Wl,--whole-archive
>>> -- Component idf::vehicle_jaguaripace will be linked with
>>> -Wl,--whole-archive
>>> -- Component idf::vehicle_kianiroev will be linked with
>>> -Wl,--whole-archive
>>> -- Component idf::vehicle_kiasoulev will be linked with
>>> -Wl,--whole-archive
>>> -- Component idf::vehicle_maxus_edeliver3 will be linked with
>>> -Wl,--whole-archive
>>> -- Component idf::vehicle_mercedesb250e will be linked with
>>> -Wl,--whole-archive
>>> -- Component idf::vehicle_mgev will be linked with -Wl,--whole-archive
>>> -- Component idf::vehicle_minise will be linked with -Wl,--whole-archive
>>> -- Component idf::vehicle_mitsubishi will be linked with
>>> -Wl,--whole-archive
>>> -- Component idf::vehicle_nissanleaf will be linked with
>>> -Wl,--whole-archive
>>> -- Component idf::vehicle_none will be linked with -Wl,--whole-archive
>>> -- Component idf::vehicle_obdii will be linked with -Wl,--whole-archive
>>> -- Component idf::vehicle_renaulttwizy will be linked with
>>> -Wl,--whole-archive
>>> -- Component idf::vehicle_renaultzoe will be linked with
>>> -Wl,--whole-archive
>>> -- Component idf::vehicle_renaultzoe_ph2_obd will be linked with
>>> -Wl,--whole-archive
>>> -- Component idf::vehicle_smarted will be linked with
>>> -Wl,--whole-archive
>>> -- Component idf::vehicle_smarteq will be linked with
>>> -Wl,--whole-archive
>>> -- Component idf::vehicle_teslamodel3 will be linked with
>>> -Wl,--whole-archive
>>> -- Component idf::vehicle_teslamodels will be linked with
>>> -Wl,--whole-archive
>>> -- Component idf::vehicle_teslaroadster will be linked with
>>> -Wl,--whole-archive
>>> -- Component idf::vehicle_thinkcity will be linked with
>>> -Wl,--whole-archive
>>> -- Component idf::vehicle_toyotarav4ev will be linked with
>>> -Wl,--whole-archive
>>> -- Component idf::vehicle_track will be linked with -Wl,--whole-archive
>>> -- Component idf::vehicle_voltampera will be linked with
>>> -Wl,--whole-archive
>>> -- Component idf::vehicle_vweup will be linked with -Wl,--whole-archive
>>> -- Component idf::vehicle_zeva will be linked with -Wl,--whole-archive
>>> -- Component idf::vfsedit will be linked with -Wl,--whole-archive
>>> -- Component idf::zip will be linked with -Wl,--whole-archive
>>> -- Components: app_trace app_update bootloader bootloader_support bt
>>> can canopen cmock console console_ssh console_telnet crypto cxx dbc
>>> driver duktape efuse esp-tls esp32adc esp32bluetooth esp32can
>>> esp32system esp32wifi esp_adc esp_app_format esp_common esp_eth
>>> esp_event esp_gdbstub esp_hid esp_http_client esp_http_server
>>> esp_https_ota esp_https_server esp_hw_support esp_lcd esp_local_ctrl
>>> esp_netif esp_partition esp_phy esp_pm esp_psram esp_ringbuf esp_rom
>>> esp_system esp_timer esp_wifi espcoredump espressif__mdns esptool_py
>>> ext12v fatfs freertos hal heap http_parser idf_test ieee802154 json
>>> libtelnet log lwip main max7317 mbedtls mcp2515 microrl mongoose
>>> mqtt newlib nvs_flash obd2ecu openthread ovms_buffer ovms_cellular
>>> ovms_http ovms_location ovms_mdns ovms_netlib ovms_ota ovms_plugins
>>> ovms_script ovms_server ovms_server_v2 ovms_server_v3 ovms_tls
>>> ovms_tpms ovms_webserver partition_table pcp perfmon powermgmt
>>> protobuf-c protocomm pthread pushover retools retools_pidscan
>>> retools_testerpresent sdcard sdmmc simcom soc spi spi_flash spiffs
>>> strverscmp swcan tcp_transport ulp unity usb vehicle vehicle_bmwi3
>>> vehicle_boltev vehicle_cadillac_c2_cts vehicle_chevrolet_c6_corvette
>>> vehicle_dbc vehicle_demo vehicle_fiat500 vehicle_hyundai_ioniq5
>>> vehicle_hyundai_ioniqvfl vehicle_jaguaripace vehicle_kianiroev
>>> vehicle_kiasoulev vehicle_maxus_edeliver3 vehicle_mercedesb250e
>>> vehicle_mgev vehicle_minise vehicle_mitsubishi vehicle_nissanleaf
>>> vehicle_none vehicle_obdii vehicle_renaulttwizy vehicle_renaultzoe
>>> vehicle_renaultzoe_ph2_obd vehicle_smarted vehicle_smarteq
>>> vehicle_teslamodel3 vehicle_teslamodels vehicle_teslaroadster
>>> vehicle_thinkcity vehicle_toyotarav4ev vehicle_track
>>> vehicle_voltampera vehicle_vweup vehicle_zeva vfs vfsedit
>>> wear_levelling wifi_provisioning wolfssh wolfssl wpa_supplicant
>>> xtensa zip
>>> -- Component paths: SRCS/ESP-IDF/5.0/components/app_trace
>>> SRCS/ESP-IDF/5.0/components/app_update
>>> SRCS/ESP-IDF/5.0/components/bootloader
>>> SRCS/ESP-IDF/5.0/components/bootloader_support
>>> SRCS/ESP-IDF/5.0/components/bt
>>> SRCS/OVMS-wt2/vehicle/OVMS.V3/components/can
>>> SRCS/OVMS-wt2/vehicle/OVMS.V3/components/canopen
>>> SRCS/ESP-IDF/5.0/components/cmock
>>> SRCS/OVMS-wt2/vehicle/OVMS.V3/components/console
>>> SRCS/OVMS-wt2/vehicle/OVMS.V3/components/console_ssh
>>> SRCS/OVMS-wt2/vehicle/OVMS.V3/components/console_telnet
>>> SRCS/OVMS-wt2/vehicle/OVMS.V3/components/crypto
>>> SRCS/ESP-IDF/5.0/components/cxx
>>> SRCS/OVMS-wt2/vehicle/OVMS.V3/components/dbc
>>> SRCS/ESP-IDF/5.0/components/driver
>>> SRCS/OVMS-wt2/vehicle/OVMS.V3/components/duktape
>>> SRCS/ESP-IDF/5.0/components/efuse
>>> SRCS/ESP-IDF/5.0/components/esp-tls
>>> SRCS/OVMS-wt2/vehicle/OVMS.V3/components/esp32adc
>>> SRCS/OVMS-wt2/vehicle/OVMS.V3/components/esp32bluetooth
>>> SRCS/OVMS-wt2/vehicle/OVMS.V3/components/esp32can
>>> SRCS/OVMS-wt2/vehicle/OVMS.V3/components/esp32system
>>> SRCS/OVMS-wt2/vehicle/OVMS.V3/components/esp32wifi
>>> SRCS/ESP-IDF/5.0/components/esp_adc
>>> SRCS/ESP-IDF/5.0/components/esp_app_format
>>> SRCS/ESP-IDF/5.0/components/esp_common
>>> SRCS/ESP-IDF/5.0/components/esp_eth
>>> SRCS/ESP-IDF/5.0/components/esp_event
>>> SRCS/ESP-IDF/5.0/components/esp_gdbstub
>>> SRCS/ESP-IDF/5.0/components/esp_hid
>>> SRCS/ESP-IDF/5.0/components/esp_http_client
>>> SRCS/ESP-IDF/5.0/components/esp_http_server
>>> SRCS/ESP-IDF/5.0/components/esp_https_ota
>>> SRCS/ESP-IDF/5.0/components/esp_https_server
>>> SRCS/ESP-IDF/5.0/components/esp_hw_support
>>> SRCS/ESP-IDF/5.0/components/esp_lcd
>>> SRCS/ESP-IDF/5.0/components/esp_local_ctrl
>>> SRCS/ESP-IDF/5.0/components/esp_netif
>>> SRCS/ESP-IDF/5.0/components/esp_partition
>>> SRCS/ESP-IDF/5.0/components/esp_phy
>>> SRCS/ESP-IDF/5.0/components/esp_pm
>>> SRCS/ESP-IDF/5.0/components/esp_psram
>>> SRCS/ESP-IDF/5.0/components/esp_ringbuf
>>> SRCS/ESP-IDF/5.0/components/esp_timer
>>> SRCS/ESP-IDF/5.0/components/esp_wifi
>>> SRCS/ESP-IDF/5.0/components/espcoredump
>>> SRCS/OVMS-wt2/vehicle/OVMS.V3/managed_components/espressif__mdns
>>> SRCS/ESP-IDF/5.0/components/esptool_py
>>> SRCS/OVMS-wt2/vehicle/OVMS.V3/components/ext12v
>>> SRCS/ESP-IDF/5.0/components/fatfs
>>> SRCS/ESP-IDF/5.0/components/freertos SRCS/ESP-IDF/5.0/components/hal
>>> SRCS/ESP-IDF/5.0/components/heap
>>> SRCS/ESP-IDF/5.0/components/http_parser
>>> SRCS/ESP-IDF/5.0/components/idf_test
>>> SRCS/ESP-IDF/5.0/components/ieee802154
>>> SRCS/ESP-IDF/5.0/components/json
>>> SRCS/OVMS-wt2/vehicle/OVMS.V3/components/libtelnet
>>> SRCS/ESP-IDF/5.0/components/log SRCS/ESP-IDF/5.0/components/lwip
>>> SRCS/OVMS-wt2/vehicle/OVMS.V3/components/max7317
>>> SRCS/ESP-IDF/5.0/components/mbedtls
>>> SRCS/OVMS-wt2/vehicle/OVMS.V3/components/mcp2515
>>> SRCS/OVMS-wt2/vehicle/OVMS.V3/components/microrl
>>> SRCS/OVMS-wt2/vehicle/OVMS.V3/components/mongoose
>>> SRCS/ESP-IDF/5.0/components/mqtt SRCS/ESP-IDF/5.0/components/newlib
>>> SRCS/ESP-IDF/5.0/components/nvs_flash
>>> SRCS/OVMS-wt2/vehicle/OVMS.V3/components/obd2ecu
>>> SRCS/ESP-IDF/5.0/components/openthread
>>> SRCS/OVMS-wt2/vehicle/OVMS.V3/components/ovms_buffer
>>> SRCS/OVMS-wt2/vehicle/OVMS.V3/components/ovms_cellular
>>> SRCS/OVMS-wt2/vehicle/OVMS.V3/components/ovms_http
>>> SRCS/OVMS-wt2/vehicle/OVMS.V3/components/ovms_location
>>> SRCS/OVMS-wt2/vehicle/OVMS.V3/components/ovms_mdns
>>> SRCS/OVMS-wt2/vehicle/OVMS.V3/components/ovms_netlib
>>> SRCS/OVMS-wt2/vehicle/OVMS.V3/components/ovms_ota
>>> SRCS/OVMS-wt2/vehicle/OVMS.V3/components/ovms_plugins
>>> SRCS/OVMS-wt2/vehicle/OVMS.V3/components/ovms_script
>>> SRCS/OVMS-wt2/vehicle/OVMS.V3/components/ovms_server
>>> SRCS/OVMS-wt2/vehicle/OVMS.V3/components/ovms_server_v2
>>> SRCS/OVMS-wt2/vehicle/OVMS.V3/components/ovms_server_v3
>>> SRCS/OVMS-wt2/vehicle/OVMS.V3/components/ovms_tls
>>> SRCS/OVMS-wt2/vehicle/OVMS.V3/components/ovms_tpms
>>> SRCS/OVMS-wt2/vehicle/OVMS.V3/components/ovms_webserver
>>> SRCS/ESP-IDF/5.0/components/partition_table
>>> SRCS/OVMS-wt2/vehicle/OVMS.V3/components/pcp
>>> SRCS/ESP-IDF/5.0/components/perfmon
>>> SRCS/OVMS-wt2/vehicle/OVMS.V3/components/powermgmt
>>> SRCS/ESP-IDF/5.0/components/protobuf-c
>>> SRCS/ESP-IDF/5.0/components/protocomm
>>> SRCS/ESP-IDF/5.0/components/pthread
>>> SRCS/OVMS-wt2/vehicle/OVMS.V3/components/pushover
>>> SRCS/OVMS-wt2/vehicle/OVMS.V3/components/retools
>>> SRCS/OVMS-wt2/vehicle/OVMS.V3/components/retools_pidscan
>>> SRCS/OVMS-wt2/vehicle/OVMS.V3/components/retools_testerpresent
>>> SRCS/OVMS-wt2/vehicle/OVMS.V3/components/sdcard
>>> SRCS/ESP-IDF/5.0/components/sdmmc
>>> SRCS/OVMS-wt2/vehicle/OVMS.V3/components/simcom
>>> SRCS/OVMS-wt2/vehicle/OVMS.V3/components/spi
>>> SRCS/ESP-IDF/5.0/components/spi_flash
>>> SRCS/ESP-IDF/5.0/components/spiffs
>>> SRCS/OVMS-wt2/vehicle/OVMS.V3/components/strverscmp
>>> SRCS/OVMS-wt2/vehicle/OVMS.V3/components/swcan
>>> SRCS/ESP-IDF/5.0/components/tcp_transport
>>> SRCS/ESP-IDF/5.0/components/ulp SRCS/ESP-IDF/5.0/components/unity
>>> SRCS/ESP-IDF/5.0/components/usb
>>> SRCS/OVMS-wt2/vehicle/OVMS.V3/components/vehicle
>>> SRCS/OVMS-wt2/vehicle/OVMS.V3/components/vehicle_bmwi3
>>> SRCS/OVMS-wt2/vehicle/OVMS.V3/components/vehicle_boltev
>>> SRCS/OVMS-wt2/vehicle/OVMS.V3/components/vehicle_cadillac_c2_cts
>>> SRCS/OVMS-wt2/vehicle/OVMS.V3/components/vehicle_chevrolet_c6_corvette
>>> SRCS/OVMS-wt2/vehicle/OVMS.V3/components/vehicle_dbc
>>> SRCS/OVMS-wt2/vehicle/OVMS.V3/components/vehicle_demo
>>> SRCS/OVMS-wt2/vehicle/OVMS.V3/components/vehicle_fiat500
>>> SRCS/OVMS-wt2/vehicle/OVMS.V3/components/vehicle_hyundai_ioniq5
>>> SRCS/OVMS-wt2/vehicle/OVMS.V3/components/vehicle_hyundai_ioniqvfl
>>> SRCS/OVMS-wt2/vehicle/OVMS.V3/components/vehicle_jaguaripace
>>> SRCS/OVMS-wt2/vehicle/OVMS.V3/components/vehicle_kianiroev
>>> SRCS/OVMS-wt2/vehicle/OVMS.V3/components/vehicle_kiasoulev
>>> SRCS/OVMS-wt2/vehicle/OVMS.V3/components/vehicle_maxus_edeliver3
>>> SRCS/OVMS-wt2/vehicle/OVMS.V3/components/vehicle_mercedesb250e
>>> SRCS/OVMS-wt2/vehicle/OVMS.V3/components/vehicle_mgev
>>> SRCS/OVMS-wt2/vehicle/OVMS.V3/components/vehicle_minise
>>> SRCS/OVMS-wt2/vehicle/OVMS.V3/components/vehicle_mitsubishi
>>> SRCS/OVMS-wt2/vehicle/OVMS.V3/components/vehicle_nissanleaf
>>> SRCS/OVMS-wt2/vehicle/OVMS.V3/components/vehicle_none
>>> SRCS/OVMS-wt2/vehicle/OVMS.V3/components/vehicle_obdii
>>> SRCS/OVMS-wt2/vehicle/OVMS.V3/components/vehicle_renaulttwizy
>>> SRCS/OVMS-wt2/vehicle/OVMS.V3/components/vehicle_renaultzoe
>>> SRCS/OVMS-wt2/vehicle/OVMS.V3/components/vehicle_renaultzoe_ph2_obd
>>> SRCS/OVMS-wt2/vehicle/OVMS.V3/components/vehicle_smarted
>>> SRCS/OVMS-wt2/vehicle/OVMS.V3/components/vehicle_smarteq
>>> SRCS/OVMS-wt2/vehicle/OVMS.V3/components/vehicle_teslamodel3
>>> SRCS/OVMS-wt2/vehicle/OVMS.V3/components/vehicle_teslamodels
>>> SRCS/OVMS-wt2/vehicle/OVMS.V3/components/vehicle_teslaroadster
>>> SRCS/OVMS-wt2/vehicle/OVMS.V3/components/vehicle_thinkcity
>>> SRCS/OVMS-wt2/vehicle/OVMS.V3/components/vehicle_toyotarav4ev
>>> SRCS/OVMS-wt2/vehicle/OVMS.V3/components/vehicle_track
>>> SRCS/OVMS-wt2/vehicle/OVMS.V3/components/vehicle_voltampera
>>> SRCS/OVMS-wt2/vehicle/OVMS.V3/components/vehicle_vweup
>>> SRCS/OVMS-wt2/vehicle/OVMS.V3/components/vehicle_zeva
>>> SRCS/ESP-IDF/5.0/components/vfs
>>> SRCS/OVMS-wt2/vehicle/OVMS.V3/components/vfsedit
>>> SRCS/ESP-IDF/5.0/components/wear_levelling
>>> SRCS/ESP-IDF/5.0/components/wifi_provisioning
>>> SRCS/OVMS-wt2/vehicle/OVMS.V3/components/wolfssh
>>> SRCS/ESP-IDF/5.0/components/wpa_supplicant
>>> SRCS/ESP-IDF/5.0/components/xtensa
>>> SRCS/OVMS-wt2/vehicle/OVMS.V3/components/zip
>>> -- Configuring done
>>> -- Generating done
>>> -- Build files have been written to: SRCS/OVMS-wt2/vehicle/OVMS.V3/build
>> So the next line that should have been printed, instead of the error,
>> would have been:
>> Could you check that your env variable `IDF_PATH` is pointing to the
>> proper copy of ESP-IDF (v5 then) ? It's currently set to
>> `/home/balzer/esp/esp-idf`.
>> (The main CMakeLists.txt includes
>> `$ENV{IDF_PATH}/tools/cmake/project.cmake`)
>> The important env variables for ESP-IDF would be:
>> * CMAKE_COLOR_DIAGNOSTICS set to 1 to have beautiful error messages
>> * ESPBAUD set to 921600
>> * ESPPORT set to your usb device (mine is /dev/cu.usbserial-0001)
>> * ESP_IDF_VERSION (5.0 here)
>> * IDF_PATH should be set to the proper 5.0 root
>> * IDF_TOOLS_EXPORT_CMD on my installation is equivalent to
>> $IDF_PATH/export.sh
>> * IDF_TOOLS_INSTALL_CMD on my installation is equivalent to
>> $IDF_PATH/install.sh
>> * IDF_TOOLS_PATH should be set to proper 5.0 tools root
>> * IDF_PYTHON_ENV_PATH on my installation is equivalent to
>> $IDF_TOOLS_PATH/python_env/idf5.0_py3.10_env
>> * OPENOCD_SCRIPTS on my installation is equivalent to
>> $IDF_TOOLS_PATH/tools/openocd-esp32/v0.11.0-esp32-20221026/openocd-esp32/share/openocd/scripts
>> and
>> * PATH which should include a few occurrences of $IDF_PATH and
>> $IDF_TOOLS_PATH
>> All of them should be automatically set it you have installed per the
>> docs, and the fact that "hello_world" compiles is a good indicator
>> that it was OK on your install , but double-checking is always
>> interesting.
>> Let me know the result of your checks.
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20230205/08fb248a/attachment-0001.htm>
