[Ovmsdev] Repeated WDT crashes after upgrade to 3.3 with 4G
Craig Leres
leres at xse.com
Fri Mar 4 15:30:53 HKT 2022
On 3/3/22 23:21, Mark Webb-Johnson wrote:
> Well, that’s a hypothesis…
> Can you try a few more times, with gps on and off, to see if it is repeatable?
I've seen at least 4 crashes, the most recently 2 with my FreeBSD built
ovms-3.3.001-285-g601f2a70-dirty, vehicle set to C6 and the only
difference from what I was using is GPS+GPS-time off.
Looks like a watchdog timeout (last two crashes were the same).
Craig
ice 133 % ./backtrace.sh 0x400891af 0x40089449 0x400e8950 0x40083dde
+ xtensa-esp32-elf-addr2line -e build/ovms3.elf 0x400891af 0x40089449
/home/ice/u0/leres/esp/openvehicles-xtensa-esp32-elf/components/esp32/panic.c:736
/home/ice/u0/leres/esp/openvehicles-xtensa-esp32-elf/components/esp32/task_wdt.c:274
/home/ice/u0/leres/esp/openvehicles-xtensa-esp32-elf/components/freertos/xtensa_vectors.S:1154
