[Ovmsdev] Remaining Charge calculator
Michael Geddes
Fri Dec 30 07:59:09 HKT 2022
Firstly, the Voltage architecture (800V, 400V, 240V 3Phase, 240V 1Phase)
in use is going to affect the amount of power able to be delivered because
the limiting factor will be the current and possibly the potential
difference across the individual cell (?)- so it is my _thesis_ that this
will matter, especially in the mid section of the charging; I need to get
more information on this so I have made a plugin to handle gathering data.
I'm quite happy to ditch it if it doesn't bare out.
Ah, also there are two more metrics that I should log that you have
reminded me of: The available power (I think I have that metric) and the
temperature (? ave of the batteries perhaps).
I'll have to try and get to one of the few 800v chargers available in my
state again - finding 50kw chargers is pretty easy.
I have mapped by hand the charging 'curve' at an 800V charger (only 150kw
or so though - so yes, power also matters), and my experience was that it
was quite 'stepped' - ie it seemed to go in stages. Though I can see the
advantage of the gradient, the only time it went to more of a
curve/gradient is a little bit in the transition areas and above 90% SOC (
which I'm not really fussed with being too precise above 90%).
I'm still a little uncertain how to handle coming from a low SOC as the
lower SOC charges a bit slower, so still need to manage somehow the maximum
power available to the charger (which I possibly have as a metric - I
should probably include that in the logging and in the calculation, and
yes, that might end up being a better input into the algorithm).
The way I have it working (btw) means that a higher voltage architecture
defaults to the lower voltage curve (line) if a higher step isn't there. So
where the curves (lines) converge I don't double up on data in the table.
The AC Charger seems to be pretty constant right up to 90% for example.
//.ichael
On Fri, 30 Dec 2022 at 02:50, Michael Balzer <dexter at expeedo.de> wrote:
> Michael,
> while it makes sense to add a general standard utility for this, I don't
> think the Hyundai/Kia code is a good candidate for this.
> I find it confusing you need to take the voltage into account rather
> than the power. Also, the "WattHours" numbers don't seem to make sense
> -- why would you have different capacities in the same SOC differences,
> and why depending on the voltage? Also, the calculator seems to need /
> be based on rectangular steps instead of an actual charge curve?
> A more natural generalized definition would in my opinion be based on
> modeling the actual curve, like the one I've implemented for the VW Up,
> see `OvmsVehicleVWeUp::CalcChargeTime()`. That takes the charge curve as
> direct (SOC → max power) coordinates, just adding the section gradients
> as a speed optimization (float divisions are very CPU intense on the
> ESP32):
> struct {
> int soc; float pwr; float grd;
> } ccurve[] = {
> { 0, 30.0, (32.5-30.0) / ( 30- 0) },
> { 30, 32.5, (26.5-32.5) / ( 55- 30) },
> { 55, 26.5, (18.5-26.5) / ( 76- 55) },
> { 76, 18.5, (11.0-18.5) / ( 81- 76) },
> { 81, 11.0, ( 6.5-11.0) / ( 91- 81) },
> { 91, 6.5, ( 3.0- 6.5) / (100- 91) },
> { 100, 3.0, 0 },
> But maybe some other vehicle already has an even more generalized & easy
> to use approach. My function lacks temperature compensation, but
> normally delivers sufficiently close results.
> Am 29.12.22 um 13:02 schrieb Michael Geddes:
> > Hi,
> > There's a remaining charge calculator currently in the hyundai base
> > class which I have improved upon. This configuration allows for the
> > charge voltage to be part of the equation. This is the example from
> > data I collected with the ioniq 5 on 800v charging .. and I've written
> > a plugin so I can get more charge profile information at other charge
> > voltages.
> > I'm happy to leave it in the Ioniq 5 code, but was wondering if I
> > should put the implementation in a common area.. vehicle.h maybe?
> > //.ichael
> > ---8<----------------------
> > // Charging profile
> > // - Must be from lowest to highest to%.
> > // - Higher voltages must come before lower voltages for the same to%
> > charging_step_t ioniq5_chargesteps[] = {
> > // voltage, to%, WattHours
> > { 750, 10, 100000 },
> > { 750, 25, 190000 },
> > { 750, 45, 220000 },
> > { 750, 75, 120000 },
> > { 750, 80, 80000 },
> > { 400, 85, 60000 },
> > { 400, 90, 40000 },
> > { 100, 90, 1100 },
> > { 400, 95, 25000 },
> > { 100, 95, 7400 },
> > { 100, 100, 7200 },
> > { 0, 0, 0 },
> > int CalcRemainingChargeMins(int chargeVolt, float chargespeed, int
> > fromSoc, int toSoc, int batterySize, charging_step_t charge_steps[])
> > OvmsDev mailing list
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20221230/f973fbed/attachment-0001.htm>
