[Ovmsdev] Repeated WDT crashes after upgrade to 3.3 with 4G
Craig Leres leres at xse.com
Sat Mar 5 06:15:49 HKT 2022
One more data point; I turned GPS off on my dev module (v3.1 board with
a sim7600A running 3.3.001-285-g601f2a70-dirty) and it started crashing.
Has anyone outside the US tried this?
		Craig
ice 12 % ./backtrace.sh 0x400891af:0x3ffb0690 0x40089449:0x3ffb06b0
0x400e8950:0x3ffb06d0 0x40083dde:0x3ffb06f0
+ xtensa-esp32-elf-addr2line -e build/ovms3.elf 0x400891af:0x3ffb0690
0x40089449:0x3ffb06b0 0x400e8950:0x3ffb06d0 0x40083dde:0x3ffb06f0
/home/ice/u0/leres/esp/openvehicles-xtensa-esp32-elf/components/esp32/panic.c:736
/home/ice/u0/leres/esp/openvehicles-xtensa-esp32-elf/components/esp32/task_wdt.c:274
/home/ice/u0/leres/esp/openvehicles-xtensa-esp32-elf/components/freertos/xtensa_vectors.S:1154
# esp/openvehicles-xtensa-esp32-elf/components/esp32/panic.c
     733
     734 void _esp_error_check_failed_without_abort(esp_err_t rc, const
char *file, int line, const char *function, const char *expression)
     735 {
     736
esp_error_check_failed_print("ESP_ERROR_CHECK_WITHOUT_ABORT", rc, file,
line, function, expression);
     737 }
