[Ovmsdev] Repeated WDT crashes after upgrade to 3.3 with 4G
Jeff Anton
antonov at hesiod.org
Sat Mar 5 00:08:48 HKT 2022
I woke from sleep thinking "interrupt storm."
Craig's observation makes me wonder... Does the gps system produce
interrupts which are not handled properly when gps is turned off.
Unhandled interrupts might get constantly repeated causing the IDLE
tasks to starve?
Jeff
On 3/3/22 23:30, Craig Leres wrote:
> On 3/3/22 23:21, Mark Webb-Johnson wrote:
>> Well, that’s a hypothesis…
>> Can you try a few more times, with gps on and off, to see if it is
>> repeatable?
> I've seen at least 4 crashes, the most recently 2 with my FreeBSD
> built ovms-3.3.001-285-g601f2a70-dirty, vehicle set to C6 and the only
> difference from what I was using is GPS+GPS-time off.
> Looks like a watchdog timeout (last two crashes were the same).
> Craig
> ice 133 % ./backtrace.sh 0x400891af 0x40089449 0x400e8950 0x40083dde
> + xtensa-esp32-elf-addr2line -e build/ovms3.elf 0x400891af 0x40089449
> /home/ice/u0/leres/esp/openvehicles-xtensa-esp32-elf/components/esp32/panic.c:736
> /home/ice/u0/leres/esp/openvehicles-xtensa-esp32-elf/components/esp32/task_wdt.c:274
> /home/ice/u0/leres/esp/openvehicles-xtensa-esp32-elf/components/freertos/xtensa_vectors.S:1154
