[Ovmsdev] Strange crashes when logging additional info in can logs
Ludovic LANGE
ll-ovmsdev at lange.nom.fr
Sat Nov 19 04:44:45 HKT 2022
Michael,
You're right, that's the best approach ; thanks for sharing it with me.
Here is a PR :
https://github.com/openvehicles/Open-Vehicle-Monitoring-System-3/pull/777
for review.
(I also converted the second parameter - metric name - but you can
remove this commit if you prefer)
Le 18/11/2022 à 14:51, Michael Balzer a écrit :
> Ludovic,
> there is an even better variant of your second approach, that's
> changing MetricCallbackEntry.m_caller to a std::string.
> That's the same scheme EventCallbackEntry already uses, and m_caller
> is only used to identiy the registrant, so that's straight forward.
> Am 18.11.22 um 01:49 schrieb Ludovic LANGE:
>> Some news...
>> My issue was caused because of course I made a mistake with the way
>> of registering my metrics Listener.
>> I used the following code (see my previous post) in the constructor:
>> + MyMetrics.RegisterListener(IDTAG.c_str(), "*",
>> std::bind(&canlog::MetricListener, this, _1));
>> and for the destructor:
>> + MyMetrics.DeregisterListener(IDTAG.c_str());
>> I had to use IDTAG because this class has multiple instances.
>> The issue is passing IDTAG.c_str() as a parameter ;
>> becauseMyMetrics.RegisterListener stores the value of this const
>> char* parameter and uses it 1) as an immutable parameter and 2) as a
>> value.
>> Of course this does not work with my first way to call
>> MyMetrics.RegisterListener :
>> * the memory buffer returned by IDTAG.c_str() has no more existence
>> after exiting the constructor, so this lead to memory corruption.
>> * when calling IDTAG.c_str() again in the destructor, there is
>> absolutely no chance that this c_str() call returns the same
>> memory address as the call in the constructor, so the value
>> comparison will never work.
>> I rewrote the code this way by adding a new member (m_idtag) to the
>> class:
>> @ vehicle/OVMS.V3/components/can/src/canlog.cpp:352 @
>> canlog::canlog(const char* type, std::string format,
>> canformat::canformat_serve_
>> m_dropcount = 0;
>> m_filtercount = 0;
>> + m_idtag = strdup(IDTAG.c_str());
>> using std::placeholders::_1;
>> using std::placeholders::_2;
>> MyEvents.RegisterEvent(IDTAG, "*",
>> std::bind(&canlog::EventListener, this, _1, _2));
>> + if (NULL != m_idtag)
>> + MyMetrics.RegisterListener(m_idtag, "*",
>> + else
>> + ESP_LOGE(TAG,"Cannot allocate memory - not registering metrics
>> listener");
>> int queuesize = MyConfig.GetParamValueInt("can", "log.queuesize",100);
>> m_queue = xQueueCreate(queuesize, sizeof(CAN_log_message_t));
>> @ vehicle/OVMS.V3/components/can/src/canlog.cpp:374 @
>> canlog::~canlog()
>> MyEvents.DeregisterEvent(IDTAG);
>> + MyMetrics.DeregisterListener(m_idtag);
>> + free((void*)m_idtag);
>> if (m_task)
>> Another option is to change MyMetrics.RegisterListener so that it
>> store *a copy* of the parameter, and does string comparison instead
>> of a value comparison:
>> modified: vehicle/OVMS.V3/main/ovms_metrics.cpp
>> @ vehicle/OVMS.V3/main/ovms_metrics.cpp:1019 @ void
>> OvmsMetrics::RegisterListener(const char* caller, const char* name,
>> MetricC
>> return;
>> + const char * caller_copy = (const char *)strdup(caller);
>> + if (NULL == caller_copy)
>> + ESP_LOGE(TAG, "Problem registering metric %s for caller %s -
>> insufficient memory",name,caller);
>> + return;
>> MetricCallbackList *ml = k->second;
>> - ml->push_back(new MetricCallbackEntry(caller,callback));
>> + ml->push_back(new MetricCallbackEntry(caller_copy,callback));
>> void OvmsMetrics::DeregisterListener(const char* caller)
>> @ vehicle/OVMS.V3/main/ovms_metrics.cpp:1041 @ void
>> while (itc!=ml->end())
>> MetricCallbackEntry* ec = *itc;
>> - if (ec->m_caller == caller)
>> + if (strcmp(ec->m_caller, caller) == 0)
>> + free((char *)ec->m_caller);
>> itc = ml->erase(itc);
>> delete ec;
>> I've tested both approaches and they both solve my issue : no more
>> crashes and memory corruption.
>> The second one is more "risky" (as it potentially impacts everyone)
>> but I think that it should not cause much regression.
>> Let me know what you think - should I make a PR for this second
>> approach ?
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20221118/64f2c69d/attachment.htm>
