[Ovmsdev] Repeated WDT crashes after upgrade to 3.3 with 4G
Jeff Anton antonov at hesiod.org
Mon Mar 7 05:38:23 HKT 2022
I flashed edge just now and it's working on my Roadster w/o GPS!
Firmware: 3.3.001-286-ga6e5b9ab/ota_1/main (build idf
v3.3.4-848-g1ff5e24b1 Mar 7 2022 00:04:15)
MODEM Status
Model: SIM7600
Network Registration: RegisteredRoaming
Provider: T-Mobile Hologram
Signal: -85 dBm
Mode:
State: NetMode
Mux: Status up
PPP: Connected on channel: #2
GPS: Not running
On 3/6/22 01:58, Michael Balzer wrote:
> I've found & fixed the bug: there was an endless loop in
> modem::IncomingMuxData() when the NMEA channel had not been created.
>> https://github.com/openvehicles/Open-Vehicle-Monitoring-System-3/commit/a6e5b9ab957ab72f56740d6fd4ba484fe1691f80
> Am 05.03.22 um 11:21 schrieb Michael Balzer:
>> I've now tried starting the NMEA channel without actually sending any
>> GPS init commands (also no +CGPS=0).
>> That inhibits the crashes, although apparently no NMEA sentences are
>> coming in. The only communication on MUX channel 1 (NMEA) are some
>> initial frames:
>> balzer at leela:~/ovms/v3> grep -A1 CHAN=1 minicom.log
>> V (26168) gsm-mux: ProcessFrame(CHAN=1, ADDR=07, CTRL=73, FCS=15, LEN=6)
>> I (26168) gsm-mux: Channel #1 is open
>> V (32568) gsm-mux: ProcessFrame(CHAN=1, ADDR=05, CTRL=ff, FCS=56, LEN=20)
>> V (32568) gsm-mux: ProcessFrame(CHAN=2, ADDR=09, CTRL=ff, FCS=d1, LEN=20)
>> V (32938) gsm-mux: ProcessFrame(CHAN=1, ADDR=05, CTRL=ff, FCS=b5, LEN=21)
>> V (32938) gsm-mux: ProcessFrame(CHAN=2, ADDR=09, CTRL=ff, FCS=32, LEN=21)
>> V (36948) gsm-mux: ProcessFrame(CHAN=1, ADDR=05, CTRL=ff, FCS=56, LEN=20)
>> V (36948) gsm-mux: ProcessFrame(CHAN=2, ADDR=09, CTRL=ff, FCS=d1, LEN=20)
>> V (38968) gsm-mux: ProcessFrame(CHAN=1, ADDR=05, CTRL=ff, FCS=b5, LEN=21)
>> V (38968) gsm-mux: ProcessFrame(CHAN=2, ADDR=09, CTRL=ff, FCS=32, LEN=21)
>> V (42638) gsm-mux: ProcessFrame(CHAN=1, ADDR=05, CTRL=ff, FCS=b5, LEN=21)
>> V (42638) gsm-mux: ProcessFrame(CHAN=3, ADDR=0d, CTRL=ff, FCS=f0, LEN=21)
>> V (44988) gsm-mux: ProcessFrame(CHAN=1, ADDR=05, CTRL=ff, FCS=b5, LEN=21)
>> V (44988) gsm-mux: ProcessFrame(CHAN=3, ADDR=0d, CTRL=ff, FCS=f0, LEN=21)
>> Unrelated to this issue, but possibly to the framing errors: I've
>> also removed the NMEA log filter from modem::StandardLineHandler()
>> and found after normal GPS startup, the NMEA sentences always come in
>> three times via three MUX channels – additionally to channel 1 on
>> channels 3 & 4:
>> V (130148) gsm-mux: ProcessFrame(CHAN=1, ADDR=05, CTRL=ff, FCS=bf,
>> LEN=78)
>> D (130148) gsm-nmea: Incoming RMC:
>> $GPRMC,095314.00,A,xxxx.139928,N,xxxx.391626,E,0.0,,050322,0.9,W,A*06
>> V (130158) gsm-mux: ProcessFrame(CHAN=3, ADDR=0d, CTRL=ff, FCS=fa,
>> LEN=78)
>> D (130158) cellular: mux-rx-line #3:
>> V (130158) gsm-mux: ProcessFrame(CHAN=4, ADDR=11, CTRL=ff, FCS=f7,
>> LEN=78)
>> D (130158) cellular: mux-rx-line #4:
>> V (130168) gsm-mux: ProcessFrame(CHAN=1, ADDR=05, CTRL=ff, FCS=b1,
>> LEN=82)
>> D (130168) gsm-nmea: Incoming GNS:
>> $GNGNS,095314.00,xxxx.139928,N,xxxx.391626,E,AAN,16,0.7,327.9,47.0,,,V*60
>> V (130178) gsm-mux: ProcessFrame(CHAN=3, ADDR=0d, CTRL=ff, FCS=f4,
>> LEN=82)
>> D (130178) cellular: mux-rx-line #3:
>> V (130178) gsm-mux: ProcessFrame(CHAN=4, ADDR=11, CTRL=ff, FCS=f9,
>> LEN=82)
>> D (130178) cellular: mux-rx-line #4:
>> I don't know if that's intended behaviour or can be changed, but I
>> suspect this to add unnecessary load to the serial communication.
>> Am 05.03.22 um 09:02 schrieb Michael Balzer:
>>> Another theory: I found Mark's comment in the SIM7600 driver NMEA
>>> startup:
>>>   // We need to do this a little differently from the standard, as
>>> SIM7600
>>>   // may start GPS on power up, and doesn't like us using CGPS=1,1 when
>>>   // it is already on. So workaround is to first CGPS=0.
>>> IOW, the SIM7600 may have GPS enabled by default, possibly also
>>> sending NMEA sentences, if not explicitly switched off.
>>> BTW, that also explains the difficulties in booting a 3.3 module
>>> from USB… :-/
>>> a) We don't switch off GPS if GPS is disabled.
>>> b) I just tried switching off GPS manually after a GPS-enabled
>>> startup, and the modem still continued to send NMEA sentences:
>>> OVMS# cellular cmd AT+CGPS=0
>>> MODEM command has been sent.
>>>>>> D (475190) gsm-nmea: Incoming RMC: $GPRMC,,V,,,,,,,,,,N*53
>>> V (475190) gsm-mux: ProcessFrame(CHAN=3, ADDR=0d, CTRL=ff, FCS=c1,
>>> LEN=31)
>>> V (475190) gsm-mux: ProcessFrame(CHAN=4, ADDR=11, CTRL=ff, FCS=cc,
>>> LEN=31)
>>> V (475190) gsm-mux: ProcessFrame(CHAN=1, ADDR=05, CTRL=ff, FCS=60,
>>> LEN=32)
>>> D (475190) gsm-nmea: Incoming GNS: $GNGNS,,,,,,NNN,,,,,,*1D
>>> V (475190) gsm-mux: ProcessFrame(CHAN=3, ADDR=0d, CTRL=ff, FCS=25,
>>> LEN=32)
>>> V (475190) gsm-mux: ProcessFrame(CHAN=4, ADDR=11, CTRL=ff, FCS=28,
>>> LEN=32)
>>> V (480180) gsm-mux: ProcessFrame(CHAN=1, ADDR=05, CTRL=ff, FCS=84,
>>> LEN=31)
>>> D (480190) gsm-nmea: Incoming RMC: $GPRMC,,V,,,,,,,,,,N*53
>>>>>> OVMS# cellular cmd AT+CGPSNMEA=0
>>> D (505190) gsm-nmea: Incoming RMC: $GPRMC,,V,,,,,,,,,,N*53
>>> V (505190) gsm-mux: ProcessFrame(CHAN=3, ADDR=0d, CTRL=ff, FCS=c1,
>>> LEN=31)
>>> V (505190) gsm-mux: ProcessFrame(CHAN=4, ADDR=11, CTRL=ff, FCS=cc,
>>> LEN=31)
>>> V (505190) gsm-mux: ProcessFrame(CHAN=1, ADDR=05, CTRL=ff, FCS=60,
>>> LEN=32)
>>> D (505190) gsm-nmea: Incoming GNS: $GNGNS,,,,,,NNN,,,,,,*1D
>>> V (505190) gsm-mux: ProcessFrame(CHAN=3, ADDR=0d, CTRL=ff, FCS=25,
>>> LEN=32)
>>> V (505190) gsm-mux: ProcessFrame(CHAN=4, ADDR=11, CTRL=ff, FCS=28,
>>> LEN=32)
>>> V (510180) gsm-mux: ProcessFrame(CHAN=1, ADDR=05, CTRL=ff, FCS=84,
>>> LEN=31)
>>> D (510190) gsm-nmea: Incoming RMC: $GPRMC,,V,,,,,,,,,,N*53
>>> So without us starting the NMEA subsystem, is it possible these
>>> transmissions are still there, filling up some MUX buffer?
>>> Am 05.03.22 um 08:33 schrieb Michael Balzer:
>>>> I've tried to reproduce this with my old 3.2 & hand soldered 3.3
>>>> dev module, with different vehicle modules and modem GPS disabled.
>>>> Results:
>>>> - the vehicle module is irrelevant
>>>> - 3.2 (SIM5360E) runs without issues (had this running over night)
>>>> - 3.3 (SIM7600G) consistently crashes by the TWDT within a couple
>>>> of minutes after modem init
>>>> This is caused by the modem task hogging core 0 as soon as the PPP
>>>> connection is up:
>>>> I (87161) cellular: Identified cellular modem: SIM7600/Experimental
>>>> support for SIMCOM SIM7600
>>>> D (87161) cellular: Remove old 'auto' modem driver
>>>> I (87161) cellular: Set modem driver to 'SIM7600'
>>>> I (87161) cellular: State: Enter PoweredOn state
>>>> OVMS# mo ta
>>>> Number of Tasks = 18        Stack:  Now   Max Total Heap 32-bit
>>>> SPIRAM C# PRI CPU% BPR/MH
>>>> 3FFAFB88    1 Blk esp_timer         436   708  4096 41648    644
>>>> 44544  0  22   0%  22/ 0
>>>> 3FFC2BD8    2 Blk OVMS DukTape      500  9252 12288 188      0
>>>> 524288  1   5   0%   5/ 0
>>>> 3FFC46B4    3 Blk eventTask         480  2032  4608 108      0
>>>> 0  0  20   0%  20/ 0
>>>> 3FFC6B38    4 Blk OVMS Events       484  3204  8192 80136      0
>>>> 79300  1   8   1%   8/ 0
>>>> 3FFC9C30    5 Blk OVMS CanRx        476  1996  4096 3240      0
>>>> 50556  0  23   0%  23/ 0
>>>> 3FFCAA2C    6 Blk ipc0              424   504  1024 7804
>>>> 0      0  0  24   0%  24/ 0
>>>> 3FFCB030    7 Blk ipc1              428   524  1024 120      0
>>>> 0  1  24   0%  24/ 0
>>>> *3FFCCEA0   10 Rdy IDLE0             412   508 1024       0
>>>> 0      0  0   0  98%   0/ 0*
>>>> 3FFCD438   11 Rdy IDLE1             404   580  1024 0      0
>>>> 0  1   0  97%   0/ 0
>>>> 3FFCE1D0   12 Blk Tmr Svc           380  1404  3072 124      0
>>>> 0  0  20   0%  20/ 0
>>>> 3FFCC308   17 Blk tiT               532  2036  3072 924      0
>>>> 1040  1  18   0%  18/ 0
>>>> *3FFD34E0   20 Blk OVMS Cellular     652  2396  4096 5848
>>>> 0      0  0  20   0%  20/ 0*
>>>> 3FFD656C   21 Blk wifi              472  2840  3584 38080      0
>>>> 5632  0  22   1%  22/ 1
>>>> 3FFE3244   22 Blk OVMS Vehicle      496   496  8192 0      0
>>>> 0  1  10   0%  10/ 0
>>>> 3FFE7BD4   23 Rdy OVMS Console      848  2688 10240 356  12100
>>>> 15960  1   5   1%   5/ 1
>>>> 3FFEA5A0   24 Blk OVMS NetMan       908  2684 10240 832      0
>>>> 2152  1   5   0%   5/ 0
>>>> 3FFEBBDC   25 Blk mdns              504  2200  4096 104      0
>>>> 4  0   1   0%   1/ 0
>>>> 3FFEFDC8   26 Blk OVMS FileLog      580  1524  3072 36      0
>>>> 0  1   2   0%   2/ 0
>>>> I (118171) cellular: Network Registration status: RegisteredRoaming
>>>> D (118181) cellular: mux-rx-line #3: +CCLK: "22/03/05,08:22:23+04"
>>>> D (118181) cellular: mux-rx-line #3: +CSQ: 24,0
>>>> D (118181) cellular: mux-rx-line #3: +COPS: 0,0,"vodafone.de
>>>> Hologram",0
>>>> I (118181) cellular: Network Provider is: vodafone.de Hologram
>>>> D (119151) cellular: State transition NetWait => NetStart
>>>> I (119151) cellular: State: Enter NetStart state
>>>> D (120151) cellular: Netstart
>>>> AT+CGDCONT=1,"IP","hologram";+CGDATA="PPP",1
>>>> V (120191) gsm-mux: ProcessFrame(CHAN=0, ADDR=01, CTRL=ef, FCS=79,
>>>> LEN=11)
>>>> V (120201) gsm-mux: ProcessFrame(CHAN=2, ADDR=09, CTRL=ff, FCS=fb,
>>>> LEN=24)
>>>> D (120201) cellular: mux-rx-line #2: CONNECT 115200
>>>> *I (120201) cellular: PPP Connection is ready to start*
>>>> V (120751) gsm-mux: ProcessFrame(CHAN=1, ADDR=05, CTRL=ff, FCS=56,
>>>> LEN=20)
>>>> OVMS# mo ta
>>>> 44544  0  22   0%  22/ 0
>>>> 3FFC2BD8    2 Blk OVMS DukTape      500  9252 12288 284      0
>>>> 524308  1   5   1%   5/ 0
>>>> 0  0  20   0%  20/ 0
>>>> 3FFC6B38    4 Blk OVMS Events       484  3204  8192 80280      0
>>>> 79680  1   8   1%   8/ 0
>>>> 50556  0  23   0%  23/ 0
>>>> 0      0  0  24   0%  24/ 0
>>>> 0  1  24   0%  24/ 0
>>>> 0      0  0   0  79%   0/ 0*
>>>> 0  1   0  95%   0/ 0
>>>> 3FFCE1D0   12 Blk Tmr Svc           380  1452  3072 124      0
>>>> 0  0  20   0%  20/ 0
>>>> 1044  1  18   0%  18/ 0
>>>> *3FFD34E0   20 Rdy OVMS Cellular     876  2716  4096 6116      0
>>>> 10440  0  20  19%  20/ 0*
>>>> 5632  0  22   1%  22/ 1
>>>> 0  1  10   0%  10/ 0
>>>> 15960  1   5   3%   5/ 1
>>>> 2152  1   5   0%   5/ 0
>>>> 4  0   1   0%   1/ 0
>>>> 0  1   2   0%   2/ 0
>>>> I (122161) housekeeping: System considered stable (RAM:
>>>> 8b=64256-64760 32b=184 SPI=3362168-3374964)
>>>> D (122231) ovms-duktape: Duktape: Compacting DukTape memory done in
>>>> 60 ms
>>>> I (123151) ovms-server-v2: Send MP-0
>>>> h1,0,*-OVM-DebugCrash,0,2592000,3.3.001-285-g601f2a70/factory/edge
>>>> (build idf v3.3.4-848-g1ff5e24b1b Feb 22 2022
>>>> 20:57:41),1,EarlyCrash,12,12,1,1,abort(),0,,0x4008ddca 0x4008e06
>>>> 5 0x400e88b8 0x40084176 ,6,Task watchdog,,,0,IDLE0,OVMS WIFI BLE BT
>>>> cores=2 rev=ESP32/3; MODEM SIM7600
>>>> I (123361) ovms-server-v2: Incoming Msg: MP-0 h1
>>>> OVMS# mo ta
>>>> 44544  0  22   0%  22/ 0
>>>> 524288  1   5   0%   5/ 0
>>>> 0  0  20   0%  20/ 0
>>>> 79300  1   8   1%   8/ 0
>>>> 50556  0  23   0%  23/ 0
>>>> 0      0  0  24   0%  24/ 0
>>>> 0  1  24   0%  24/ 0
>>>> 0      0  0   0   0%   0/ 0*
>>>> 0  1   0  95%   0/ 0
>>>> 0  0  20   0%  20/ 0
>>>> 1044  1  18   0%  18/ 0
>>>> 10440  0  20  98%  20/ 0*
>>>> 5632  0  22   1%  22/ 1
>>>> 0  1  10   0%  10/ 0
>>>> 3FFE7BD4   23 Rdy OVMS Console      880  2688 10240 356  12100
>>>> 15960  1   5   4%   5/ 1
>>>> 2152  1   5   0%   5/ 0
>>>> 4  0   1   0%   1/ 0
>>>> 0  1   2   0%   2/ 0
>>>> OVMS# E (181151) task_wdt: Task watchdog got triggered. The
>>>> following tasks did not reset the watchdog in time:
>>>> E (181151) task_wdt:  - IDLE0 (CPU 0)
>>>> E (181151) task_wdt: Tasks currently running:
>>>> E (181151) task_wdt: CPU 0: Tmr Svc
>>>> E (181151) task_wdt: CPU 1: IDLE1
>>>> E (181151) task_wdt: Aborting.
>>>> No other log messages.
>>>> Am 04.03.22 um 17:08 schrieb Jeff Anton:
>>>>> I woke from sleep thinking "interrupt storm."
>>>>> Craig's observation makes me wonder... Does the gps system produce
>>>>> interrupts which are not handled properly when gps is turned off.
>>>>> Unhandled interrupts might get constantly repeated causing the
>>>>> IDLE tasks to starve?
>>>> I think that may be the case. Maybe the NMEA MUX channel gets
>>>> continuous input from the 7600 when GPS is disabled?
>>>> Regards,
>>>> Michael
>>>> Am 04.03.22 um 23:15 schrieb Craig Leres:
>>>>> One more data point; I turned GPS off on my dev module (v3.1 board
>>>>> with a sim7600A running 3.3.001-285-g601f2a70-dirty) and it
>>>>> started crashing.
>>>>> Has anyone outside the US tried this?
>>>>>         Craig
>>>>> ice 12 % ./backtrace.sh 0x400891af:0x3ffb0690
>>>>> 0x40089449:0x3ffb06b0 0x400e8950:0x3ffb06d0 0x40083dde:0x3ffb06f0
>>>>> + xtensa-esp32-elf-addr2line -e build/ovms3.elf
>>>>> 0x400891af:0x3ffb0690 0x40089449:0x3ffb06b0 0x400e8950:0x3ffb06d0
>>>>> /home/ice/u0/leres/esp/openvehicles-xtensa-esp32-elf/components/esp32/panic.c:736
>>>>> /home/ice/u0/leres/esp/openvehicles-xtensa-esp32-elf/components/esp32/task_wdt.c:274
>>>>> /home/ice/u0/leres/esp/openvehicles-xtensa-esp32-elf/components/freertos/xtensa_vectors.S:1154
>>>>> # esp/openvehicles-xtensa-esp32-elf/components/esp32/panic.c
>>>>>     733
>>>>>     734 void _esp_error_check_failed_without_abort(esp_err_t rc,
>>>>> const char *file, int line, const char *function, const char
>>>>> *expression)
>>>>>     735 {
>>>>>     736
>>>>> esp_error_check_failed_print("ESP_ERROR_CHECK_WITHOUT_ABORT", rc,
>>>>> file, line, function, expression);
>>>>>     737 }
>>>>> OvmsDev mailing list
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20220306/31c35e1e/attachment-0001.htm>
