[Ovmsdev] Server Authentication Confusion
Douglas Urner dlu at canishe.com
Fri Dec 30 08:30:42 HKT 2022
We’re trying to set up an OVMS server and I’m puzzled by the authentication process. After (making an attempt at) following the server setup instructions (https://docs.openvehicles.com/en/stable/server/index.html <https://docs.openvehicles.com/en/stable/server/index.html>) we’re seeing these message after starting the server:
2022-12-30 00:18:03.533595 +0000 info  OVMS::Server::AuthDrupal: - - - Periodic Drupal maintenance
DBD::mysql::db do failed: Table 'openvehicles.users' doesn't exist at plugins/system/OVMS/Server/DbDBI.pm line 181.
After a bit more poking, it appears that the only functional authentication module wants to talk to a Drupal site (presumably to populate the users table). Do we need to set up a Drupal instance, or is it possible manually populate the openvehicles.users table?
Thanks, Doug
Douglas Urner (he/they) | dlu at canishe.com | +1 360.769.5565
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20221229/b406dae4/attachment.htm>
