[Ovmsdev] Repeated WDT crashes after upgrade to 3.3 with 4G
Jeff Anton
antonov at hesiod.org
Sat Mar 5 02:34:45 HKT 2022
On 3/3/22 21:55, Mark Webb-Johnson wrote:
> Steve, Jeff,
> I have noticed you running '3.3.001-285’. Can you try with the
> standard ‘3.3.001’ that was released a while ago? You can get it from:
> http://api.openvehicles.com/firmware/ota/v3.3/main/ovms3.bin
> or
> http://api.openvehicles.com/firmware/ota/v3.2/edge/3.3.001.ovms3.bin
> I wonder if something is broken in the latest edge?
> P.S. I think that in general we may be confusing people here. The
> firmware/ota/<X> directory is for those version <X> mainboards. So
> /v3.1/, /v3.2/ or /v3.3/. The idea is that we can then have different
> build settings (sdkconfig) for different base hardware (in particular
> esp32 revision) and make improvements. At the moment v3.1 and v3.2 are
> symlinked together (on api.openvehicles.com
> <http://api.openvehicles.com>) as ESP32 is the same.
> Regards, Mark
So I've tried every combination.... GPS off always crashes with all
versions I've tried.
Version/Build
w/o GPS
w/ GPS
3.3.001-285-g601f2a70/ota_0/main (build idf v3.3.4-848-g1ff5e24b1) (edge)
crash
PPP comes up
3.3.001/ota_1/main (build idf v3.3.4-848-g1ff5e24b1) (above link
v3.3/main/ovms3.bin)
crash/slow to connect/crash
PPP comes up
factory/main/3.3.001-33-g58d01654 crash
PPP comes up
Jeff
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20220304/97df5da2/attachment.htm>
