[Ovmsdev] Crash and wifi problem
Wed May 4 16:59:35 HKT 2022
Most of your crashes are stack overflows.
You can currently only see the task causing this on the USB terminal, it
will be shown in the crash info.
Check if your sdkconfig has lower stack sizes than the suggested defaults:
OVMS.V3> diff support/sdkconfig.default.hw31 sdkconfig
Btw, I currently build my releases with
CONFIG_OVMS_SYS_COMMAND_STACK_SIZE=10240 due to the config restore issue.
Am 04.05.22 um 06:11 schrieb Tamás Kovács:
> I have many problem with my new OVMS (OVMS WIFI BLE BT cores=2
> rev=ESP32/3; MODEM SIM7600) Now i use the the following fw
> (3.3.002-31-g3604f462)
> The crash logs i attached.
> If i restart the network from my MAC with cable, is see (photo attached)
>   - Warning: cellulars: Cannot restart, as modem driver is not loaded
> and i get a following for the wi-f many timei:
>   - wifi: bcn_timeout, ap_probe_send_start
> Best wishes:
> Tamás Kovács
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20220504/5bd018f2/attachment.htm>
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20220504/5bd018f2/attachment.sig>
