[Ovmsdev] New Metric Units
    Michael Geddes
    Sun Nov 13 15:42:14 HKT 2022
Greetings,
so this is my idea of being able to select which units various groups use
(in addition to Distance).
This can be then accessed by the special 'user' unit code.  (or  'metrics
list -u ' )
The idea of [Default] selection below  simply means storing the value to
blank - meaning use whatever unit the particular metric uses.  The other
idea I had was to actually default it to the equivalent of 'Metric' special
unit code and not have the [Default] button.
[image: image.png]
Currently I've made it so that if there are more than 3 choices other than
[default] that it uses the choice/combo box rather than the Radio buttons.
(ie this list is auto-generated from the Metric Units table and the Metric
Groups table).
Thoughts / comments?
//.ichael
On Sat, 12 Nov 2022 at 17:35, Michael Geddes <frog at bunyip.wheelycreek.net>
wrote:
> https://github.com/openvehicles/Open-Vehicle-Monitoring-System-3/pull/771
> I'm hoping this P/R is ok in this form (made of 5 separate commits).
> I will have a look at implementing the "user" unit code.  The base for how
> it would work is already a part of the above pull request.  I'll just look
> at the module configuration for distance.
> The 'power consumption' is one where it's not just a check-box.. there're
> 5 possible choice!
> I should also add 'bar' for pressure given that for some reason that's
> still a thing people want.
> //.ichael
> On Sat, 12 Nov 2022 at 16:24, Michael Balzer <dexter at expeedo.de> wrote:
>> I think this is pretty decent & complete now.
>> I also like the approach of the 'user' unit code. Moving all user unit
>> prefs into the module configuration is an old todo. Currently only the
>> distance unit is defined at the module side, temperature and pressure are
>> App prefs.
>> Am 11.11.22 um 09:54 schrieb Michael Geddes:
>> Ok - so here's what I have implemented for Duktape and Metrics. (I added
>> IsDefined() as well).
>> Any thoughts on this?
>> Noting
>>    OvmsMetrics.Float( {metric} ) -> Outputs metric as float (same)
>>    OvmsMetrics.Float( {metric}, {unit}) -> Outputs metric as float
>> converted to given unit  (new)
>>    OvmsMetrics.Value( {metric} )   -> Outputs Metric in native value
>> (same)
>>    OvmsMetrics.Value( {metric} , false)   -> Outputs Metric as string and
>> no units (same)
>>    OvmsMetrics.Value( {metric} ,  {unit})  -> Outputs Metric converted to
>> given unit as native value. (new)
>>   OvmsMetrics.Value( {metric} ,  {unit}, false )  -> Outputs Metric
>> converted to given unit as string including any unit specifier. (new)
>> also  OvmsMetric.GetValues( {metric} [,{unit}] [, {converted} ] )  Adds
>> similar behaviour to Value() above.
>> also the special units '*imperial*' and '*metric*' will convert to the
>> associated imperial / metric version of the units as appropriate.
>> (function() {
>>    dump = function (metric) { print( metric+ " ["+(typeof metric)+"]\n"
>>    dump_obj = function (obj )  {
>>      print('--- Object ----\n')
>>      for (var k in obj) {
>>        xk = obj[k];
>>        print( k+':'+ xk + ' ['+typeof xk+ "]\n");
>>    dump(OvmsMetrics.Value("xiq.v.trip.consumption"));
>>    dump(OvmsMetrics.Value("xiq.v.trip.consumption", false));
>>    dump(OvmsMetrics.Value("xiq.v.trip.consumption","kmpkwh"));
>>    dump(OvmsMetrics.Value("xiq.v.trip.consumption", "mipkwh", false));
>>    dump(OvmsMetrics.AsFloat("xiq.v.trip.consumption"));
>>    dump(OvmsMetrics.AsFloat("xiq.v.trip.consumption","kmpkwh"));
>>    dump(OvmsMetrics.Value("xiq.v.trip.consumption","imperial"))
>>    dump(OvmsMetrics.Value("xiq.v.trip.consumption","imperial", false))
>>    dump_obj(OvmsMetrics.GetValues("trip", "metric"))
>>    dump_obj(OvmsMetrics.GetValues("trip", "imperial", false))
>> With this output:
>> 19.2308 [number]
>> 19.2308 [string]
>> 5.2 [number]
>> 3.23112mi/kWh [string]
>> 19.2308 [number]
>> 5.2 [number]
>> 309.49 [number]
>> 309.49Wh/mi [string]
>> --- Object ----
>> v.p.trip:13 [number]
>> xiq.e.trip:0 [number]
>> xiq.e.trip.energy.recuperated:0 [number]
>> xiq.e.trip.energy.used:0 [number]
>> xiq.v.trip.consumption:19.2308 [number]
>> --- Object ----
>> v.p.trip:8.07781M [string]
>> xiq.e.trip:0M [string]
>> xiq.e.trip.energy.recuperated:0kWh [string]
>> xiq.e.trip.energy.used:0kWh [string]
>> xiq.v.trip.consumption:309.49Wh/mi [string]
>> On Wed, 9 Nov 2022 at 05:47, Michael Geddes <frog at bunyip.wheelycreek.net>
>> wrote:
>>> Yeah - I like HasValue.  I implemented IsDefined() but I will rename
>>> it.. that's a much clearer name.
>>> Another thought. How about if we did this (but also with GetValues() as
>>> well - see the special values below)
>>> OvmsMetrics.Value("xiq.v.trip.consumption",  true)  -> 17.0582  (Number)
>>> OvmsMetrics.Value("xiq.v.trip.consumption",  false)  -> 17.0582
>>> (String)
>>> OvmsMetrics.Value("xiq.v.trip.consumption", "mipkwh", true)  -> 3.64264
>>> (Number)
>>> OvmsMetrics.Value("xiq.v.trip.consumption", "mipkwh", false)  ->
>>> 3.64264Mi/kWh  (String)
>>>  OvmsMetrics.Value("xiq.v.trip.consumption", "native", false)  ->
>>> 17.0582km/kWh  (String)
>>> and
>>> OvmsMetrics.Value("xiq.v.trip.consumption", "imperial", false)  ->
>>> I have already implemented the special values 'native' (existing),
>>> 'imperial' and 'metric'.
>>> I was also thinking that in the future you could have 'user'. Where for
>>> each group of values:
>>> 'temperature', 'distance', 'shortdistance', 'power' etc.. you could have
>>> a user preference. I probably won't implement it now,.but it could be cool
>>> that any UI could just ask for the user defined units (rather than having a
>>> separate choice).
>>> //.ichael
>>> On Tue, 8 Nov 2022 at 21:57, Mark Webb-Johnson <mark at webb-johnson.net>
>>> wrote:
>>>> Or perhaps something more specific?
>>>>     HasValue()
>>>> Mark
>>>> On 8 Nov 2022, at 9:01 PM, Michael Balzer <dexter at expeedo.de> wrote:
>>>> Signed PGP part
>>>> That's basically a good approach, but be aware 'IsDefined()' has an
>>>> ambiguous meaning here, as with the API stem "OvmsMetrics" it would
>>>> naturally be expected to mean "is this metric defined", not "does this
>>>> metric have a defined value".
>>>> An undefined metric currently can be derived from 'Values()' returning
>>>> undefined, but that's more an undocumented side effect than intended.
>>>> Maybe 'GetDefined()' could be a better name, leveraging this behaviour,
>>>> i.e. returning 'undefined' for an actually undefined metric, and 'null' for
>>>> a defined metric without a value.
>>>> Regards,
>>>> Michael
>>>> Am 08.11.22 um 13:46 schrieb Michael Geddes:
>>>> Ah yes. Arrays - will check those.  Yeah, how about we add a
>>>> 'IsDefined' method to metrics instead of the null thing (it does sound like
>>>> it will upset too many applecarts).
>>>> On Tue, 8 Nov 2022 at 20:35, Michael Balzer <dexter at expeedo.de> wrote:
>>>>> Michael,
>>>>> looks all good to me, once again nice find with the decode argument.
>>>>> Adding decode to the Value() call was only for symmetry IIRC, the main use
>>>>> was with GetValues() (
>>>>> https://docs.openvehicles.com/en/latest/userguide/scripting.html#ovmsmetrics
>>>>> Don't forget to test arrays, e.g. "v.t.pressure" & "v.t.temp".
>>>>> Returning null for an undefined metric seems like a natural choice,
>>>>> but is a rather deep change, as for consistency not only the Duktape
>>>>> metrics API but also the Web UI metrics API would need to be changed
>>>>> accordingly. Unless you've got a real use case that needs that, we should
>>>>> be careful.
>>>>> Regards,
>>>>> Michael
>>>>> Am 07.11.22 um 15:00 schrieb Michael Geddes:
>>>>> I have figured out a bunch of stuff and have implemented the
>>>>> following: (having done away with needing AsFloatUnit)
>>>>> OvmsMetrics.Value( {metric} [, {decode}])
>>>>> OvmsMetrics.Value( {metric}, {unit} [,{decode}])
>>>>> It turns out that the [decode] flag wasn't working anyway (since the
>>>>> function was being registered as only having 1 param)...
>>>>> This way it is still really 1 function.. but I check it the second
>>>>> parameter is a 'boolean', and if not.. try the second form.
>>>>> OvmsMetrics.AsFloat( {metric} [,{unit}] )
>>>>> and add the function
>>>>> Ovms.Metrics.ValueUnit( {metric} [,{unit}])
>>>>> This prints the value and the unit.
>>>>> Here's a sample function and the output! This also shows the types of
>>>>> the output.
>>>>> (function() {
>>>>>    x = OvmsMetrics.Value("xiq.v.trip.consumption");
>>>>>    print( (typeof x) + ": "+  x+"\n"  );
>>>>>    x = OvmsMetrics.Value("xiq.v.trip.consumption", false);
>>>>>    print( (typeof x) + ": "+  x +"\n" );
>>>>>    x =  OvmsMetrics.Value("xiq.v.trip.consumption","kmpkwh")
>>>>>    print( (typeof x) + ": "+ x +"\n");
>>>>>    x =  OvmsMetrics.Value("xiq.v.trip.consumption", "mipkwh", false)
>>>>>    x =  OvmsMetrics.ValueUnit("xiq.v.trip.consumption")
>>>>>    x =  OvmsMetrics.ValueUnit("xiq.v.trip.consumption","mipkwh")
>>>>>    x =  OvmsMetrics.AsFloat("xiq.v.trip.consumption")
>>>>>    x =  OvmsMetrics.AsFloat("xiq.v.trip.consumption","kmpkwh")
>>>>> number: 17.0582
>>>>> string: 17.0582
>>>>> number: 5.86227
>>>>> string: 3.64264
>>>>> string: 17.0582kWh/100km
>>>>> string: 3.64264mi/kWh
>>>>> number: 17.0582
>>>>> number: 5.86227
>>>>> It still might be an idea to use 'null' as a return value if the
>>>>> metrics is !IsDefined() but that would be changing the existing
>>>>> behaviour slightly.
>>>>> //.ichael
>>>>> On Mon, 7 Nov 2022 at 08:12, Michael Geddes <
>>>>> frog at bunyip.wheelycreek.net> wrote:
>>>>>> I've worked out what the decode flag is for and how it works, and I
>>>>>> think how optional params work.
>>>>>> I'm pretty sure I won't  need the 'AsFloatUnit' function; the unit
>>>>>> would be an option to AsFloat(); I'll know that soon.
>>>>>> The 'Value' function is more complicated because of the optional
>>>>>> decode bool. I guess I could add the Unit to the end of that.
>>>>>> ValueUnit could be still useful then to provide a 'Value + Unit'.
>>>>>> Question:  Is there a reason we shouldn't be returning with
>>>>>> duk_push_null    if the metric !IsDefined()  in both AsFloat() and
>>>>>> Value(metric,true) cases?
>>>>>> //.ichael
>>>>>> On Sun, 6 Nov 2022 at 11:22, Michael Geddes <
>>>>>>> Right, so I've implemented some stuff that seems to work quite well.
>>>>>>> https://github.com/openvehicles/Open-Vehicle-Monitoring-System-3/pull/764
>>>>>>> should be ready now after a couple of stupid mistakes slipped through.
>>>>>>>  This absolutely needs somebody to review it please! (There's a reason why
>>>>>>> I've converted some if()'s to switch() - which is that it will be used in
>>>>>>> the follow-up commit).
>>>>>>> The commit that will follow on from that it implements the new
>>>>>>> Units: kWh/100km, km/kWh  and  mi/kWh.
>>>>>>> This is a summary of what I've implemented for scripting - including
>>>>>>> showing the unit codes I have so far.  I've considered a few things:
>>>>>>>   * Should some of the longer unit codes be shortened  (eg mi, mins,
>>>>>>> m, ft, deg, perc)
>>>>>>>   * The unit codes could be much more regular and separated by
>>>>>>> dots  eg:
>>>>>>>         watthours -> w.h
>>>>>>>         kwhp100km -> kw.h_100km or kw.h/100km
>>>>>>>         miph ->  mi_h or mi/h  (or should it be mph).
>>>>>>>         psi -> p_in.in or p/in.in or lb_in.in (yes, slightly weird,
>>>>>>> but predictable)
>>>>>>> *OVMS# metric units*
>>>>>>>           km : km
>>>>>>>        miles : M
>>>>>>>       meters : m
>>>>>>>         feet : ft
>>>>>>>      celcius : °C
>>>>>>>   fahrenheit : °F
>>>>>>>          kpa : kPa
>>>>>>>           pa : Pa
>>>>>>>          psi : psi
>>>>>>>        volts : V
>>>>>>>         amps : A
>>>>>>>     amphours : Ah
>>>>>>>           kw : kW
>>>>>>>          kwh : kWh
>>>>>>>        watts : W
>>>>>>>    watthours : Wh
>>>>>>>      seconds : Sec
>>>>>>>      minutes : Min
>>>>>>>        hours : Hour
>>>>>>>          utc : UTC
>>>>>>>      degrees : °
>>>>>>>         kmph : km/h
>>>>>>>         miph : Mph
>>>>>>>       kmphps : km/h/s
>>>>>>>       miphps : Mph/s
>>>>>>>         mpss : m/s²
>>>>>>>          dbm : dBm
>>>>>>>           sq : sq
>>>>>>>      percent : %
>>>>>>>        whpkm : Wh/km
>>>>>>>        whpmi : Wh/mi
>>>>>>>    kwhp100km : kWh/100km
>>>>>>>       kmpkwh : km/kWh
>>>>>>>       mipkwh : mi/kWh
>>>>>>>           nm : Nm
>>>>>>> *OVMS# metric unit mi*
>>>>>>>        miles : M
>>>>>>>      minutes : Min
>>>>>>>         miph : Mph
>>>>>>>       miphps : Mph/s
>>>>>>>        whpmi : Wh/mi
>>>>>>>       mipkwh : mi/kWh
>>>>>>> *OVMS# metric get xiq.v.trip.consumption *17.0597kWh/100km
>>>>>>> *OVMS# metric get xiq.v.trip.consumption kpkwh *5.86177km/kWh
>>>>>>> *OVMS# metric get xiq.v.trip.consumption mpkwh *3.64233mi/kWh
>>>>>>> *OVMS# metric set xiq.c.speed 5 miph *Metric set
>>>>>>> *OVMS# metric get xiq.c.speed *8.04673km/h
>>>>>>> *OVMS# metric get xiq.c.speed miph *5Mph
>>>>>>> And then in DukTape - there are some questions I have about the
>>>>>>> implementation:
>>>>>>> * Names of functions? Better ideas?
>>>>>>> * Should ValueUnit output the units?
>>>>>>> * In Value() there is the line    bool decode =
>>>>>>> duk_opt_boolean(ctx, 1, true);
>>>>>>>     * What does 'decode' mean here?
>>>>>>>     * Do I need it for ValueUnit() ?
>>>>>>> * (function() {    print(
>>>>>>> OvmsMetrics.Value("xiq.v.trip.consumption"));    print("\n")    print(
>>>>>>> OvmsMetrics.ValueUnit("xiq.v.trip.consumption",""));    print("\n")
>>>>>>>  print( OvmsMetrics.ValueUnit("xiq.v.trip.consumption","mipkwh"));
>>>>>>>  print("\n")    print(
>>>>>>> OvmsMetrics.AsFloatUnit("xiq.v.trip.consumption","kmpkwh")); })();*
>>>>>>> --- Output ---
>>>>>>> 17.0597
>>>>>>> 17.0597kWh/100km
>>>>>>> 3.64233mi/kWh
>>>>>>> 5.86177
>>>>>>> The basic stuff all works - it's just quibbling over the details..
>>>>>>> but let's get them right!
>>>>>>> //.ichael
>>>>>>> On Sat, 5 Nov 2022 at 20:09, Michael Geddes <
>>>>>>>> Yeah - this was copied code from kia/kona and is what triggered
>>>>>>>> these ideas; I totally agree this shouldn't be doubled up on.
>>>>>>>> I've got some commits centred round Metrics that I'll just check
>>>>>>>> over and push up ... and then I'll just have the single xiq.v.
>>>>>>>> trip.consumption metric (unless you have some ideas for the
>>>>>>>> namespace) which will be much neater.
>>>>>>>> If it's ok with you then I might do that unit conversion proposal.
>>>>>>>> Would it ok if the unit specifications were the same as to the
>>>>>>>> programatic codes in ovms_metrics.h?
>>>>>>>> (kWh,   WattHours , MetersPSS )
>>>>>>>> I would probably add a command
>>>>>>>> metric units <spec>
>>>>>>>> to list all (matching) units and their associated Labels.
>>>>>>>> //.ichael
>>>>>>>> On Sat, 5 Nov 2022 at 18:48, Michael Balzer <dexter at expeedo.de>
>>>>>>>> wrote:
>>>>>>>>> Michael,
>>>>>>>>> adding unit conversion support to the shell and Duktape commands
>>>>>>>>> is a good idea.
>>>>>>>>> Metrics are not meant to provide a user interface, they should be
>>>>>>>>> defined to be efficient and non-redundant.
>>>>>>>>> Btw, metrics names also shall not use upper case characters, and
>>>>>>>>> shall only use "." as a separator.
>>>>>>>>> Regards,
>>>>>>>>> Michael
>>>>>>>>> Am 05.11.22 um 11:22 schrieb Michael Geddes:
>>>>>>>>> Hi all,
>>>>>>>>> Some of the code I copied from Kona/Kia code had both kwh/100km
>>>>>>>>> and km/kwh metrics in the code as 'Other'.
>>>>>>>>> Adding the various power consumption Units is not particularly
>>>>>>>>> hard (I will have a pull-request soon) - though the conversions between
>>>>>>>>> them all required some thought!
>>>>>>>>> ... but it also made me think these two metrics that are (with the
>>>>>>>>> consumption units added) defined like this:
>>>>>>>>> m_v_trip_consumption1 =
>>>>>>>>> MyMetrics.InitFloat("xiq.v.trip.consumption.KWh/100km", 10, 0, kWHP100K);
>>>>>>>>> m_v_trip_consumption2 = MyMetrics.InitFloat("
>>>>>>>>> xiq.v.trip.consumption.km/kWh", 10, 0, kPkWH);
>>>>>>>>> These are effectively the same metric but in different units!
>>>>>>>>> I'm wondering if we would be better to have scripting and Duktape
>>>>>>>>> support for converting metrics to different unit!  This might be also quite
>>>>>>>>> useful for those strange countries that insist on using miles as a
>>>>>>>>> measurement.
>>>>>>>>> On top of the 'metric list' and 'metric set' we could add a
>>>>>>>>> 'metric get' which gets a single value.. and add unit support for get/set.
>>>>>>>>> I've also got a pull request that improves the precision of the
>>>>>>>>> km<->mi conversions and factors it out.
>>>>>>>>> //.ichael
>>>>>>>>> OvmsDev mailing listOvmsDev at lists.openvehicles.comhttp://lists.openvehicles.com/mailman/listinfo/ovmsdev
>>>>>>>>> Michael Balzer * Helkenberger Weg 9 * D-58256 Ennepetal
>>>>>>>>> Fon 02333 / 833 5735 * Handy 0176 / 206 989 26
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20221113/f7edd4f4/attachment-0001.htm>
Type: image/png
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20221113/f7edd4f4/attachment-0001.png>
