[Ovmsdev] ssh documentation
Craig Leres
leres at xse.com
Tue Feb 15 05:33:29 HKT 2022
On 2/12/22 16:02, Stephen Casner wrote:
> You're right, this was a case of documentation not being updated to
> match the code. The update to WolfSSH 1.4.5 and WolfSSL 4.6.0 removed
> this restriction. That occurred a year ago (January 2021).
Perfect, thanks for the details.
> That is also correct. I believe the code as currently configured
> requires an RSA key. I see "NO_DSA" included in the user_settings.h
> that might be OK to remove. Some of the configuration trimming was to
> save space and some was to avoid the need for the slow calculations.
I suspect RSA is the "best" WolfSSL 4.6.0 supports. And I'm ok with
NO_DSA staying in effect:
http://www.openssh.com/legacy.html
OpenSSH 7.0 and greater similarly disable the ssh-dss (DSA)
public key algorithm. It too is weak and we recommend against
its use.
PR #700 created.
Craig
