[Ovmsdev] New Metric Units
    Michael Geddes
    Mon Nov  7 22:00:35 HKT 2022
I have figured out a bunch of stuff and have implemented the following:
(having done away with needing AsFloatUnit)
OvmsMetrics.Value( {metric} [, {decode}])
OvmsMetrics.Value( {metric}, {unit} [,{decode}])
It turns out that the [decode] flag wasn't working anyway (since the
function was being registered as only having 1 param)...
This way it is still really 1 function.. but I check it the second
parameter is a 'boolean', and if not.. try the second form.
OvmsMetrics.AsFloat( {metric} [,{unit}] )
and add the function
Ovms.Metrics.ValueUnit( {metric} [,{unit}])
This prints the value and the unit.
Here's a sample function and the output! This also shows the types of the
output.
(function() {
   x = OvmsMetrics.Value("xiq.v.trip.consumption");
   print( (typeof x) + ": "+  x+"\n"  );
   x = OvmsMetrics.Value("xiq.v.trip.consumption", false);
   print( (typeof x) + ": "+  x +"\n" );
   x =  OvmsMetrics.Value("xiq.v.trip.consumption","kmpkwh")
   print( (typeof x) + ": "+ x +"\n");
   x =  OvmsMetrics.Value("xiq.v.trip.consumption", "mipkwh", false)
   x =  OvmsMetrics.ValueUnit("xiq.v.trip.consumption")
   x =  OvmsMetrics.ValueUnit("xiq.v.trip.consumption","mipkwh")
   x =  OvmsMetrics.AsFloat("xiq.v.trip.consumption")
   x =  OvmsMetrics.AsFloat("xiq.v.trip.consumption","kmpkwh")
number: 17.0582
string: 17.0582
number: 5.86227
string: 3.64264
string: 17.0582kWh/100km
string: 3.64264mi/kWh
number: 17.0582
number: 5.86227
It still might be an idea to use 'null' as a return value if the metrics is
!IsDefined() but that would be changing the existing behaviour slightly.
//.ichael
On Mon, 7 Nov 2022 at 08:12, Michael Geddes <frog at bunyip.wheelycreek.net>
wrote:
> I've worked out what the decode flag is for and how it works, and I think
> how optional params work.
> I'm pretty sure I won't  need the 'AsFloatUnit' function; the unit would
> be an option to AsFloat(); I'll know that soon.
> The 'Value' function is more complicated because of the optional decode
> bool. I guess I could add the Unit to the end of that.
> ValueUnit could be still useful then to provide a 'Value + Unit'.
> Question:  Is there a reason we shouldn't be returning with  duk_push_null
>   if the metric !IsDefined()  in both AsFloat() and Value(metric,true)
> cases?
> //.ichael
> On Sun, 6 Nov 2022 at 11:22, Michael Geddes <frog at bunyip.wheelycreek.net>
> wrote:
>> Right, so I've implemented some stuff that seems to work quite well.
>> https://github.com/openvehicles/Open-Vehicle-Monitoring-System-3/pull/764
>> should be ready now after a couple of stupid mistakes slipped through.
>>  This absolutely needs somebody to review it please! (There's a reason why
>> I've converted some if()'s to switch() - which is that it will be used in
>> the follow-up commit).
>> The commit that will follow on from that it implements the new Units:
>> kWh/100km, km/kWh  and  mi/kWh.
>> This is a summary of what I've implemented for scripting - including
>> showing the unit codes I have so far.  I've considered a few things:
>>   * Should some of the longer unit codes be shortened  (eg mi, mins, m,
>> ft, deg, perc)
>>   * The unit codes could be much more regular and separated by dots
>> eg:
>>         watthours -> w.h
>>         kwhp100km -> kw.h_100km or kw.h/100km
>>         miph ->  mi_h or mi/h  (or should it be mph).
>>         psi -> p_in.in or p/in.in or lb_in.in (yes, slightly weird, but
>> predictable)
>> *OVMS# metric units*
>>           km : km
>>        miles : M
>>       meters : m
>>         feet : ft
>>      celcius : °C
>>   fahrenheit : °F
>>          kpa : kPa
>>           pa : Pa
>>          psi : psi
>>        volts : V
>>         amps : A
>>     amphours : Ah
>>           kw : kW
>>          kwh : kWh
>>        watts : W
>>    watthours : Wh
>>      seconds : Sec
>>      minutes : Min
>>        hours : Hour
>>          utc : UTC
>>      degrees : °
>>         kmph : km/h
>>         miph : Mph
>>       kmphps : km/h/s
>>       miphps : Mph/s
>>         mpss : m/s²
>>          dbm : dBm
>>           sq : sq
>>      percent : %
>>        whpkm : Wh/km
>>        whpmi : Wh/mi
>>    kwhp100km : kWh/100km
>>       kmpkwh : km/kWh
>>       mipkwh : mi/kWh
>>           nm : Nm
>> *OVMS# metric unit mi*
>>        miles : M
>>      minutes : Min
>>         miph : Mph
>>       miphps : Mph/s
>>        whpmi : Wh/mi
>>       mipkwh : mi/kWh
>> *OVMS# metric get xiq.v.trip.consumption*17.0597kWh/100km
>> *OVMS# metric get xiq.v.trip.consumption kpkwh*5.86177km/kWh
>> *OVMS# metric get xiq.v.trip.consumption mpkwh*3.64233mi/kWh
>> *OVMS# metric set xiq.c.speed 5 miph*Metric set
>> *OVMS# metric get xiq.c.speed*8.04673km/h
>> *OVMS# metric get xiq.c.speed miph*5Mph
>> And then in DukTape - there are some questions I have about the
>> implementation:
>> * Names of functions? Better ideas?
>> * Should ValueUnit output the units?
>> * In Value() there is the line    bool decode = duk_opt_boolean(ctx, 1,
>> true);
>>     * What does 'decode' mean here?
>>     * Do I need it for ValueUnit() ?
>> *(function() {   print( OvmsMetrics.Value("xiq.v.trip.consumption"));
>>  print("\n")   print( OvmsMetrics.ValueUnit("xiq.v.trip.consumption",""));
>>  print("\n")   print(
>> OvmsMetrics.ValueUnit("xiq.v.trip.consumption","mipkwh"));   print("\n")
>>  print( OvmsMetrics.AsFloatUnit("xiq.v.trip.consumption","kmpkwh"));})();*
>> --- Output ---
>> 17.0597
>> 17.0597kWh/100km
>> 3.64233mi/kWh
>> 5.86177
>> The basic stuff all works - it's just quibbling over the details.. but
>> let's get them right!
>> //.ichael
>> On Sat, 5 Nov 2022 at 20:09, Michael Geddes <frog at bunyip.wheelycreek.net>
>> wrote:
>>> Yeah - this was copied code from kia/kona and is what triggered these
>>> ideas; I totally agree this shouldn't be doubled up on.
>>> I've got some commits centred round Metrics that I'll just check over
>>> and push up ... and then I'll just have the single xiq.v.
>>> trip.consumption metric (unless you have some ideas for the namespace)
>>> which will be much neater.
>>> If it's ok with you then I might do that unit conversion proposal.
>>> Would it ok if the unit specifications were the same as to the
>>> programatic codes in ovms_metrics.h?
>>> (kWh,   WattHours , MetersPSS )
>>> I would probably add a command
>>> metric units <spec>
>>> to list all (matching) units and their associated Labels.
>>> //.ichael
>>> On Sat, 5 Nov 2022 at 18:48, Michael Balzer <dexter at expeedo.de> wrote:
>>>> Michael,
>>>> adding unit conversion support to the shell and Duktape commands is a
>>>> good idea.
>>>> Metrics are not meant to provide a user interface, they should be
>>>> defined to be efficient and non-redundant.
>>>> Btw, metrics names also shall not use upper case characters, and shall
>>>> only use "." as a separator.
>>>> Regards,
>>>> Michael
>>>> Am 05.11.22 um 11:22 schrieb Michael Geddes:
>>>> Hi all,
>>>> Some of the code I copied from Kona/Kia code had both kwh/100km and
>>>> km/kwh metrics in the code as 'Other'.
>>>> Adding the various power consumption Units is not particularly hard (I
>>>> will have a pull-request soon) - though the conversions between them all
>>>> required some thought!
>>>> ... but it also made me think these two metrics that are (with the
>>>> consumption units added) defined like this:
>>>> m_v_trip_consumption1 =
>>>> MyMetrics.InitFloat("xiq.v.trip.consumption.KWh/100km", 10, 0, kWHP100K);
>>>> m_v_trip_consumption2 = MyMetrics.InitFloat("
>>>> xiq.v.trip.consumption.km/kWh", 10, 0, kPkWH);
>>>> These are effectively the same metric but in different units!
>>>> I'm wondering if we would be better to have scripting and Duktape
>>>> support for converting metrics to different unit!  This might be also quite
>>>> useful for those strange countries that insist on using miles as a
>>>> measurement.
>>>> On top of the 'metric list' and 'metric set' we could add a 'metric
>>>> get' which gets a single value.. and add unit support for get/set.
>>>> I've also got a pull request that improves the precision of the km<->mi
>>>> conversions and factors it out.
>>>> //.ichael
>>>> OvmsDev mailing listOvmsDev at lists.openvehicles.comhttp://lists.openvehicles.com/mailman/listinfo/ovmsdev
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20221107/a5b4a4e2/attachment-0001.htm>
