[Ovmsdev] MCP2515 driver bug?
    Greg D
    gregd2350 at gmail.com
    Tue Jan  4 10:46:08 HKT 2022
Hi Mark,
Trying this again...  (got a 554 blocked reply the first time).  apologize
if it's a duplicate.
Will this fix the bus hangs we have with the HUD devices?  Ref: "Can buses
stop after some time" email thread from 5/28/2019...  As I wrote at the
time, a 100% way to reproduce the hang was to have a HUD device running,
*then* start the OBD2ECU task.  I haven't used my HUD in some time, so I
don't know if this was fixed since then.  If not, that was a very quick and
easy way to reproduce the issue.
Happy New Year!
Greg
On Mon, Jan 3, 2022 at 5:10 PM Mark Webb-Johnson <mark at webb-johnson.net>
wrote:
> An update on this.
> Working with another developer, we have made some changes in a ’spimaster’
> branch:
>    1. Stop using spi_nodma fork of ESP’s standard spi code, and switch
>    back to use the standard ESP IDF spi master.
>    2. To support >3 devices (which ESP IDF spi master doesn’t due to
>    hardware limitations of CS line and 3x DMA channels), change to use
>    software CS line for the MAX7317 driver (the MCP2515 continue to use
>    hardware CS).
>    3. Confirm the changes to our MCP2515 driver related to keeping track
>    of the last buffer read, to solve the out-of-order issue.
>    4. Confirm the fix for another related issue where we don’t block
>    (delay) if the can tx queue is full.
> These seem better now, and I am able to establish a CAN IP connection over
> MCP2515. Frames come in order, and we are seeing performance around 700
> frames/second - which should be adequate for our needs.
> I’ll do some more testing over the next few days, and if no issues found
> merge back to master.
> On 7 Jun 2021, at 12:16 AM, Michael Balzer <dexter at expeedo.de> wrote:
> Signed PGP part
> Mark,
> I've just found a spot-on post on this issue:
> https://www.microchip.com/forums/tm.aspx?m=620741
> Tom suggests implementing a state machine to reproduce the receive order.
> His analysis & solution looks sound to me.
> Am 06.06.21 um 14:50 schrieb Mark Webb-Johnson:
> I spent quite a bit of time on this. With my standard test packet of 11
> CAN frames expected, and the standard driver, I get perhaps 4 or 5 of them
> (about half are lost, and some are out of order).
> I made the suggested change to move the MyCan.IncomingFrame() call out of
> the ‘can’ object (when frameReceived is true) to within the
> mcp2515 AsynchronousInterruptHandler itself. That allows the handler to
> receive more than one frame per call and is a very simple change. Once that
> is done, we can at least now try to tune it.
> So I then modified the code of mcp2515 AsynchronousInterruptHandler to
> loop so long as the interrupt flag says either buffer #0 or #1 has a frame.
> The result looks something like this:
> D (63192) mcp2515: AsynchronousInterruptHandler instat=01 errflag=00
> txb0ctrl=00
> D (63192) mcp2515: AsynchronousInterruptHandler rx frame from buffer #0
> (ID 0x110 B1=54)
> D (63192) mcp2515: AsynchronousInterruptHandler instat=23 errflag=40
> txb0ctrl=00
> (ID 0x110 B1=40)
> D (63192) mcp2515: AsynchronousInterruptHandler rx frame from buffer #1
> (ID 0x110 B1=45)
> D (63192) mcp2515: AsynchronousInterruptHandler Clear RX buffer #0
> overflow flag
> D (63192) mcp2515: AsynchronousInterruptHandler instat=23 errflag=00
> txb0ctrl=00
> (ID 0x110 B1=24)
> (ID 0x110 B1=34)
> D (63192) mcp2515: AsynchronousInterruptHandler instat=20 errflag=00
> txb0ctrl=00
> The actual frames on the bus are (B1 values) 54, 45, 40, 0a, 7a, d5, 0c,
> 14, 1c, 24, 2c, and 34. Looking at the above debug output, we get:
>    - Interrupt flags show buffer #0 has a frame. It is B1=54. Good.
>    - Interrupt flags show buffers #0 and #1 both have frames. Buffer #0
>    has B1=40 and buffer #1 has B1=45.
>    - Etc etc
> That is not good. What must have happened is that the first B1=54 frame
> arrived, got put in buffer #0, and interrupt was raised. We checked the
> interrupt flags, found buffer #0 had something, and read the frame ok. All
> is good. But what is happening now is that between the time we checked the
> interrupt flags and the time we finished reading the 13 bytes from buffer
> #0, a second frame arrived and was put in buffer #1. Then a third frame
> arrives and is put in buffer #0. We loop back to check the interrupt flags
> and find both buffers have frames ready. So we ready buffer #0 to get the
> third frame, then buffer #1 to get the second frame. We are out of sequence.
> By removing the ESP_LOGD statements, I can improve performance enough to
> get 10 out of the 11 frames, but still sometimes frames are swapped in
> order.
> By over-clocking the MCP2515 SPI bus (supposed to be 10MHz, but I push it
> to 15MHz), I can get all 11 frames, but two are out of order.
> I suppose I can minimise the chance of the out-of-order issue by repeating
> the call to read interrupt flags after processing buffer #0 but before
> checking for buffer #1. That would at least reduce the time window to as
> small as possible, but would be another SPI call and is too slow. Doing
> that brings us back to losing frames.
> Another approach may relate to our current use of the READ command to read
> 5 status registers (interrupt flags, error flags, two skipped, then
> transmit buffer #0 flags). There are two specific commands ‘read status’
> (which gets the rx and tx buffer status flags in one byte), and ‘rx status’
> (which gets just the receive buffer status and some info on the frames
> received, again in one byte). I think those are more designed for what we
> are trying to do. I can try to optimise the read loop at the start of the
> AsynchronousInterruptHandler to use one of those - they are 2 SPI bytes vs
> 7 for what we are doing at the moment (so more than three times as fast).
> I think it will also be worthwhile having a look at some other open source
> mcp2515 drivers to see how other people are doing it.
> On 4 Jun 2021, at 3:02 PM, Mark Webb-Johnson <mark at webb-johnson.net>
> wrote:
> Signed PGP part
> The handler can only return one frame. As it is, if both buffers #0 and #1
> have a frame, it returns #0. I am not sure if it gets called again (seems
> to depend on the interrupt gpio status).
> // Read the interrupt pin status and if it's still active (low), require
> another interrupt handling iteration
>   return !gpio_get_level((gpio_num_t)m_intpin);
> Maybe a quick solution is to just return true, immediately
> after *frameReceived=true, if intflag=0x01 and (intstat & CANINTF_RX1IF)?
> That would dispatch the incoming frame, then call back for more (from the
> loop in the can object).
> I am not sure in general why AsynchronousInterruptHandler uses a bool
> frameReceived flag, and doesn’t just simply dispatch the frame immediately
> to the can object? That would simplify things and allow
> the AsynchronousInterruptHandler to handle receiving both frames in the
> same call. Given that MCP2515 is the only driver
> using AsynchronousInterruptHandler, that would be an easy fix.
> On 4 Jun 2021, at 2:29 PM, Michael Balzer <dexter at expeedo.de> wrote:
> Signed PGP part
> Mark,
> the handler is meant to read both buffers sequentially, and on a quick
> glance I don't see why it wouldn't. But it can't hurt if you do an audit of
> the code.
> I remember having had that out-of-order discussion when handling both RX
> buffers before here, but don't remember the outcome. Too bad the list
> archives cannot be searched.
> I think it was the MCP not doing overflows from RX buffer 1 to 0. I.e. if
> buffer 1 still has a frame on arrival, the new frame will be lost. That
> means losing a frame if the handler cannot react fast enough, but receiving
> out of order would be worse.
> Am 04.06.21 um 04:16 schrieb Mark Webb-Johnson:
> Michael,
> Good suggestion on the timing. I think it best to use the same timings as
> the Arduino library, and have committed that change. No vehicle modules
> currently use 1Mbps on MCP2515 anyway. Unfortunately, it didn’t resolve my
> problem.
> Looking at the error flags I see:
> Error flag:  0x23401c01
> intstat 0x23
>         ERRIF Error Interrupt pending
>         RX0IF Rx buffer 0 full interrupt
>         RX1IF Rx buffer 1 full interrupt
> errflag 0x40
>         RX0OVR Rx buffer 0 overflow
> intflag 0x1c01
>         0x01 Implied from Rx buffer 0 full
>         0x1c = 0001 1100
>         Means RXB0 overflow. No data lost in this case (it went into RXB1)
>         Means (errflag & EFLG_RX01OVR), clear RX buffer overflow flags
>         Means (intstat & (CANINTF_MERRF | CANINTF_WAKIF | CANINTF_ERRIF)),
> clear error & wakeup interrupts
> So we have CAN frames in BOTH rx buffers #0 and #1. Looking at our driver
> code (mcp2515::AsynchronousInterruptHandler), it seems in that case we only
> read from buffer #0. From the flow I can see, we are going to lose that
> second frame. We’re not really handling the issue of two frames being in
> the buffers when the interrupt handler is called.
> As the architecture of mcp2515::AsynchronousInterruptHandler can only
> receive one frame, it is not so simple to fix. We could simply read and
> return the frame in buffer #0, requesting to be called again (return true),
> but another frame may arrive (into buffer #0) before we get called again,
> and that is going to result in out-of-order frames.
> I’ll work on improving the handling of this case.
> On 3 Jun 2021, at 3:07 PM, Michael Balzer <dexter at expeedo.de> wrote:
> Signed PGP part
> Mark,
> I'd give the bit timing a try first, the MCP2515 seems to be very
> sensitive for this. I've even had some trouble finding a working
> configuration for the 50 kbit timing I've added a couple weeks ago.
> We currently use 00 / D0 / 82 which is also the result of the old Intrepid
> timing calculator. That's a propagation segment of 1 Tq and 3 Tq per phase,
> resulting in samling between 50% - 62.5%.
> The Arduino MCP CAN lib by Cory Fowler also had this previously, but then
> changed in…
> https://github.com/coryjfowler/MCP_CAN_lib/commit/ece730cf697fef1cbe8a90111694868168d41000
> …to 00 / CA / 81, which is a propagation segment of 3 Tq and 2 Tq per
> phase, shifting the sampling window to 62.5 - 75%.
> Our current configuration scheme for the internal SJA1000 compatible CAN
> seems to sample at 62.5 - 75% as well, so that would also match.
> Am 03.06.21 um 07:36 schrieb Mark Webb-Johnson:
> I’m working on an implementation of IP stack over CAN for the Tesla
> Roadster. IP frames are encoded as a length followed by a sequence of CAN
> frames, all on the same ID. This runs over a 1MHz bus, so presumably the
> traffic volume could be high at times.
> I was having problems with this running on CAN2, so tried CAN1 and it
> worked perfectly. Here are some simple dumps of a single PING packet (and
> single PING response packet):
> ID #111 is used to transmit an IP packet, and ID #110 is used to receive
> an IP packet. The special empty data frame is an acknowledgment.
> Using latest master branch code (3.2.016-196-g0aad1a9f/ota_1/edge (build
> idf v3.3.4-848-g1ff5e24b1 Jun  2 2021 09:28:58)).
> So, first let’s test with traffic on CAN1 (active, 1Mbps), and listening
> on CAN2 (listen, 1Mbps):
> TCPDUMP:
> 05:57:55.980291 IP (tos 0x0, ttl 64, id 43101, offset 0, flags [DF], proto
> ICMP (1), length 84)
>     10.10.99.3 > 10.10.99.2: ICMP echo request, id 23372, seq 1, length 64
> 0x0000:  4500 0054 a85d 4000 4001 b832 0a0a 6303  E..T.]@. at ..2..c.
> 0x0010:  0a0a 6302 0800 7df8 5b4c 0001 5361 b860  ..c...}.[L..Sa.`
> 0x0020:  19f5 0e00 0809 0a0b 0c0d 0e0f 1011 1213  ................
> 0x0030:  1415 1617 1819 1a1b 1c1d 1e1f 2021 2223  .............!"#
> 0x0040:  2425 2627 2829 2a2b 2c2d 2e2f 3031 3233  $%&'()*+,-./0123
> 0x0050:  3435 3637                                4567
> 05:57:56.436190 IP (tos 0x0, ttl 64, id 14937, offset 0, flags [none],
> proto ICMP (1), length 84)
>     10.10.99.2 > 10.10.99.3: ICMP echo reply, id 23372, seq 1, length 64
> 0x0000:  4500 0054 3a59 0000 4001 6637 0a0a 6302  E..T:Y.. at .f7..c.
> 0x0010:  0a0a 6303 0000 85f8 5b4c 0001 5361 b860  ..c.....[L..Sa.`
> Traffic (as shown on PC the other end of the can log tcp connection):
> tx: #111 54 00
> tx: #111 45 00 00 54 a8 5d 40 00
> tx: #111 40 01 b8 32 0a 0a 63 03
> tx: #111 0a 0a 63 02 08 00 7d f8
> tx: #111 5b 4c 00 01 53 61 b8 60
> tx: #111 19 f5 0e 00 08 09 0a 0b
> tx: #111 0c 0d 0e 0f 10 11 12 13
> tx: #111 14 15 16 17 18 19 1a 1b
> tx: #111 1c 1d 1e 1f 20 21 22 23
> tx: #111 24 25 26 27 28 29 2a 2b
> tx: #111 2c 2d 2e 2f 30 31 32 33
> tx: #111 34 35 36 37
> rx: #110
> rx: #110 54 00
> rx: #110 45 00 00 54 3a 59 00 00
> rx: #110 40 01 66 37 0a 0a 63 02
> rx: #110 0a 0a 63 03 00 00 85 f8
> rx: #110 5b 4c 00 01 53 61 b8 60
> rx: #110 19 f5 0e 00 08 09 0a 0b
> rx: #110 0c 0d 0e 0f 10 11 12 13
> rx: #110 14 15 16 17 18 19 1a 1b
> rx: #110 1c 1d 1e 1f 20 21 22 23
> rx: #110 24 25 26 27 28 29 2a 2b
> rx: #110 2c 2d 2e 2f 30 31 32 33
> rx: #110 34 35 36 37
> CAN1 active:
> 1T11 111 54 00
> 1R11 110
> 1CER TX_Queue T11 111 40 01 b8 32 0a 0a 63 03
> 1T11 111 45 00 00 54 a8 5d 40 00
> 1T11 111 40 01 b8 32 0a 0a 63 03
> 1CER TX_Queue T11 111 5b 4c 00 01 53 61 b8 60
> 1T11 111 0a 0a 63 02 08 00 7d f8
> 1T11 111 5b 4c 00 01 53 61 b8 60
> 1CER TX_Queue T11 111 0c 0d 0e 0f 10 11 12 13
> 1T11 111 19 f5 0e 00 08 09 0a 0b
> 1T11 111 0c 0d 0e 0f 10 11 12 13
> 1CER TX_Queue T11 111 1c 1d 1e 1f 20 21 22 23
> 1T11 111 14 15 16 17 18 19 1a 1b
> 1T11 111 1c 1d 1e 1f 20 21 22 23
> 1CER TX_Queue T11 111 2c 2d 2e 2f 30 31 32 33
> 1T11 111 24 25 26 27 28 29 2a 2b
> 1T11 111 2c 2d 2e 2f 30 31 32 33
> 1T11 111 34 35 36 37
> 1R11 110 54 00
> 1R11 110 45 00 00 54 3a 59 00 00
> 1R11 110 40 01 66 37 0a 0a 63 02
> 1R11 110 0a 0a 63 03 00 00 85 f8
> 1R11 110 5b 4c 00 01 53 61 b8 60
> 1R11 110 19 f5 0e 00 08 09 0a 0b
> 1R11 110 0c 0d 0e 0f 10 11 12 13
> 1R11 110 14 15 16 17 18 19 1a 1b
> 1R11 110 1c 1d 1e 1f 20 21 22 23
> 1R11 110 24 25 26 27 28 29 2a 2b
> 1R11 110 2c 2d 2e 2f 30 31 32 33
> 1R11 110 34 35 36 37
> CAN2 listen:
> 2R11 111 54 00
> 2R11 110
> 2R11 111 45 00 00 54 a8 5d 40 00
> 2R11 111 40 01 b8 32 0a 0a 63 03
> 2R11 111 0a 0a 63 02 08 00 7d f8
> 2R11 111 5b 4c 00 01 53 61 b8 60
> 2R11 111 19 f5 0e 00 08 09 0a 0b
> 2R11 111 0c 0d 0e 0f 10 11 12 13
> 2R11 111 14 15 16 17 18 19 1a 1b
> 2R11 111 1c 1d 1e 1f 20 21 22 23
> 2R11 111 24 25 26 27 28 29 2a 2b
> 2R11 111 2c 2d 2e 2f 30 31 32 33
> 2R11 111 34 35 36 37
> 2R11 110 54 00
> 2CER Error intr=10 rxpkt=14 txpkt=0 errflags=0x23401c01 rxerr=0 txerr=0
> rxinval=0 rxovr=0 txovr=0 txdelay=0 txfail=0 wdgreset=0 errreset=0
> 2R11 110 40 01 66 37 0a 0a 63 02
> 2R11 110 19 f5 0e 00 08 09 0a 0b
> 2R11 110 34 35 36 37
> 2R11 110 45 00 00 54 3a 59 00 00
> Conclusion is that the CAN1 traffic looks fine, and the PING packet gets a
> good reply. All successful. But the CAN2 listen is missing a few packets
> and the last packet is out of order.
> Now, let’s test with traffic on CAN2 (active, 1Mbps), and listening on
> CAN1 (listen, 1Mbps):
> TCPDUMP:
> 06:00:33.004060 IP (tos 0x0, ttl 64, id 58240, offset 0, flags [DF], proto
>     10.10.99.3 > 10.10.99.2: ICMP echo request, id 23393, seq 1, length 64
> 0x0000:  4500 0054 e380 4000 4001 7d0f 0a0a 6303  E..T.. at .@.}...c.
> 0x0010:  0a0a 6302 0800 7cc8 5b61 0001 f161 b860  ..c...|.[a...a.`
> 0x0020:  8b0f 0000 0809 0a0b 0c0d 0e0f 1011 1213  ................
> tx: #111 54 00
> tx: #111 45 00 00 54 e3 80 40 00
> tx: #111 40 01 7d 0f 0a 0a 63 03
> tx: #111 0a 0a 63 02 08 00 7c c8
> tx: #111 5b 61 00 01 f1 61 b8 60
> tx: #111 8b 0f 00 00 08 09 0a 0b
> rx: #110
> rx: #110 54 00
> rx: #110 45 00 00 54 3a 5a 00 00
> rx: #110 0a 0a 63 03 00 00 84 c8
> rx: #110 8b 0f 00 00 08 09 0a 0b
> rx: #110 40 01 66 36 0a 0a 63 02
> CAN2 active:
> 2T11 111 54 00
> 2R11 110
> 2CER TX_Queue T11 111 40 01 7d 0f 0a 0a 63 03
> 2T11 111 45 00 00 54 e3 80 40 00
> 2T11 111 40 01 7d 0f 0a 0a 63 03
> 2CER TX_Queue T11 111 5b 61 00 01 f1 61 b8 60
> 2T11 111 0a 0a 63 02 08 00 7c c8
> 2T11 111 5b 61 00 01 f1 61 b8 60
> 2CER TX_Queue T11 111 0c 0d 0e 0f 10 11 12 13
> 2T11 111 8b 0f 00 00 08 09 0a 0b
> 2T11 111 0c 0d 0e 0f 10 11 12 13
> 2CER TX_Queue T11 111 1c 1d 1e 1f 20 21 22 23
> 2T11 111 14 15 16 17 18 19 1a 1b
> 2T11 111 1c 1d 1e 1f 20 21 22 23
> 2CER TX_Queue T11 111 2c 2d 2e 2f 30 31 32 33
> 2T11 111 24 25 26 27 28 29 2a 2b
> 2T11 111 2c 2d 2e 2f 30 31 32 33
> 2T11 111 34 35 36 37
> 2R11 110 54 00
> 2R11 110 45 00 00 54 3a 5a 00 00
> 2CER Error intr=15 rxpkt=3 txpkt=12 errflags=0x23401c01 rxerr=0 txerr=0
> rxinval=0 rxovr=0 txovr=0 txdelay=5 txfail=0 wdgreset=0 errreset=0
> 2R11 110 0a 0a 63 03 00 00 84 c8
> 2R11 110 8b 0f 00 00 08 09 0a 0b
> 2R11 110 40 01 66 36 0a 0a 63 02
> CAN1 listen:
> 1R11 111 54 00
> 1R11 110
> 1R11 111 45 00 00 54 e3 80 40 00
> 1R11 111 40 01 7d 0f 0a 0a 63 03
> 1R11 111 0a 0a 63 02 08 00 7c c8
> 1R11 111 5b 61 00 01 f1 61 b8 60
> 1R11 111 8b 0f 00 00 08 09 0a 0b
> 1R11 111 0c 0d 0e 0f 10 11 12 13
> 1R11 111 14 15 16 17 18 19 1a 1b
> 1R11 111 1c 1d 1e 1f 20 21 22 23
> 1R11 111 24 25 26 27 28 29 2a 2b
> 1R11 111 2c 2d 2e 2f 30 31 32 33
> 1R11 111 34 35 36 37
> 1R11 110 54 00
> 1R11 110 45 00 00 54 3a 5a 00 00
> 1R11 110 40 01 66 36 0a 0a 63 02
> 1R11 110 0a 0a 63 03 00 00 84 c8
> 1R11 110 5b 61 00 01 f1 61 b8 60
> 1R11 110 8b 0f 00 00 08 09 0a 0b
> Conclusion is that the CAN2 transmit traffic looks fine, but no PING reply
> received via CAN. The CAN1 listen shows the reply just fine.
> Here is that last CAN1 listen, with timestamps:
> 1622696433.080107 1R11 111 54 00
> 1622696433.081657 1R11 110
> 1622696433.227479 1R11 111 45 00 00 54 e3 80 40 00
> 1622696433.228318 1R11 111 40 01 7d 0f 0a 0a 63 03
> 1622696433.245727 1R11 111 0a 0a 63 02 08 00 7c c8
> 1622696433.246214 1R11 111 5b 61 00 01 f1 61 b8 60
> 1622696433.248219 1R11 111 8b 0f 00 00 08 09 0a 0b
> 1622696433.248772 1R11 111 0c 0d 0e 0f 10 11 12 13
> 1622696433.250774 1R11 111 14 15 16 17 18 19 1a 1b
> 1622696433.251338 1R11 111 1c 1d 1e 1f 20 21 22 23
> 1622696433.253380 1R11 111 24 25 26 27 28 29 2a 2b
> 1622696433.253944 1R11 111 2c 2d 2e 2f 30 31 32 33
> 1622696433.265937 1R11 111 34 35 36 37
> 1622696433.269221 1R11 110 54 00
> 1622696433.272095 1R11 110 45 00 00 54 3a 5a 00 00
> 1622696433.272125 1R11 110 40 01 66 36 0a 0a 63 02
> 1622696433.272156 1R11 110 0a 0a 63 03 00 00 84 c8
> 1622696433.272193 1R11 110 5b 61 00 01 f1 61 b8 60
> 1622696433.272245 1R11 110 8b 0f 00 00 08 09 0a 0b
> 1622696433.272277 1R11 110 0c 0d 0e 0f 10 11 12 13
> 1622696433.272314 1R11 110 14 15 16 17 18 19 1a 1b
> 1622696433.272354 1R11 110 1c 1d 1e 1f 20 21 22 23
> 1622696433.272387 1R11 110 24 25 26 27 28 29 2a 2b
> 1622696433.272420 1R11 110 2c 2d 2e 2f 30 31 32 33
> 1622696433.272452 1R11 110 34 35 36 37
> It is 1Mbps, with 30us or so between each packet. This is the *only*
> traffic on the bus. Everything else is turned off. Roughly 12 packets each
> way. Surely even if we were hitting a performance limit, our buffers can
> handle 12 packets?
> The good news is that I have a good environment to replicate this issue
> now, so any fix should be easy to test.
> I haven’t worked on the MCP2515 driver in our code in a long time, but it
> certainly seems something is messed up and that could be badly affecting
> vehicle modules using anything other than CAN1.
> I will start to look at this over the weekend, but has anyone got any
> ideas/suggestions? Perhaps the bit timing registers are off by a small
> amount (so it works on CAN1 but not on CAN2)? Or something more serious in
> our driver?
> OvmsDev mailing listOvmsDev at lists.openvehicles.comhttp://lists.openvehicles.com/mailman/listinfo/ovmsdev
> <MCP2515Calc-1000kbit.ods>
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20220103/089c0898/attachment-0001.htm>
