[Ovmsdev] OBDII vehicle chicken-n-egg issue
Craig Leres
leres at xse.com
Mon Oct 3 09:20:48 HKT 2022
On 10/2/22 01:27, Michael Balzer wrote:
> the initial poll state is set by the constructor to 0. Poll state 0
> enables polling of the VIN (every 999 seconds) and the engine RPM (every
> 10 seconds) entry of the polls list.
> PollSetState(0) does not disable the polling, it just sets the state to
> 0. You can currently use up to four states.
> I wrote some documenting comments on the poller in vehicle_poller.cpp
> and vehicle.h. A developer manual page is still todo.
> You can also hook into the CAN error reporting or query the error state
> from PollerStateTicker() to detect when the bus goes offline. See the
> Hyundai code for an example on this.
Thanks, that got me aimed in a useful direction.
I spent some too-long-postponed time reverse engineering the PIDs the
Corvette spontaneously transmits; it was easy to pick out the vin and
something that may or may not be rpm but definitely tells me when the
engine is running.
Engine off:
1664745342.332392 1R11 308 00 e8 00 00 20 00 ff
Engine on, about 2000 RPM:
1664745361.231876 1R11 308 00 e8 8b 00 21 00 ff
Engine on, idling at about 650 RPM:
1664745370.031792 1R11 308 00 e8 6a 00 21 00 ff
Now that I'm not polling for rpm every 10 seconds when the car is off,
can1 Tx ovrflw/Tx fails are both staying at zero; I started to worry
that filling up the transmit queue while the car was parked/off was
causing me to lose the ability to transmit anything once it was on
again. Now it's no longer a potential issue.
Craig
OVMS# can can1 status
CAN: can1
Mode: Active
Speed: 500000
DBC: none
Interrupts: 21116
Rx pkt: 21113
Rx ovrflw: 0
Tx pkt: 8
Tx delays: 0
Tx ovrflw: 0
Tx fails: 0
Err flags: 0x00000000
Rx err: 0
Tx err: 0
Rx invalid: 0
Wdg Resets: 0
Wdg Timer: 7 sec(s)
Err Resets: 0
