[Ovmsdev] Android App beta
Mon Sep 26 19:56:52 HKT 2022
Nice, please go ahead if you want to create an includable example widget :-)
I've found out you can also use progress bars to display values, enable
formula input on the "step" & set the formular to e.g. $br(ovms, car_soc)$.
Works, although I need to convert all car model values to strings for
KWGT. Btw, I also need to unroll the TPMS arrays, they are split into a
"_cnt" & "_<n>" variables. I need to add an info on this to the wiki.
I haven't found out how to send a broadcast from KWGT yet, is that
possible? That would enable creating command shortcuts & buttons as with
Automagic.
Am 26.09.22 um 12:13 schrieb Chris van der Meijden:
> Correction:
> $br(ovms, sel_vehicle_label)$
> Am Montag, dem 26.09.2022 um 12:05 +0200 schrieb Chris van der Meijden:
>> I like the new KWGT Widget feature:
>> Above is the Tesla Widget of our Model 3, beneath that my OVMS KWGT
>> widget of our VW e-UP.
>> I had to allow "Passing data to other apps". The syntax for getting
>> the intent variables to text in KWGT is i.e.
>> $br(ovms, car_sel_vehicle_label)$
>> Other variables can be found here:
>> https://github.com/openvehicles/Open-Vehicle-Android/wiki/Update-Broadcast-Intent-data
>> The image is local on the filesystem of the phone and does not come
>> by intent.
>> Am Sonntag, dem 25.09.2022 um 16:23 +0200 schrieb Michael Balzer:
>> No, icon can only be 0 from the else branch, in that case it shall
>> fall back to the default image.
>> But I've meanwhile found (I think) your maps/track crash, commit is
>> already in the hub. The checkbox handler didn't check if the map
>> object is initialized.
>> https://github.com/openvehicles/Open-Vehicle-Android/blob/master/OpenVehicleApp/src/main/java/com/openvehicles/OVMS/ui/FragMap.java#L319
>> Am 25.09.22 um 15:46 schrieb Chris van der Meijden:
>> Just guessing, but does
>> int icon;
>> in MyGcmListenerService.java
>> <https://github.com/devmarxx/Open-Vehicle-Android/commit/3c13100a6a25257fe694be3050a1b76ca2b6fb44#diff-c13198cb33bb355f600c37f8889cedcb72346835dbb7e357c031c57aba424487> at
>> line 132
>> not need to be initialized like
>> int icon = 0;
>> now you use
>> .setSmallIcon((icon!= 0) ? icon: R.drawable.map_car_default)
>> at line 150 now?
>> As the images and the Google stuff are related to that integer it
>> made me thinking ...
>> Am Sonntag, dem 25.09.2022 um 11:52 +0200 schrieb Michael Balzer:
>>> Chris,
>>> that's not a crash log, that's just a warning.
>>> On that warning: the App requests
>>> android.permission.ACCESS_FINE_LOCATION by it's manifest. Maybe with
>>> LineageOS you need to manually give it that permission?
>>> A crash log has class "E" (error) and includes an exception and a
>>> backtrace, for an example see:
>>> https://issuetracker.google.com/issues/201308676#comment4
>>> On the crash: maybe it's because you don't have the Google
>>> components, not sure if FragMap can handle that.
>>> The forum post relates to /e/OS … maybe I need some emulator images
>>> running alternative Androids now…
>>> Am 25.09.22 um 11:40 schrieb Chris van der Meijden:
>>> Hey Michael,
>>> this is from logcat when I change "Track vehicle" and the app crashes:
>>> 09-25 11:16:01.410 1710 1839 W BroadcastQueue: Permission Denial:
>>> receiving Intent { act=android.intent.action.SERVICE_STATE
>>> flg=0x1000010 (has extras) } to ProcessRecord{8dcdd54
>>> 2053:com.android.systemui/u0a148} (pid=2053, uid=10148) requires
>>> android.permission.ACCESS_FINE_LOCATION due to sender android (uid 1001)
>>> I saw now, that this crash also happens in the production app.
>>> The widget is running well. I will keep the app running for while
>>> and will see if it stays stable.
>>> Regards
>>> Chris
>>> Am Samstag, dem 24.09.2022 um 23:02 +0200 schrieb Michael Balzer:
>>>> Chris,
>>>> thanks for testing. A crash log would help on any crashes you see.
>>>> Btw, I don't bump the revision until the actual release build.
>>>> Crashes related to the car image don't occur immediately, it
>>>> sometimes takes hours of use before it happens. When it does,
>>>> clearing the App cache fixes the crash for another random period.
>>>> Speed optimization was one goal. What about the widget?
>>>> Thanks,
>>>> Michael
>>>> Am 24.09.22 um 22:43 schrieb Chris van der Meijden:
>>>> Hey Michael,
>>>> I just installed the "release" Version on LineageOS 19.1 (Android
>>>> 12) without Google components.
>>>> The vehicle setup was without any troubles. I could select the
>>>> yellow VW e-UP image without crashing.
>>>> The App version is set wrong under "Vehicle info" (3.19.1, 2021122401).
>>>> Everything seems to be faster than before.
>>>> When I change the checkbox on "Track vehicle" under "Position" the
>>>> App crashes. But after a new start of the app the value of the
>>>> checkbox has changed.
>>>> Perhaps this first impression is of some help.
>>>> Regards
>>>> Chris
>>>> Am Samstag, dem 24.09.2022 um 20:10 +0200 schrieb Michael Balzer:
>>>>> Everyone,
>>>>> I'm currently working on the next Android release including
>>>>> KustomWidget support and a native app widget based on the old
>>>>> Automagic gauge widget.
>>>>> Automagic has been dead for some time now, and it keeps crashing
>>>>> on Androids >= 7.
>>>>> My changes so far are in the hub, APK builds are available here:
>>>>>   * https://dexters-web.de/f/tw-beta/OpenVehicleApp-22092401-release.apk
>>>>>   * debug build for extended logging:
>>>>>     https://dexters-web.de/f/tw-beta/OpenVehicleApp-22092401-debug.apk
>>>>> There's an issue with the App related to Android >= 10 though,
>>>>> which I haven't found yet. It's been reported in the forum:
>>>>>   * https://www.openvehicles.com/node/3410
>>>>> I could use some help with that, I've got no idea other than
>>>>> blaming Android.
>>>>> I've seen the effect in my emulator tests, and it seems to occur
>>>>> more frequently with non-roadster images.
>>>>> Regards,
>>>>> Michael
>>>>> OvmsDev mailing list
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20220926/cf113d1a/attachment-0001.htm>
Type: image/png
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20220926/cf113d1a/attachment-0001.png>
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20220926/cf113d1a/attachment-0001.sig>
