[Ovmsdev] 4G Modem Module *requires* 3.3 firmware
Sat Feb 26 16:36:48 HKT 2022
We could include some "experimental" note to tell users things may
change there, as we do with the MQTT support.
Am 25.02.22 um 01:32 schrieb Mark Webb-Johnson:
> My only concern is the plugin system in 3.3, and backwards
> compatibility for those using that.
>> On 25 Feb 2022, at 5:23 AM, Michael Balzer <dexter at expeedo.de> wrote:
>> Signed PGP part
>> We should release 3.3 to eap & main now, as users now begin trying to
>> update their new 3.3 modules:
>> https://github.com/openvehicles/Open-Vehicle-Monitoring-System-3/issues/701
>> Objections?
>> Am 20.01.22 um 09:12 schrieb Mark Webb-Johnson:
>>> Just a reminder note to people upgrading existing v3.1 and v3.2 OVMS
>>> to 4G:
>>> You will need to install the v3.3 firmware (currently
>>> version 3.3.001) to support the new 4G modem option. That version is
>>> pre-installed on all new v3.3 kits, but not yet released to 'main'
>>> release level for everyone. The solution is to set the release level
>>> to 'edge', and you will see the v3.3 firmware available for install.
>>> You can set back to 'main' after install.
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20220226/9d4a5d7d/attachment.htm>
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20220226/9d4a5d7d/attachment.sig>
