[Ovmsdev] Advice regarding BmsSetCell...
Sat Nov 12 22:07:37 HKT 2022
If brick index numbers are normally coming sequentially, a simple
approach would be to fill cell readings sequentially based on just
checking the new brick index is higher than the one received before.
To autodetect the layout, use Michael's new CheckChangeCellArrangement
calls to let the cell array grow for every new highest brick number
received. Once the first complete brick sequence is received, the BMS
cell layout should match the actual battery layout.
A better option able to handle sparse frames: collect the brick index
keys in a std::set or sorted array, use the key index to address the
cells in the BMS, and for auto detection let the cell layout grow with
the set size.
Am 12.11.22 um 14:12 schrieb Michael Geddes:
> I did have some code that handled this kind of stuff... But it was
> over complicated.. There's a new function that allows you to set the
> new size that the ioniq 5 code uses... But a similar function could be
> added that just compresses what is there as well.
> On Sat, 12 Nov 2022, 9:02 pm Mark Webb-Johnson,
> <mark at webb-johnson.net> wrote:
> The original Model S had a fairly simple to decode CAN bus message
> 0x6f2 with the first byte in range 0..1f and each message encoding
> 3 battery bricks, for a total of 96 bricks.
> However, things have now got more complicated. A 75kWh Model X,
> and a replacement pack for a 85kWh Model S, contain cut-down packs
> with modules missing, so 0x6f2 only contains 28 messages, for 84
> bricks, with bricks #15, #16, #17 and #31 missing from the message.
> When we feed this into BmsSetCell… calls, the OVMS BMS support
> code sees the missing bricks, assumes things are missing, and
> refuses to give an output.
> So my (hopefully simple) question, is how to tell it the brick
> arrangement? Or how to deal with these missing bricks?
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20221112/face3782/attachment.htm>
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20221112/face3782/attachment.sig>
