[Ovmsdev] DBC : proposal fix for negative integer numbers having wrong values
Michael Geddes
Fri Oct 14 16:40:09 HKT 2022
OOH.. nice one. I had missed that in my template implementation. I'm a big
fan of using C++ templating to do type-safe versions of this kind of
stuff... This is my template version:
/** Sign extend an unsigned to a signed integer of the same size.
template<typename UINT, typename INT, uint8_t SIGNBIT>
INT sign_extend( UINT uvalue)
typedef typename std::make_unsigned<INT>::type uint_t;
uint_t newuvalue = uvalue;
if ( newuvalue & ( UINT(1U) << SIGNBIT) ) {
newuvalue |= ~((uint_t(1U) << SIGNBIT) - 1);
return reinterpret_cast<INT &>(uvalue);
It could probably be converted into a version that would infer some of the
types.. but this should work pretty well and should compile down to close
to the same code.
Usage from my code: Where BYTES is a templated integer value parameter.
res = sign_extend < uint32_t, int32_t, BYTES * 8 - 1 > (ures);
I also have a templated buffer extractor that allows for checking available
space!
For example this code (which extracts 2 bytes as a signed integer), which
should now work with sign extension thanks to your bugfix and the above
templated version of sign extension:
int32_t signedValue;
if (!can_buff_int<2>(data, 10, signedValue )) {
ESP_LOGE(TAG, "IoniqISOTP.BMC: BMS Current: Bad Buffer");
} else {
StdMetrics.ms_v_bat_current->SetValue((float)signedValue / 10.0,
Amps);
//.ichael
On Fri, 14 Oct 2022 at 05:35, Ludovic LANGE <ll-ovmsdev at lange.nom.fr> wrote:
> Dear list,
> I've come across an issue with the DBC parser where a non-32-bit negative
> number was incorrectly decoded.
> I've traced this to an issue with sign-extension ; and I've proposed a fix
> here
> https://github.com/openvehicles/Open-Vehicle-Monitoring-System-3/pull/736
> Before having it merged, I'd like to gather some feedback from users of
> the DBC module.
> Please have a look, and comment directly on the GitHub PR.
> Thanks in advance !
> Ludovic
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20221014/2ae9b461/attachment.htm>
