[Ovmsdev] Android App beta
Mon Oct 10 01:16:24 HKT 2022
Chris, Michael, thanks for tests & feedback.
Code changes so far are now in the hub:
https://github.com/openvehicles/Open-Vehicle-Android/commit/c23b3dbd772bdae7e82601797cd3a71c2623a78c
This has become a very large commit, and it mixes some version update
changes that became necessary & deprecation fixes I should have kept
separate, but cannot disentangle now.
Some things still to do for the release, most notably removing UI
interaction from the service. So if any other stuff shall be added to
the next release, tell me & go ahead preparing that.
Am 09.10.22 um 17:09 schrieb Chris van der Meijden:
> I tested the new build. Everything is working fine for me.
> I think it is a good idea to restrict the respond to only
> action.COMMAND and leave SendCommand for background operation.
> Am Sonntag, dem 09.10.2022 um 16:05 +0200 schrieb Michael Balzer:
>> Chris, Michael,
>> new builds with the announced new security scheme:
>>   * https://dexters-web.de/f/tw-beta/OpenVehicleApp-22100901-release.apk
>>   * https://dexters-web.de/f/tw-beta/OpenVehicleApp-22100901-debug.apk
>> This adds a new API key authorization to both Intent interfaces. The
>> API key is automatically generated on App launch, and can be viewed,
>> copied and regenerated from the general options page.
>> It can be used for both command intents by passing in as extra
>> "apikey", allowing to omit the vehicle password. The vehicle id is
>> now also optional on both interfaces, if omitted the current vehicle
>> will be used. To change the car you can either pass the vehicle
>> password or the apikey along with the vehicle id.
>> So with am, you can now use:
>>   * am broadcast -a com.openvehicles.OVMS.SendCommand -e apikey … -e
>>     command "stat"
>>   * am start -a com.openvehicles.OVMS.action.COMMAND -e apikey … -e
>>     command "stat"
>> The second guarantees the activity is started, so the response will
>> be visible.
>> I'll probably restrict displaying the response to action.COMMAND in
>> the next build, so SendCommand will be for background operations
>> while action.COMMAND is for interactive uses.
>> Android 10 (API 29) has a new limitation for displaying results
>> (starting UI activities) from a service
>> (https://developer.android.com/guide/components/activities/background-starts),
>> so that works only by chance now anyway.
>> Am 09.10.22 um 12:45 schrieb Chris van der Meijden:
>> Hi Michael,
>> thank you for your response. As always of great help :-)
>> Good that you could find a possible security risc concerning the
>> credentials.
>> Regards
>> Chris
>> Am Sonntag, dem 09.10.2022 um 10:53 +0200 schrieb Michael Balzer:
>>> Chris,
>>> AFAIK you need to have an adb connection or a rooted Android to use
>>> "am", so not suitable as a general way to call OVMS commands.
>>> With your (rooted) Lineageos you should be able to use it like this:
>>> am broadcast -a com.openvehicles.OVMS.SendCommand -e sel_vehicleid
>>> xxx -e sel_server_password xxx -e msg_command "7,stat"
>>> And I missed mentioning I also added support for user command syntax
>>> to "SendCommand", so you can now alternatively do
>>> xxx -e sel_server_password xxx -e command "stat"
>>> Playing with am, I found out…
>>> am start -n com.openvehicles.OVMS/.api.CommandActivity -a
>>> com.openvehicles.OVMS.action.COMMAND -e command "stat"
>>> …actually works to trigger the new command receiver. I thought
>>> restricting the new receiver to app-internal intents would be
>>> possible, but it apparently isn't. That bothers me, it means any App
>>> could issue a command without knowing the credentials or an auth key
>>> and without a previous explicit user interaction to allow this.
>>> So I need to add a credentials check to the new action, which means
>>> you will need to reinstall all bookmarks / shortcut assignments.
>>> Please wait with complex setups until I've added that.
>>> Am 08.10.22 um 19:30 schrieb Chris van der Meijden:
>>> I have been playing with the "SH" function of KWGT and tried to send
>>> a broadcast over the shell, like adb:
>>> 'am broadcast -acom.whereismywifeserver.intent.TEST --essms_body
>>> "test fromadb"'
>>> That did not work, there where "rights" issues.
>>> I took a look at the commands documentation. I will play a bit with
>>> that.
>>> Thanx for explaining!
>>> Am Samstag, dem 08.10.2022 um 18:54 +0200 schrieb Michael Balzer:
>>>> Chris,
>>>> "com.openvehicles.OVMS.SendCommand" is the old command action, it's
>>>> still supported and should work the same way as before, except
>>>> there are some new extras in the response intent.
>>>> The "SendCommand" interface is raw MP function level, that's why
>>>> you need to prefix "7," for text commands (7 = execute text
>>>> command). Other MP commands work just the same way as raw commands,
>>>> e.g. "20,<pin>" will lock the car if supported.
>>>> (https://docs.openvehicles.com/en/latest/protocol_v2/commands.html)
>>>> The newly added command intent action is
>>>> "com.openvehicles.OVMS.action.COMMAND", it just takes one extra
>>>> "command", which takes the command just as entered in the
>>>> notification page. See help there for the syntax, text commands can
>>>> be given as in the shell, to send the above MP lock command, you'd
>>>> enter "#20,<pin>". This action currently always sends the command
>>>> to the currently selected vehicle.
>>>> KWGT doesn't support sending intents, that's why I've done all this.
>>>> To call a stored command from KWGT, set a suitable element's touch
>>>> handler to "start shortcut". After clicking on that action, you can
>>>> open a selector. It will show the list of shortcut providers
>>>> installed including the OVMS App now. Click on the OVMS entry, then
>>>> select the command from the list of stored commands.
>>>> Regards,
>>>> Michael
>>>> Am 08.10.22 um 17:54 schrieb Chris van der Meijden:
>>>> Hi Michael
>>>> I just installed the release apk on my degoogled Lineageos 19.1.
>>>> Installation went without any troubles. I tested the broadcast with
>>>> my fireplace app via webinent:
>>>> action: 'com.openvehicles.OVMS.SendCommand',
>>>> extras: {
>>>>    sel_vehicleid: vid,
>>>>    sel_server_password: pwd,
>>>>    msg_command: '7,climatecontrol on'
>>>> It works still fine and I can see the response dialog in the OVMS app.
>>>> I don't understand the "MP function". Do you have an example for
>>>> for i.e. "climatecontrol on" via Buttons in KWGT? I'd love to test
>>>> that :-)
>>>> And do you know if there is a way to send intent broadcasts with
>>>> KWGT? I tried with a "GLOBALE", but I could not get that to work.
>>>> Regards
>>>> Chris
>>>> Am Samstag, dem 08.10.2022 um 15:37 +0200 schrieb Michael Balzer:
>>>>> New test build:
>>>>>   * https://dexters-web.de/f/tw-beta/OpenVehicleApp-22100801-release.apk
>>>>>   * https://dexters-web.de/f/tw-beta/OpenVehicleApp-22100801-debug.apk
>>>>> This includes major extensions & code rewrites, I think I'll bump
>>>>> the version to 4.0 when releasing this to Google Play.
>>>>> Main goal & outcome of this effort: command bookmarks.
>>>>> The App now offers stored commands (see notifications tab). Stored
>>>>> commands can be pinned to the launcher and selected from third
>>>>> party Apps like KWGT as shortcuts to execute on triggers / actions.
>>>>> So this enabled custom widgets to include buttons triggering car
>>>>> commands.
>>>>> Commands are given using the user syntax, i.e. don't need the MP
>>>>> function prefix. You can still call an MP function by using the
>>>>> user syntax, i.e. "#…".
>>>>> Command responses are shown as a dialog with a timeoout of 5
>>>>> seconds unless you hold it by touching or begin scrolling a long
>>>>> response. If the App is paused it will be resumed and switch to
>>>>> the notifications page (which keeps a record of all commands &
>>>>> responses). If the App isn't running, only the response dialog is
>>>>> shown on the launcher.
>>>>> All this of course needs the service to be enabled & allow
>>>>> commands to be sent.
>>>>> Command responses are also broadcasted now, so KWGT et al can
>>>>> receive them -- but they will currently need to know the command
>>>>> sent previously and copy command responses if they need to keep
>>>>> them, I don't know if KWGT can do that (Automagic can). KWGT seems
>>>>> to only have a simple variable storage model.
>>>>> I think about extending the ApiService to keep a command queue so
>>>>> the broadcast can at least carry the command, the response is
>>>>> supposedly produced for. Unfortunately the MP API cannot guarantee
>>>>> this, as it doesn't currently return a copy of the original
>>>>> command or a command ID reference with the response, so this would
>>>>> at best be a guess. Not sure if users actually need this.
>>>>> Note: I haven't pushed the code changes to github yet, I'd first
>>>>> like to get some test feedback. I've tested this on Android 6, 7,
>>>>> 11 & 13, but not on any degoogled Androids.
>>>>> Regards,
>>>>> Michael
>>>>> Am 26.09.22 um 17:26 schrieb Chris van der Meijden:
>>>>> For an includable example it would be nice if we could send the
>>>>> vehicle image from the OVMS app to KWGT.
>>>>> You can assign "Activities" to the "Touch" event on an image.
>>>>> Would be cool if that works, so we can start the remote climate
>>>>> control similar to how I do that with my OVMS-Fireplace app:
>>>>> https://github.com/devmarxx/OVMS-Fireplace
>>>>> Am Montag, dem 26.09.2022 um 13:56 +0200 schrieb Michael Balzer:
>>>>>> Nice, please go ahead if you want to create an includable example
>>>>>> widget :-)
>>>>>> I've found out you can also use progress bars to display values,
>>>>>> enable formula input on the "step" & set the formular to e.g.
>>>>>> $br(ovms, car_soc)$.
>>>>>> Works, although I need to convert all car model values to strings
>>>>>> for KWGT. Btw, I also need to unroll the TPMS arrays, they are
>>>>>> split into a "_cnt" & "_<n>" variables. I need to add an info on
>>>>>> this to the wiki.
>>>>>> I haven't found out how to send a broadcast from KWGT yet, is
>>>>>> that possible? That would enable creating command shortcuts &
>>>>>> buttons as with Automagic.
>>>>>> Regards,
>>>>>> Michael
>>>>>> Am 26.09.22 um 12:13 schrieb Chris van der Meijden:
>>>>>> Correction:
>>>>>> $br(ovms, sel_vehicle_label)$
>>>>>> Am Montag, dem 26.09.2022 um 12:05 +0200 schrieb Chris van der
>>>>>> Meijden:
>>>>>>> I like the new KWGT Widget feature:
>>>>>>> Above is the Tesla Widget of our Model 3, beneath that my OVMS
>>>>>>> KWGT widget of our VW e-UP.
>>>>>>> I had to allow "Passing data to other apps". The syntax for
>>>>>>> getting the intent variables to text in KWGT is i.e.
>>>>>>> $br(ovms, car_sel_vehicle_label)$
>>>>>>> Other variables can be found here:
>>>>>>> https://github.com/openvehicles/Open-Vehicle-Android/wiki/Update-Broadcast-Intent-data
>>>>>>> The image is local on the filesystem of the phone and does not
>>>>>>> come by intent.
>>>>>>> Am Sonntag, dem 25.09.2022 um 16:23 +0200 schrieb Michael Balzer:
>>>>>>> No, icon can only be 0 from the else branch, in that case it
>>>>>>> shall fall back to the default image.
>>>>>>> But I've meanwhile found (I think) your maps/track crash, commit
>>>>>>> is already in the hub. The checkbox handler didn't check if the
>>>>>>> map object is initialized.
>>>>>>> https://github.com/openvehicles/Open-Vehicle-Android/blob/master/OpenVehicleApp/src/main/java/com/openvehicles/OVMS/ui/FragMap.java#L319
>>>>>>> Regards,
>>>>>>> Michael
>>>>>>> Am 25.09.22 um 15:46 schrieb Chris van der Meijden:
>>>>>>> Just guessing, but does
>>>>>>> int icon;
>>>>>>> in MyGcmListenerService.java
>>>>>>> <https://github.com/devmarxx/Open-Vehicle-Android/commit/3c13100a6a25257fe694be3050a1b76ca2b6fb44#diff-c13198cb33bb355f600c37f8889cedcb72346835dbb7e357c031c57aba424487> at
>>>>>>> line 132
>>>>>>> not need to be initialized like
>>>>>>> int icon = 0;
>>>>>>> now you use
>>>>>>> .setSmallIcon((icon!= 0) ? icon: R.drawable.map_car_default)
>>>>>>> at line 150 now?
>>>>>>> As the images and the Google stuff are related to that integer
>>>>>>> it made me thinking ...
>>>>>>> Am Sonntag, dem 25.09.2022 um 11:52 +0200 schrieb Michael Balzer:
>>>>>>>> Chris,
>>>>>>>> that's not a crash log, that's just a warning.
>>>>>>>> On that warning: the App requests
>>>>>>>> android.permission.ACCESS_FINE_LOCATION by it's manifest. Maybe
>>>>>>>> with LineageOS you need to manually give it that permission?
>>>>>>>> A crash log has class "E" (error) and includes an exception and
>>>>>>>> a backtrace, for an example see:
>>>>>>>> https://issuetracker.google.com/issues/201308676#comment4
>>>>>>>> On the crash: maybe it's because you don't have the Google
>>>>>>>> components, not sure if FragMap can handle that.
>>>>>>>> The forum post relates to /e/OS … maybe I need some emulator
>>>>>>>> images running alternative Androids now…
>>>>>>>> Regards,
>>>>>>>> Michael
>>>>>>>> Am 25.09.22 um 11:40 schrieb Chris van der Meijden:
>>>>>>>> Hey Michael,
>>>>>>>> this is from logcat when I change "Track vehicle" and the app
>>>>>>>> crashes:
>>>>>>>> 09-25 11:16:01.410 1710 1839 W BroadcastQueue: Permission
>>>>>>>> Denial: receiving Intent {
>>>>>>>> act=android.intent.action.SERVICE_STATE flg=0x1000010 (has
>>>>>>>> extras) } to ProcessRecord{8dcdd54
>>>>>>>> 2053:com.android.systemui/u0a148} (pid=2053, uid=10148)
>>>>>>>> requires android.permission.ACCESS_FINE_LOCATION due to sender
>>>>>>>> android (uid 1001)
>>>>>>>> I saw now, that this crash also happens in the production app.
>>>>>>>> The widget is running well. I will keep the app running for
>>>>>>>> while and will see if it stays stable.
>>>>>>>> Regards
>>>>>>>> Chris
>>>>>>>> Am Samstag, dem 24.09.2022 um 23:02 +0200 schrieb Michael Balzer:
>>>>>>>>> Chris,
>>>>>>>>> thanks for testing. A crash log would help on any crashes you
>>>>>>>>> see. Btw, I don't bump the revision until the actual release
>>>>>>>>> build.
>>>>>>>>> Crashes related to the car image don't occur immediately, it
>>>>>>>>> sometimes takes hours of use before it happens. When it does,
>>>>>>>>> clearing the App cache fixes the crash for another random period.
>>>>>>>>> Speed optimization was one goal. What about the widget?
>>>>>>>>> Thanks,
>>>>>>>>> Michael
>>>>>>>>> Am 24.09.22 um 22:43 schrieb Chris van der Meijden:
>>>>>>>>> Hey Michael,
>>>>>>>>> I just installed the "release" Version on LineageOS 19.1
>>>>>>>>> (Android 12) without Google components.
>>>>>>>>> The vehicle setup was without any troubles. I could select the
>>>>>>>>> yellow VW e-UP image without crashing.
>>>>>>>>> The App version is set wrong under "Vehicle info" (3.19.1,
>>>>>>>>> 2021122401).
>>>>>>>>> Everything seems to be faster than before.
>>>>>>>>> When I change the checkbox on "Track vehicle" under "Position"
>>>>>>>>> the App crashes. But after a new start of the app the value of
>>>>>>>>> the checkbox has changed.
>>>>>>>>> Perhaps this first impression is of some help.
>>>>>>>>> Regards
>>>>>>>>> Chris
>>>>>>>>> Am Samstag, dem 24.09.2022 um 20:10 +0200 schrieb Michael Balzer:
>>>>>>>>>> Everyone,
>>>>>>>>>> I'm currently working on the next Android release including
>>>>>>>>>> KustomWidget support and a native app widget based on the old
>>>>>>>>>> Automagic gauge widget.
>>>>>>>>>> Automagic has been dead for some time now, and it keeps
>>>>>>>>>> crashing on Androids >= 7.
>>>>>>>>>> My changes so far are in the hub, APK builds are available here:
>>>>>>>>>>   * https://dexters-web.de/f/tw-beta/OpenVehicleApp-22092401-release.apk
>>>>>>>>>>   * debug build for extended logging:
>>>>>>>>>>     https://dexters-web.de/f/tw-beta/OpenVehicleApp-22092401-debug.apk
>>>>>>>>>> There's an issue with the App related to Android >= 10
>>>>>>>>>> though, which I haven't found yet. It's been reported in the
>>>>>>>>>> forum:
>>>>>>>>>>   * https://www.openvehicles.com/node/3410
>>>>>>>>>> I could use some help with that, I've got no idea other than
>>>>>>>>>> blaming Android.
>>>>>>>>>> I've seen the effect in my emulator tests, and it seems to
>>>>>>>>>> occur more frequently with non-roadster images.
>>>>>>>>>> Regards,
>>>>>>>>>> Michael
>>>>>>>>>> _______________________________________________
>>>>>>>>>> OvmsDev mailing list
>>>>>>>>>> OvmsDev at lists.openvehicles.com
>>>>>>>>>> http://lists.openvehicles.com/mailman/listinfo/ovmsdev
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20221009/090d7ef9/attachment-0001.htm>
Type: image/png
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20221009/090d7ef9/attachment-0001.png>
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20221009/090d7ef9/attachment-0001.sig>
