[Ovmsdev] New Metric Units
Wed Dec 14 05:41:21 HKT 2022
Michael,
Am 13.12.22 um 00:00 schrieb Michael Geddes:
> I'll go back and revise the topic subscriptions stuff wrt metrics etc.
> with the stuff I have done.
> I have implemented metric subscriptions and also implemented async
> getters in the dashboard just to see what the burden is, and tbh it's
> not too bad!  I had no real expectation that this would end up in the
> final code and it was more just to further my understanding.   What
> I've done does require a 'get and subscribe' function added to the
> websocket.
> *unit getsub /CallID/  m/etricName/*
> Which subscribes to the metric, but also returns a result something like
> { result : {  ID: /CallID/, Metric: /metricName/, Value:
> /metricValue/, Units : { native: /unitcode/, unit: /userunitcode/,
> label: /label/} }}
> So I can create a Promise and put the Accept function agains the
> (random) /CallID/ on an object, (and a timeout that calls reject) -so
> when the result comes in I can call the accept.
If the asynchronous nature isn't hidden (i.e. caller needs to use
async/await tags) and using the async getters is an alternative to the
pattern subscription scheme, that would be OK for inclusion. It adds
another way to subscribe, that may be better for some applications. Keep
in mind a page/fragment's getter subscriptions then also need to be
unsubscribed on unloading the page/fragment.
> It still doesn't get over the need for plugins to either subscribe to
> the metrics they want to access through metrics[]... or use the
> ametrics[] collection in an async function.  Having a tag (as you
> mentioned) that says which metrics to subscribe to would be at least
> backwards compatible.  I guess we could make it so that if a plugin
> was searched for such a tag and none existed, we could subscribe all?
Yes, and we could add an API version attribute, to be able to identify
receivers that expect to have direct access to all metrics. That way we
still enable a new receiver to be created that really doesn't need
metrics (or does all subscriptions through the async getters). Something
like…
<div class="receiver">
   → auto subscription to "metrics/#" if no explicit "metrics/…"
subscriptions present
<div class="receiver" data-apiversion="2">
   → only process explicit subscriptions
> //.ichael
> On Sun, 11 Dec 2022 at 19:54, Michael Balzer <dexter at expeedo.de> wrote:
>     Michael,
>     yes, while async getters seem to be possible by some JS voodoo,
>     they probably won't work without changes to the applications.
>     I also don't think they would form an application code pattern we
>     should encourage, as they would try to hide asynchronous
>     operations and would lead to each individual metric needing to be
>     requested (at least initially) by a separate async call.
>     Instead, please reconsider:
>>     Btw, in case you didn't see this already: I implemented an auto
>>     subscription scheme for the 'stream' notifications -- these are
>>     by default very transmission intense and can cause substantial
>>     load on the module side as well. These subscriptions are managed
>>     automatically for all components and plugins by the framework
>>     (which btw also takes care of initializing all fragments added in
>>     the '#' container).
>     I designed this subscription scheme to follow the MQTT topic
>     subscription scheme and be usable for any kind of subscription.
>     Different data sources can be identified by the root topic. For
>     notifications, it's `notify/`, for metrics, we can naturally
>     assign `metrics/`. A subscription pattern `metrics/v/p/#` would
>     for example subscribe to all `v.p.*` metrics.
>     Auto subscribing & unsubscribing is managed by the framework via
>     the `data-subscriptions` attribute of a `.receiver`.
>     Examples:
>       * https://docs.openvehicles.com/en/latest/components/ovms_webserver/docs/notifications.html
>       * https://github.com/openvehicles/Open-Vehicle-Monitoring-System-3/tree/master/plugins/retools
>     Btw, if (!) we keep the units dictionary subscription necessity,
>     that could be a subscription to `units/#`.
>     Regards,
>     Michael
>     Am 08.12.22 um 04:29 schrieb Michael Geddes:
>>     I've implemented a way of having user units of metrics come
>>     through  (I have metrics_user[] metrics_label[] and metrics_all[]
>>     implemented)..
>>     *however as far as dynamic subscription to metrics goes, I now
>>     believe I can't do what I want in a backwards compatible way.*
>>     This is where I'm at:
>>     I haven't used Promises before or async/wait etc, so in my
>>     naivity, I had (mistakenly it seems) thought I could define a
>>     function taking a /metric code/ that
>>     * Sends a command to the websocket  eg /metric fetchsub 1234
>>     v.p.trip/
>>     * Waits for the result coming in over the web-socket or times out
>>     * Returns the result to the user *directly*
>>     so /metric['/ /v.p.trip//'] /  (or whatever) could have an
>>     accessor function that (for unsubscribed metrics) silently
>>     fetched and subscribed to the metric over the websocket and
>>     returned the value.
>>     I have actually implemented the fetching bit mostly .. (a Promise
>>     resolve call-back is put in a collection against a random id and
>>     when the event comes back it uses the id to grab the promise
>>     function and resolve with the result - and yes it has a timeout)
>>     ... except that in the end, the javascript still requires a
>>     Promise to be created that needs to execute its result as a
>>     call-back. I also believe I now understand why that is not
>>     possible, and that fundamentally the only way of doing async
>>     stuff at all ends up in some kind of call back (via a Promise
>>     directly or an async function Promise)... and that the only
>>     exceptions to this are within an async function (which in the end
>>     still returns a Promise).
>>     This makes blocking on a metric['v.p.trip'] proxy get; function
>>     not possible afaict.  Unless somebody knows a mechansim that I
>>     could use? (outside of an async function, of course)
>>     I have implement the subscription model for metrics[]  (which
>>     supports, for example, v.p.* ) .. but without the
>>     auto-subscription it is going to be less useful for plugins as
>>     far as backwards compatibility goes!
>>     you could have a call like this:
>>        applyMetric('v.p.trip', (value) => {  ... put the value
>>     somewhere } )
>>     //.ichael
>>     On Sat, 3 Dec 2022 at 02:29, Michael Balzer <dexter at expeedo.de>
>>     wrote:
>>         Michael,
>>         the unit conversion JS code scheme is fine. Btw, you can
>>         optimize convert to…
>>           convert = function (from, to, value) {
>>             return (unit_conversions[from + ">" + to] ||
>>         unit_conversions.native)(value);
>>     Yeah - I'm assuming that the gain from not looking up
>>     unnecessarily is lost from all the checking. Got it.
>>>         I knew we had to keep the default webstream as it was.  I
>>>         was thinking of having a different websocket Uri to trigger
>>>         filtered mode (starting without sending all units).
>>>         Especially, I was also considering the plugins that run from
>>>         the '#' container that may not know the container had
>>>         switched to user units! (so I'm not sure about option a.),
>>>         so from what I can tell, the base metrics[] needs to
>>>         maintain native units imho. This is also why I was looking
>>>         at the 'auto-subscribe' idea since the outside container
>>>         doesn't know which metrics a plugin might use, and a plugin
>>>         wouldn't know to subscribe to the messages.
>>         I think plugins will need to be updated anyway, as will all
>>         our standard pages & components, as up to now all units have
>>         been fixed in the UI.
>>         In both approaches, all metrics displays (simple markup,
>>         tables, charts) will need to be reworked to use the user
>>         units. Only the basic markup type displays could partially be
>>         modified automatically (by walking through their '.unit'
>>         elements), but any extended use, even the range & energy
>>         displays in the dashboard's speed gauge, will need a
>>         config-aware approach.
>>         Charts will need to fully reconfigure, as unit labels are
>>         used within different chart features, and axis limits &
>>         plotbands will need to be adjusted. For this, scripts can
>>         subscribe to a new 'msg:units' event sent when a
>>         (re-)configuration of units is received.
>>     Yeah - I've got some classes so that different cars can specify
>>     all the ranges in native units and it will generate code for the
>>     current user units. I've already put this into use for all
>>     vehicle classes that return a custom guage configuration.
>>       At the moment it is still static code and we'll need to sink on
>>     a (not yet implmeneted) untits changed event to  reload it.. but
>>     it would be simple enough to change the code generated to be
>>     dynamic (especially that we now have that conversion function).
>>     Even just having the user refresh the page is better than nothing
>>     at the moment (it's not like the user is going to be changing the
>>     units all the time).
>>         auto subscription scheme for the 'stream' notifications --
>>         these are by default very transmission intense and can cause
>>         substantial load on the module side as well. These
>>         subscriptions are managed automatically for all components
>>         and plugins by the framework (which btw also takes care of
>>         initializing all fragments added in the '#' container).
>>>         We could maintain a units collection exactly as above with
>>>         some proxy arrays to get at values without exceptions.  For eg:
>>>         m.label["v.p.speed"]  could look up the units_ collection
>>>         being maintained and return blank if the entry doesn't
>>>         exist. Then
>>>         m.value["v.p.speed"] would give the user unit and
>>>         m.nativevalue["v.p.speed"] the native value. The latter two
>>>         would use the metrics[] array or whatever mechanism we had.
>>>         We could add m.text["v.p.speed"] that would give a text
>>>         version with the value and unit if it had one.
>>         That leads us to another option: we could keep the metrics
>>         transmission in native values, add the units dictionary and
>>         provide all conversions in Javascript using this proxy getter
>>         scheme.
>>     Yep - already decided to do that. It makes more sense.  At the
>>     moment I'm also implementing a way of starting off with no
>>     metrics supplied and then adding in which ones we need.  Probably
>>     the JS is the bit I need to work out on that.
>>         That would keep the current metrics[] access scheme intact
>>         and unchanged, so all current frontend code & plugins would
>>         continue to work, using the native values as before.
>>         The new proxy getters then can be used as the new way to
>>         access metrics by anyone interested in using user units, and
>>         we can go ahead by applying this to the standard pages and
>>         components.
>>         This in combination with the 'msg:units' event to signal
>>         reconfiguration should provide all we need.
>>         We can even easily combine this with providing a command or
>>         socket URL / parameter to switch the metrics into user mode.
>>         The standard web frontend won't need this then, but it would
>>         make using user units easy for devices without Javascript
>>         support.
>>         Regards,
>>         Michael
>>         Am 28.11.22 um 00:36 schrieb Michael Geddes:
>>>         Solved a couple of things.
>>>         I have a 'unit conversion' code - which I current have put
>>>         into a separate cpp file along with the two other C++
>>>         conversion functions.
>>>         I wanted to do it this way so they are all in there
>>>         together. (Does this make sense to do?).
>>>         mi_to_km = function(mi) { return mi * 1.609347; }
>>>           km_to_mi = function(km) { return km * 0.6213700; }
>>>           pkm_to_pmi = function(pkm) { return pkm * 1.609347; }
>>>           pmi_to_pkm  = function(pmi) { return pmi * 0.6213700; }
>>>           const feet_per_mile = 5280;
>>>           var unit_conversions = {
>>>                 "native":             function (value) { return value;},
>>>                 "km>miles": km_to_mi,
>>>                 "km>meters":  function (value) { return value*1000; },
>>>                 "km>feet":  function (value) { return
>>>         km_to_mi(value) * feet_per_mile; },
>>>                 "percent>permille": function (value) { return
>>>         value*10.0; },
>>>                 "percent>percent":  function (value) { return
>>>         value*0.10; }
>>>           convert_function = function (from, to) {
>>>             var fn = undefined;
>>>             if (from !== to && to !== "")
>>>               fn = unit_conversions[from + ">" + to];
>>>             if (fn == undefined)
>>>               fn = unit_conversions.native;
>>>             return fn;
>>>             var fn = convert_function(from, to);
>>>             return fn(value);
>>>         The other problem of looking at the uri of the websocket I
>>>         have solved by creating a 'SocketCreator'  MgHandler class
>>>         in the MG_EV_WEBSOCKET_HANDSHAKE_REQUEST event (and looks at
>>>         the uri)... that waits for the
>>>         MG_EV_WEBSOCKET_HANDSHAKE_DONE  and deletes itself.
>>>         int OvmsSocketCreator::HandleEvent(int ev, void *p)
>>>           if ( ev != MG_EV_WEBSOCKET_HANDSHAKE_DONE)
>>>             return ev;
>>>           // new websocket connection
>>>           MyWebServer.CreateWebSocketHandler(m_nc, m_socket_type );
>>>           m_nc = NULL;
>>>           delete this;
>>>           return 0;
>>>         Thoughts?
>>>         //.ichael
>>>         On Sun, 27 Nov 2022 at 07:18, Michael Geddes
>>>             I was thinking of having a different websocket Uri to
>>>             trigger filtered mode (starting without sending all
>>>             units).. Though I am struggling with how to get and then
>>>             pass the Uri information into the web socket
>>>             constructor! The event that currently creates it doesn't
>>>             seem to have access to the Uri. (see below - p is NULL
>>>             for HANDSHAKE_DONE).
>>>             case MG_EV_WEBSOCKET_HANDSHAKE_REQUEST:
>>>             struct http_message *hm = (struct http_message *) p; //
>>>             how to pass uri info to the event below!?
>>>             break;
>>>             case MG_EV_WEBSOCKET_HANDSHAKE_DONE:   // new websocket
>>>             connection
>>>             MyWebServer.CreateWebSocketHandler(nc);
>>>             break;
>>>             from the '#' container that may not know the container
>>>             had switched to user units! (so I'm not sure about
>>>             option a.), so from what I can tell, the base metrics[]
>>>             needs to maintain native units imho. This is also why I
>>>             was looking at the 'auto-subscribe' idea since the
>>>             outside container doesn't know which metrics a plugin
>>>             might use, and a plugin wouldn't know to subscribe to
>>>             the messages.
>>>             I do like the separate units description message -
>>>             though we would probably need to add the 'native' if we
>>>             want to do conversions.
>>>             { units: {
>>>               "v.p.speed": { code: "kmph", *native "kmph",* label:
>>>             "km/h" }, …
>>>             with some proxy arrays to get at values without
>>>             exceptions.  For eg:
>>>             collection being maintained and return blank if the
>>>             entry doesn't exist. Then
>>>             two would use the metrics[] array or whatever mechanism
>>>             we had. We could add m.text["v.p.speed"] that would give
>>>             a text version with the value and unit if it had one.
>>>             I had contemplated the idea of providing a JavaScript
>>>             unit conversion and was working around it. Downside is
>>>             it's a third set of conversion functions to maintain...
>>>             On the other hand using that we could just keep the
>>>             metrics being sent as it is now, have the groups sent as
>>>             you proposed (along with the native unit code) , and
>>>             have the above m.value[] proxy collection use a 'touser'
>>>             function assigned to the units_ collection above that
>>>             provided native to user conversion.
>>>             We could send a javascript library  constructed with
>>>             just the necessary functions for the required
>>>             conversions of native to user (or the whole lot..
>>>             whichever). .
>>>             var conversions = {
>>>                 unit: function ( value) { return value }
>>>                 km_miles: function (value) { return value * 0.6213700; }
>>>             We could perform the lookup when constructing the units
>>>             and assign the touser property. (And have a 'unit'
>>>             function that does no conversion).
>>>             //.ichael
>>>             On Sat, 26 Nov 2022, 10:43 pm Michael Balzer,
>>>                 The metrics subscription scheme is an option, and
>>>                 the auto-subscribe feature via a getter is a nice
>>>                 idea. But I wouldn't apply that to metrics value
>>>                 conversions and units.
>>>                 Also we would still need the current set of metrics
>>>                 to be subscribed by default, as there are also non
>>>                 Javascript devices (e.g. smart buttons, Wifi
>>>                 displays) reading the WebSocket stream.
>>>                 My thoughts on this so far:
>>>                 Basically the web UI, as any frontend, should adapt
>>>                 to unit configurations seamlessly. The web UI
>>>                 includes many command outputs, which already
>>>                 automatically switch units as configured.
>>>                 For all practical purposes, the web UI needs to
>>>                 interact with users in their preferred units. Only
>>>                 some plugins and functions will need certain values
>>>                 in metric (native) units for calculations, and these
>>>                 will also need a simple way to convert calculation
>>>                 results back to user units for displaying. So I
>>>                 think we need to provide the unit configuration and
>>>                 value conversion tools in the web framework as well.
>>>                 Proposal:
>>>                 a) We provide a config option and a WebSocket
>>>                 command to switch the WebSocket metrics transmission
>>>                 mode to user / native units. To keep plugin
>>>                 compatibility, the default is 'native'.
>>>                 b) We introduce a separate units dictionary object
>>>                 containing the user units for both metrics and the
>>>                 unit groups in their code & label representation.
>>>                 The units dictionary only needs to be sent
>>>                 initially, when new metrics are registered, when the
>>>                 metrics mode is changed for the current connection,
>>>                 and when some user unit configuration is changed,
>>>                 keeping the bandwidth and processing requirements low.
>>>                 The units dictionary can combine both metrics and
>>>                 group units, as the unit group names are fully
>>>                 distinct from the metrics namespace. The transport
>>>                 scheme could be:
>>>                 { units: {
>>>                   "v.p.speed": { code: "kmph", label: "km/h" }, …
>>>                   "units.distance": { code: "miles", label: "M" }, …
>>>                 c) In the web framework, accessing units should be
>>>                 as simple as possible and avoid throwing exceptions
>>>                 for undefined entries, so we could e.g. split these
>>>                 into separate code & label objects:
>>>                 units["v.p.speed"]    = "km/h"    // consistently
>>>                 accompanies metrics["v.p.speed"]
>>>                 unitcodes["v.p.speed"]     = "kmph"
>>>                 units["units.distance"] = "M"
>>>                 unitcodes["units.distance"] = "miles"
>>>                 …or provide a getter that tests for the key
>>>                 existence and returns an object with empty fields as
>>>                 necessary.
>>>                 With this, all metrics displays can easily be
>>>                 changed to display the actual unit labels instead of
>>>                 using fixed strings.
>>>                 d) To provide value conversion we implement
>>>                 UnitConvert() in Javascript plus some wrappers that
>>>                 automatically look up the unit for a given
>>>                 metrics/group name and do the conversion to/from
>>>                 native units, something like…
>>>                 var speed_kph    = toNativeValue("v.p.speed"); //
>>>                 optional second arg to convert any data
>>>                 var speed_kph    = metrics_native["v.p.speed"]; //
>>>                 using a getter
>>>                 var trip_display = toUserValue("units.distance", 1234);
>>>                 Plugins for scientific/technical applications that
>>>                 depend on native (metric) units can use the new
>>>                 metrics transmission mode control command to force
>>>                 native mode. Or they can choose to migrate from
>>>                 "metrics[]" to "metrics_native[]".
>>>                 The metrics mode config option can come with a note
>>>                 informing users that there may be some old plugins
>>>                 not compatible with non-native units. They can then
>>>                 check their plugins for this and make an informed
>>>                 decision on wether to enable user units and/or
>>>                 wether to install a specific plugin.
>>>                 Thoughts, comments?
>>>                 Regards,
>>>                 Michael
>>>                 Am 25.11.22 um 03:13 schrieb Michael Geddes:
>>>>                 I have an idea which might reduce traffic for
>>>>                 maintaining the metrics[] array in the browser and
>>>>                 cope with the user units.
>>>>                 I'll start by saying I'm not a JS developer per
>>>>                 se.. so a newb in JS really. Still, it's mainly
>>>>                 just another language so .. we'll give it a go.
>>>>                 Firstly:
>>>>                 * Implement the 'changed' filters as below for the
>>>>                 web-socket.. for both normal and 'user' values.
>>>>                 * Add a function that subscribes to a value (and
>>>>                 returns the current value of it)..including to
>>>>                 'user' value/unitlabel.
>>>>                 Subscribing the normal way to the metrics over the
>>>>                 websocket would have the normal effect.. but we
>>>>                 would have a new way that would subscribe in a
>>>>                 filtered way.
>>>>                 I've had a little play with the Proxy object .. so
>>>>                 at least I know this should work:
>>>>                 Have a metrics_ array that is the real associative
>>>>                 array for metrics[] and then define a Proxy that
>>>>                 has (at the least) 'get' and 'has' defined (giving
>>>>                 us the ability to overload /metrics['prop']/ and
>>>>                 /"prop" in metrics operations/).
>>>>                 The /get /function would return the underlying
>>>>                 value if it exists in the /metrics_ /array (which
>>>>                 is maintained through the websocket from currently
>>>>                 subscribed values in the current manner).
>>>>                 If the value is not in the /metrics_/ array - it
>>>>                 would then do a subscribe+query on the websocket
>>>>                 getting the current value and adding it into the
>>>>                 /metrics_/  container. If it was unavailable then
>>>>                 it would put /undefined/ into the array.
>>>>                 The 'has' would do the get() and return true if the
>>>>                 value was not == /undefined/.
>>>>                 For the 'query the websocket' bit, I'm assuming I
>>>>                 would be working with promises or futures or some
>>>>                 such: I'll do the research and do it properly
>>>>                 unless somebody can help me out with it. That's the
>>>>                 bit I was going to work on next for the
>>>>                 proof-of-concept.
>>>>                 Any immediate thoughts? Dangers?
>>>>                 I also noticed there was a bit that went through
>>>>                 html element properties and looked for metrics ..
>>>>                 this could be used to bulk subscribe to any metric
>>>>                 values required there.
>>>>                 //.ichael
>>>>                 On Thu, 17 Nov 2022 at 07:52, Michael Geddes
>>>>                     Yeah, ok.
>>>>                     I will get all the other 'user unit' stuff done
>>>>                     as a line in the sand, and then move to working
>>>>                     out the web stuff.  I'm still finding my way
>>>>                     though all the client side javascript, which
>>>>                     looks very cool.. but I've not really done
>>>>                     jQuery before (just enough to recognise it).
>>>>                     Subscribing to metrics with/without user units
>>>>                     makes a lot of sense. Obviously the default
>>>>                     needs to be 'Subscribe to all metrics but not
>>>>                     user units' to maintain compatibility... but I
>>>>                     was also thinking it might be nice if we could
>>>>                     filter down even the normal subscribed events.
>>>>                     We could have:
>>>>                     * Web socket command to  filter units (flag on
>>>>                     websocket to say 'filtered' + flag bitset on
>>>>                     each metric  similar to 'dirty')
>>>>                     Then either:
>>>>                     * Web socket command to turn on user units
>>>>                     (single flag on that websocket)
>>>>                     or
>>>>                     * Web socket command to turn on user units for
>>>>                     specific metrics (flag bitset on each metric)
>>>>                     A parameter to the URI for the websocket could
>>>>                     start the socket in 'filtered' mode to avoid
>>>>                     the initial rush of metrics.
>>>>                     This could drastically reduce traffic and time
>>>>                     for the metrics command to execute.  It would
>>>>                     be possible to also check (on a 'filtered'
>>>>                     websocket) for any changes to metrics for that
>>>>                     websocket slot before queueing the 'metric
>>>>                     update' socket command.
>>>>                     //.ichael
>>>>                     On Thu, 17 Nov 2022 at 00:35, Michael Balzer
>>>>                         Michael,
>>>>                         I don't have much spare time currently,
>>>>                         just some quick first comments: it's
>>>>                         important to implement this as lightweight
>>>>                         as possible, both in terms of network load
>>>>                         and client CPU & memory requirements. Some
>>>>                         devices already have issues, which can be
>>>>                         seen by the "websocket overflow" messages.
>>>>                         The web UI also should stay usable via
>>>>                         cellular.
>>>>                         My impression is the new scheme, while only
>>>>                         slightly raising the client requirements,
>>>>                         adds substantially to the network requirements.
>>>>                         An option could be to separate the units --
>>>>                         or more, back when implementing this I
>>>>                         thought about separating the names later
>>>>                         on. Another question is if we normally
>>>>                         generally need both the native and the
>>>>                         converted values in the web UI. We maybe
>>>>                         could provide an option to switch to
>>>>                         converted values, or add an option to
>>>>                         retreive or subscribe to a set of converted
>>>>                         metrics on demand.
>>>>                         Standard plugins like ABRP and PwrMon rely
>>>>                         on getting metric (native) units, and there
>>>>                         probably are non-public plugins, e.g. for
>>>>                         engineering & scientific projects, that
>>>>                         depend on metric units to do their
>>>>                         calculations and don't need anything else.
>>>>                         We shouldn't make life harder for these
>>>>                         applications without good reason.
>>>>                         Regards,
>>>>                         Michael
>>>>                         Am 15.11.22 um 01:26 schrieb Michael Geddes:
>>>>>                         If you're ok with the [default] option
>>>>>                         I'll stick with that. I mean in some ways
>>>>>                         it would be nice to have a button choice
>>>>>                         metric | usa | europe | asia | custom
>>>>>                          etc and I kind of considered something
>>>>>                         like that but figured it's only a handful
>>>>>                         of choices.. and it's an embedded device..
>>>>>                         so simpler is better.
>>>>>                         On a related note - I was thinking how it
>>>>>                         would be nice if the dashboard (etc) had
>>>>>                         access to the 'user' units, so went
>>>>>                         hunting down that little rabbit hole.
>>>>>                         Quite a nice mechanism with the web socket
>>>>>                         updating the "metrics" object in the UI.
>>>>>                         This is a snippet of one idea, which is
>>>>>                         that for any metric that has the
>>>>>                         possibility of a user unit, we set the
>>>>>                         extra values of the metric with '#unit'
>>>>>                         and '#user' appended - see below. (I've
>>>>>                         chosen '#' arbitrarily.. but it could be
>>>>>                         '/' or ':' or '>'  but maybe not '.' )
>>>>>                         v.p.odometer#unit: "M"
>>>>>                         v.p.odometer#user: 6754.91
>>>>>                         v.p.satcount: 13
>>>>>                         v.p.speed: 0
>>>>>                         v.p.speed#unit: "km/h"
>>>>>                         v.p.speed#user: null
>>>>>                         *v.p.trip: 28*
>>>>>                         *v.p.trip#unit: "M"
>>>>>                         v.p.trip#user: 17.3984*
>>>>>                         Then we can use this in the dials to
>>>>>                         populate the values and captions! (not
>>>>>                         that I like Miles).
>>>>>                         I
>>>>>                         The other (similar) way was to have
>>>>>                         something like the following:
>>>>>                         "v.p.trip#user" : { "value": 17.3984,
>>>>>                         "unit": "M" }
>>>>>                         It wouldn't make the total message any
>>>>>                         shorter.. soo.. dunno.
>>>>>                         There's also some complications with
>>>>>                         setting up the dials (for min/max values)
>>>>>                         - like for the speed.
>>>>>                         Notice also that I'm returning null for
>>>>>                         undefined values. It's nice - but I'm not
>>>>>                         sure how javascript handles null when used
>>>>>                         / printed etc.
>>>>>                         //.ichael
>>>>>                         On Sun, 13 Nov 2022 at 21:06, Michael
>>>>>                             Michael,
>>>>>                             looks good.
>>>>>                             I think having an explicit 'default'
>>>>>                             option is better than taking the
>>>>>                             'Metric' equivalent for that, as in
>>>>>                             your example you already show unit
>>>>>                             alternatives within the metric system
>>>>>                             to support different scalings (kW / W,
>>>>>                             kWh / Wh). (Btw… waiting for someone
>>>>>                             to miss Horsepower & BTU here ;-))
>>>>>                             @Patrick, I think that also answers
>>>>>                             your implicit question:
>>>>>>                             The default button makes it unclear what the actual setting is.
>>>>>                             The default (native unit) is always
>>>>>                             metric, but you may have a mix of
>>>>>                             scalings, as we try to find the one
>>>>>                             that fits best for the given
>>>>>                             application when defining a metric.
>>>>>                             For example the current driving energy
>>>>>                             consumption is stored natively in
>>>>>                             Wh/km, while the energy used or
>>>>>                             regenerated is in kWh, and the
>>>>>                             odometer & trip counters are in km,
>>>>>                             while the altitude ist in m.
>>>>>                             Regards,
>>>>>                             Michael
>>>>>                             Am 13.11.22 um 08:42 schrieb Michael
>>>>>                             Geddes:
>>>>>>                             Greetings,
>>>>>>                             so this is my idea of being able to
>>>>>>                             select which units various groups use
>>>>>>                             (in addition to Distance).
>>>>>>                             This can be then accessed by the
>>>>>>                             special 'user' unit code.  (or
>>>>>>                             'metrics list -u ' )
>>>>>>                             The idea of [Default] selection
>>>>>>                             below  simply means storing the value
>>>>>>                             to blank - meaning use whatever unit
>>>>>>                             the particular metric uses. The other
>>>>>>                             idea I had was to actually default it
>>>>>>                             to the equivalent of 'Metric' special
>>>>>>                             unit code and not have the [Default]
>>>>>>                             button.
>>>>>>                             Currently I've made it so that if
>>>>>>                             there are more than 3 choices other
>>>>>>                             than [default] that it uses the
>>>>>>                             choice/combo box rather than the
>>>>>>                             Radio buttons. (ie this list is
>>>>>>                             auto-generated from the Metric Units
>>>>>>                             table and the Metric Groups table).
>>>>>>                             Thoughts / comments?
>>>>>>                             //.ichael
>>>>>>                             On Sat, 12 Nov 2022 at 17:35, Michael
>>>>>>                             Geddes <frog at bunyip.wheelycreek.net>
>>>>>>                             wrote:
>>>>>>                                 https://github.com/openvehicles/Open-Vehicle-Monitoring-System-3/pull/771
>>>>>>                                 I'm hoping this P/R is ok in this
>>>>>>                                 form (made of 5 separate commits).
>>>>>>                                 I will have a look at
>>>>>>                                 implementing the "user" unit
>>>>>>                                 code. The base for how it
>>>>>>                                 would work is already a part of
>>>>>>                                 the above pull request. I'll just
>>>>>>                                 look at the module configuration
>>>>>>                                 for distance.
>>>>>>                                 The 'power consumption' is one
>>>>>>                                 where it's not just a check-box..
>>>>>>                                 there're 5 possible choice!
>>>>>>                                 I should also add 'bar' for
>>>>>>                                 pressure given that for some
>>>>>>                                 reason that's still a thing
>>>>>>                                 people want.
>>>>>>                                 //.ichael
>>>>>>                                 On Sat, 12 Nov 2022 at 16:24,
>>>>>>                                 Michael Balzer
>>>>>>                                     I think this is pretty decent
>>>>>>                                     & complete now.
>>>>>>                                     I also like the approach of
>>>>>>                                     the 'user' unit code. Moving
>>>>>>                                     all user unit prefs into the
>>>>>>                                     module configuration is an
>>>>>>                                     old todo. Currently only the
>>>>>>                                     distance unit is defined at
>>>>>>                                     the module side, temperature
>>>>>>                                     and pressure are App prefs.
>>>>>>                                     Regards,
>>>>>>                                     Michael
>>>>>>                                     Am 11.11.22 um 09:54 schrieb
>>>>>>                                     Michael Geddes:
>>>>>>>                                     Ok - so here's what I have
>>>>>>>                                     implemented for Duktape and
>>>>>>>                                     Metrics. (I added
>>>>>>>                                     IsDefined() as well).
>>>>>>>                                     Any thoughts on this?
>>>>>>>                                     Noting
>>>>>>>                                      OvmsMetrics.Float( {metric}
>>>>>>>                                     ) -> Outputs metric as float
>>>>>>>                                     (same)
>>>>>>>                                      OvmsMetrics.Float(
>>>>>>>                                     {metric}, {unit}) -> Outputs
>>>>>>>                                     metric as float converted to
>>>>>>>                                     given unit (new)
>>>>>>>                                      OvmsMetrics.Value( {metric}
>>>>>>>                                     )  -> Outputs Metric in
>>>>>>>                                     native value (same)
>>>>>>>                                     , false)   -> Outputs Metric
>>>>>>>                                     as string and no units (same)
>>>>>>>                                     , {unit})  -> Outputs Metric
>>>>>>>                                     converted to given unit as
>>>>>>>                                     native value. (new)
>>>>>>>                                     , {unit}, false )  ->
>>>>>>>                                     Outputs Metric converted to
>>>>>>>                                     given unit as string
>>>>>>>                                     including any unit
>>>>>>>                                     specifier. (new)
>>>>>>>                                     also OvmsMetric.GetValues(
>>>>>>>                                     {metric} [,{unit}] [,
>>>>>>>                                     {converted} ] )  Adds
>>>>>>>                                     similar behaviour to Value()
>>>>>>>                                     above.
>>>>>>>                                     also the special units
>>>>>>>                                     '*imperial*' and '*metric*'
>>>>>>>                                     will convert to the
>>>>>>>                                     associated imperial / metric
>>>>>>>                                     version of the units as
>>>>>>>                                     appropriate.
>>>>>>>                                     (function() {
>>>>>>>                                        dump = function (metric)
>>>>>>>                                     { print( metric+ "
>>>>>>>                                     ["+(typeof metric)+"]\n"  ); }
>>>>>>>                                        dump_obj = function (obj )  {
>>>>>>>                                      print('--- Object ----\n')
>>>>>>>                                          for (var k in obj) {
>>>>>>>                                            xk = obj[k];
>>>>>>>                                            print( k+':'+ xk + '
>>>>>>>                                     ['+typeof xk+ "]\n");
>>>>>>>                                      dump(OvmsMetrics.Value("xiq.v.trip.consumption"));
>>>>>>>                                      dump(OvmsMetrics.Value("xiq.v.trip.consumption",
>>>>>>>                                     false));
>>>>>>>                                      dump(OvmsMetrics.Value("xiq.v.trip.consumption","kmpkwh"));
>>>>>>>                                     "mipkwh", false));
>>>>>>>                                      dump(OvmsMetrics.AsFloat("xiq.v.trip.consumption"));
>>>>>>>                                      dump(OvmsMetrics.AsFloat("xiq.v.trip.consumption","kmpkwh"));
>>>>>>>                                      dump(OvmsMetrics.Value("xiq.v.trip.consumption","imperial"))
>>>>>>>                                      dump(OvmsMetrics.Value("xiq.v.trip.consumption","imperial",
>>>>>>>                                     false))
>>>>>>>                                      dump_obj(OvmsMetrics.GetValues("trip",
>>>>>>>                                     "metric"))
>>>>>>>                                     "imperial", false))
>>>>>>>                                     With this output:
>>>>>>>                                     19.2308 [number]
>>>>>>>                                     19.2308 [string]
>>>>>>>                                     5.2 [number]
>>>>>>>                                     3.23112mi/kWh [string]
>>>>>>>                                     19.2308 [number]
>>>>>>>                                     5.2 [number]
>>>>>>>                                     309.49 [number]
>>>>>>>                                     309.49Wh/mi [string]
>>>>>>>                                     --- Object ----
>>>>>>>                                     v.p.trip:13 [number]
>>>>>>>                                     xiq.e.trip:0 [number]
>>>>>>>                                     xiq.e.trip.energy.recuperated:0 [number]
>>>>>>>                                     xiq.e.trip.energy.used:0 [number]
>>>>>>>                                     xiq.v.trip.consumption:19.2308 [number]
>>>>>>>                                     --- Object ----
>>>>>>>                                     v.p.trip:8.07781M [string]
>>>>>>>                                     xiq.e.trip:0M [string]
>>>>>>>                                     xiq.e.trip.energy.recuperated:0kWh [string]
>>>>>>>                                     xiq.e.trip.energy.used:0kWh [string]
>>>>>>>                                     xiq.v.trip.consumption:309.49Wh/mi [string]
>>>>>>>                                     On Wed, 9 Nov 2022 at 05:47,
>>>>>>>                                     Michael Geddes
>>>>>>>                                     wrote:
>>>>>>>                                         Yeah - I like HasValue.
>>>>>>>                                         I implemented
>>>>>>>                                         IsDefined() but I will
>>>>>>>                                         rename it.. that's a
>>>>>>>                                         much clearer name.
>>>>>>>                                         Another thought. How
>>>>>>>                                         about if we did this
>>>>>>>                                         (but also with
>>>>>>>                                         GetValues() as well -
>>>>>>>                                         see the special values
>>>>>>>                                         below)
>>>>>>>                                          true)  -> 17.0582  (Number)
>>>>>>>                                          false) -> 17.0582  (String)
>>>>>>>                                         "mipkwh", true)  ->
>>>>>>>                                         3.64264  (Number)
>>>>>>>                                         "mipkwh", false)  ->
>>>>>>>                                         3.64264Mi/kWh  (String)
>>>>>>>                                         "native", false)  ->
>>>>>>>                                         17.0582km/kWh  (String)
>>>>>>>                                         and
>>>>>>>                                         "imperial", false)  ->
>>>>>>>                                         I have already
>>>>>>>                                         implemented the special
>>>>>>>                                         values 'native'
>>>>>>>                                         (existing), 'imperial'
>>>>>>>                                         and 'metric'.
>>>>>>>                                         I was also thinking that
>>>>>>>                                         in the future you could
>>>>>>>                                         have 'user'. Where for
>>>>>>>                                         each group of values:
>>>>>>>                                         'temperature',
>>>>>>>                                         'distance',
>>>>>>>                                         'shortdistance', 'power'
>>>>>>>                                         etc.. you could have a
>>>>>>>                                         user preference. I
>>>>>>>                                         probably won't implement
>>>>>>>                                         it now,.but it could be
>>>>>>>                                         cool that any UI could
>>>>>>>                                         just ask for the user
>>>>>>>                                         defined units (rather
>>>>>>>                                         than having a separate
>>>>>>>                                         choice).
>>>>>>>                                         //.ichael
>>>>>>>                                         On Tue, 8 Nov 2022 at
>>>>>>>                                         21:57, Mark Webb-Johnson
>>>>>>>                                         <mark at webb-johnson.net>
>>>>>>>                                         wrote:
>>>>>>>                                             Or perhaps something
>>>>>>>                                             more specific?
>>>>>>>                                                 HasValue()
>>>>>>>                                             Mark
>>>>>>>>                                             On 8 Nov 2022, at
>>>>>>>>                                             9:01 PM, Michael
>>>>>>>>                                             Balzer
>>>>>>>>                                             wrote:
>>>>>>>>                                             Signed PGP part
>>>>>>>>                                             That's basically a
>>>>>>>>                                             good approach, but
>>>>>>>>                                             be aware
>>>>>>>>                                             'IsDefined()' has
>>>>>>>>                                             an ambiguous
>>>>>>>>                                             meaning here, as
>>>>>>>>                                             with the API stem
>>>>>>>>                                             "OvmsMetrics" it
>>>>>>>>                                             would naturally be
>>>>>>>>                                             expected to mean
>>>>>>>>                                             "is this metric
>>>>>>>>                                             defined", not "does
>>>>>>>>                                             this metric have a
>>>>>>>>                                             defined value".
>>>>>>>>                                             An undefined metric
>>>>>>>>                                             currently can be
>>>>>>>>                                             derived from
>>>>>>>>                                             'Values()'
>>>>>>>>                                             returning
>>>>>>>>                                             undefined, but
>>>>>>>>                                             that's more an
>>>>>>>>                                             undocumented side
>>>>>>>>                                             effect than intended.
>>>>>>>>                                             Maybe
>>>>>>>>                                             'GetDefined()'
>>>>>>>>                                             could be a better
>>>>>>>>                                             name, leveraging
>>>>>>>>                                             this behaviour,
>>>>>>>>                                             i.e. returning
>>>>>>>>                                             'undefined' for an
>>>>>>>>                                             actually undefined
>>>>>>>>                                             metric, and 'null'
>>>>>>>>                                             for a defined
>>>>>>>>                                             metric without a value.
>>>>>>>>                                             Regards,
>>>>>>>>                                             Michael
>>>>>>>>                                             Am 08.11.22 um
>>>>>>>>                                             13:46 schrieb
>>>>>>>>                                             Michael Geddes:
>>>>>>>>>                                             Ah yes. Arrays -
>>>>>>>>>                                             will check those.
>>>>>>>>>                                             Yeah, how about we
>>>>>>>>>                                             add a 'IsDefined'
>>>>>>>>>                                             method to metrics
>>>>>>>>>                                             instead of the
>>>>>>>>>                                             null thing (it
>>>>>>>>>                                             does sound like it
>>>>>>>>>                                             will upset too
>>>>>>>>>                                             many applecarts).
>>>>>>>>>                                             On Tue, 8 Nov 2022
>>>>>>>>>                                             at 20:35, Michael
>>>>>>>>>                                             Balzer
>>>>>>>>>                                             wrote:
>>>>>>>>>                                                 Michael,
>>>>>>>>>                                                 looks all good
>>>>>>>>>                                                 to me, once
>>>>>>>>>                                                 again nice
>>>>>>>>>                                                 find with the
>>>>>>>>>                                                 decode
>>>>>>>>>                                                 argument.
>>>>>>>>>                                                 Adding decode
>>>>>>>>>                                                 to the Value()
>>>>>>>>>                                                 call was only
>>>>>>>>>                                                 for symmetry
>>>>>>>>>                                                 IIRC, the main
>>>>>>>>>                                                 use was with
>>>>>>>>>                                                 GetValues()
>>>>>>>>>                                                 (https://docs.openvehicles.com/en/latest/userguide/scripting.html#ovmsmetrics).
>>>>>>>>>                                                 Don't forget
>>>>>>>>>                                                 to test
>>>>>>>>>                                                 arrays, e.g.
>>>>>>>>>                                                 "v.t.pressure"
>>>>>>>>>                                                 & "v.t.temp".
>>>>>>>>>                                                 Returning null
>>>>>>>>>                                                 for an
>>>>>>>>>                                                 undefined
>>>>>>>>>                                                 metric seems
>>>>>>>>>                                                 like a natural
>>>>>>>>>                                                 choice, but is
>>>>>>>>>                                                 a rather deep
>>>>>>>>>                                                 change, as for
>>>>>>>>>                                                 consistency
>>>>>>>>>                                                 not only the
>>>>>>>>>                                                 Duktape
>>>>>>>>>                                                 metrics API
>>>>>>>>>                                                 but also the
>>>>>>>>>                                                 Web UI metrics
>>>>>>>>>                                                 API would need
>>>>>>>>>                                                 to be changed
>>>>>>>>>                                                 accordingly.
>>>>>>>>>                                                 Unless you've
>>>>>>>>>                                                 got a real use
>>>>>>>>>                                                 case that
>>>>>>>>>                                                 needs that, we
>>>>>>>>>                                                 should be careful.
>>>>>>>>>                                                 Regards,
>>>>>>>>>                                                 Michael
>>>>>>>>>                                                 Am 07.11.22 um
>>>>>>>>>                                                 15:00 schrieb
>>>>>>>>>                                                 Michael Geddes:
>>>>>>>>>>                                                 I have
>>>>>>>>>>                                                 figured out a
>>>>>>>>>>                                                 bunch of
>>>>>>>>>>                                                 stuff and
>>>>>>>>>>                                                 have
>>>>>>>>>>                                                 implemented
>>>>>>>>>>                                                 the
>>>>>>>>>>                                                 following:
>>>>>>>>>>                                                 (having done
>>>>>>>>>>                                                 away with
>>>>>>>>>>                                                 needing
>>>>>>>>>>                                                 AsFloatUnit)
>>>>>>>>>>                                                 OvmsMetrics.Value(
>>>>>>>>>>                                                 {metric} [,
>>>>>>>>>>                                                 {decode}])
>>>>>>>>>>                                                 OvmsMetrics.Value(
>>>>>>>>>>                                                 {metric},
>>>>>>>>>>                                                 {unit}
>>>>>>>>>>                                                 [,{decode}])
>>>>>>>>>>                                                 It turns out
>>>>>>>>>>                                                 that the
>>>>>>>>>>                                                 [decode] flag
>>>>>>>>>>                                                 wasn't
>>>>>>>>>>                                                 working
>>>>>>>>>>                                                 anyway (since
>>>>>>>>>>                                                 the function
>>>>>>>>>>                                                 was being
>>>>>>>>>>                                                 registered as
>>>>>>>>>>                                                 only having 1
>>>>>>>>>>                                                 param)...
>>>>>>>>>>                                                 This way it
>>>>>>>>>>                                                 is still
>>>>>>>>>>                                                 really 1
>>>>>>>>>>                                                 function..
>>>>>>>>>>                                                 but I check
>>>>>>>>>>                                                 it the second
>>>>>>>>>>                                                 parameter is
>>>>>>>>>>                                                 a 'boolean',
>>>>>>>>>>                                                 and if not..
>>>>>>>>>>                                                 try the
>>>>>>>>>>                                                 second form.
>>>>>>>>>>                                                 {metric}
>>>>>>>>>>                                                 [,{unit}] )
>>>>>>>>>>                                                 and add the
>>>>>>>>>>                                                 function
>>>>>>>>>>                                                 Ovms.Metrics.ValueUnit(
>>>>>>>>>>                                                 {metric}
>>>>>>>>>>                                                 [,{unit}])
>>>>>>>>>>                                                 This prints
>>>>>>>>>>                                                 the value and
>>>>>>>>>>                                                 the unit.
>>>>>>>>>>                                                 Here's a
>>>>>>>>>>                                                 sample
>>>>>>>>>>                                                 function and
>>>>>>>>>>                                                 the output!
>>>>>>>>>>                                                 This also
>>>>>>>>>>                                                 shows the
>>>>>>>>>>                                                 types of the
>>>>>>>>>>                                                 output.
>>>>>>>>>>                                                 (function() {
>>>>>>>>>>                                                    x =
>>>>>>>>>>                                                 OvmsMetrics.Value("xiq.v.trip.consumption");
>>>>>>>>>>                                                    print(
>>>>>>>>>>                                                 (typeof x) +
>>>>>>>>>>                                                 ": "+  x+"\n"  );
>>>>>>>>>>                                                    x =
>>>>>>>>>>                                                 false);
>>>>>>>>>>                                                    print(
>>>>>>>>>>                                                 (typeof x) +
>>>>>>>>>>                                                 ": "+  x +"\n" );
>>>>>>>>>>                                                    x =
>>>>>>>>>>                                                    print(
>>>>>>>>>>                                                 (typeof x) +
>>>>>>>>>>                                                 ": "+ x +"\n");
>>>>>>>>>>                                                    x =
>>>>>>>>>>                                                 "mipkwh", false)
>>>>>>>>>>                                                    print(
>>>>>>>>>>                                                 (typeof x) +
>>>>>>>>>>                                                 ": "+ x +"\n");
>>>>>>>>>>                                                    x =
>>>>>>>>>>                                                  OvmsMetrics.ValueUnit("xiq.v.trip.consumption")
>>>>>>>>>>                                                    print(
>>>>>>>>>>                                                 (typeof x) +
>>>>>>>>>>                                                 ": "+ x +"\n");
>>>>>>>>>>                                                    x =
>>>>>>>>>>                                                  OvmsMetrics.ValueUnit("xiq.v.trip.consumption","mipkwh")
>>>>>>>>>>                                                    print(
>>>>>>>>>>                                                 (typeof x) +
>>>>>>>>>>                                                 ": "+ x +"\n");
>>>>>>>>>>                                                    x =
>>>>>>>>>>                                                    print(
>>>>>>>>>>                                                 (typeof x) +
>>>>>>>>>>                                                 ": "+ x +"\n");
>>>>>>>>>>                                                    x =
>>>>>>>>>>                                                    print(
>>>>>>>>>>                                                 (typeof x) +
>>>>>>>>>>                                                 ": "+ x +"\n");
>>>>>>>>>>                                                 number: 17.0582
>>>>>>>>>>                                                 string: 17.0582
>>>>>>>>>>                                                 number: 5.86227
>>>>>>>>>>                                                 string: 3.64264
>>>>>>>>>>                                                 string: 17.0582kWh/100km
>>>>>>>>>>                                                 string: 3.64264mi/kWh
>>>>>>>>>>                                                 number: 17.0582
>>>>>>>>>>                                                 number: 5.86227
>>>>>>>>>>                                                 It still
>>>>>>>>>>                                                 might be an
>>>>>>>>>>                                                 idea to use
>>>>>>>>>>                                                 'null' as a
>>>>>>>>>>                                                 return value
>>>>>>>>>>                                                 if the
>>>>>>>>>>                                                 metrics
>>>>>>>>>>                                                 is!IsDefined()
>>>>>>>>>>                                                 but that
>>>>>>>>>>                                                 would be
>>>>>>>>>>                                                 changing the
>>>>>>>>>>                                                 existing
>>>>>>>>>>                                                 behaviour
>>>>>>>>>>                                                 slightly.
>>>>>>>>>>                                                 //.ichael
>>>>>>>>>>                                                 On Mon, 7 Nov
>>>>>>>>>>                                                 2022 at
>>>>>>>>>>                                                 08:12,
>>>>>>>>>>                                                 Michael
>>>>>>>>>>                                                 Geddes
>>>>>>>>>>                                                 wrote:
>>>>>>>>>>                                                     I've
>>>>>>>>>>                                                     worked
>>>>>>>>>>                                                     out what
>>>>>>>>>>                                                     the
>>>>>>>>>>                                                     decode
>>>>>>>>>>                                                     flag is
>>>>>>>>>>                                                     for and
>>>>>>>>>>                                                     how it
>>>>>>>>>>                                                     works,
>>>>>>>>>>                                                     and I
>>>>>>>>>>                                                     think how
>>>>>>>>>>                                                     optional
>>>>>>>>>>                                                     params work.
>>>>>>>>>>                                                     I'm
>>>>>>>>>>                                                     pretty
>>>>>>>>>>                                                     sure I
>>>>>>>>>>                                                     won't
>>>>>>>>>>                                                     need the
>>>>>>>>>>                                                     'AsFloatUnit'
>>>>>>>>>>                                                     function;
>>>>>>>>>>                                                     the unit
>>>>>>>>>>                                                     would be
>>>>>>>>>>                                                     an option
>>>>>>>>>>                                                     to
>>>>>>>>>>                                                     AsFloat();
>>>>>>>>>>                                                     I'll know
>>>>>>>>>>                                                     that soon.
>>>>>>>>>>                                                     The
>>>>>>>>>>                                                     'Value'
>>>>>>>>>>                                                     function
>>>>>>>>>>                                                     is more
>>>>>>>>>>                                                     complicated
>>>>>>>>>>                                                     because
>>>>>>>>>>                                                     of the
>>>>>>>>>>                                                     optional
>>>>>>>>>>                                                     decode
>>>>>>>>>>                                                     bool. I
>>>>>>>>>>                                                     guess I
>>>>>>>>>>                                                     could add
>>>>>>>>>>                                                     the Unit
>>>>>>>>>>                                                     to the
>>>>>>>>>>                                                     end of that.
>>>>>>>>>>                                                     ValueUnit
>>>>>>>>>>                                                     could be
>>>>>>>>>>                                                     still
>>>>>>>>>>                                                     useful
>>>>>>>>>>                                                     then to
>>>>>>>>>>                                                     provide a
>>>>>>>>>>                                                     'Value +
>>>>>>>>>>                                                     Unit'.
>>>>>>>>>>                                                     Question:
>>>>>>>>>>                                                     Is there
>>>>>>>>>>                                                     a reason
>>>>>>>>>>                                                     we
>>>>>>>>>>                                                     shouldn't
>>>>>>>>>>                                                     be
>>>>>>>>>>                                                     returning
>>>>>>>>>>                                                     with
>>>>>>>>>>                                                     duk_push_null
>>>>>>>>>>                                                       if the
>>>>>>>>>>                                                     metric
>>>>>>>>>>                                                     !IsDefined()
>>>>>>>>>>                                                     in both
>>>>>>>>>>                                                     AsFloat()
>>>>>>>>>>                                                     and
>>>>>>>>>>                                                     Value(metric,true)
>>>>>>>>>>                                                     cases?
>>>>>>>>>>                                                     //.ichael
>>>>>>>>>>                                                     On Sun, 6
>>>>>>>>>>                                                     Nov 2022
>>>>>>>>>>                                                     at 11:22,
>>>>>>>>>>                                                     Michael
>>>>>>>>>>                                                     Geddes
>>>>>>>>>>                                                     wrote:
>>>>>>>>>>                                                         Right,
>>>>>>>>>>                                                         so
>>>>>>>>>>                                                         I've
>>>>>>>>>>                                                         implemented
>>>>>>>>>>                                                         some
>>>>>>>>>>                                                         stuff
>>>>>>>>>>                                                         that
>>>>>>>>>>                                                         seems
>>>>>>>>>>                                                         to
>>>>>>>>>>                                                         work
>>>>>>>>>>                                                         quite
>>>>>>>>>>                                                         well.
>>>>>>>>>>                                                         https://github.com/openvehicles/Open-Vehicle-Monitoring-System-3/pull/764
>>>>>>>>>>                                                         should
>>>>>>>>>>                                                         be
>>>>>>>>>>                                                         ready
>>>>>>>>>>                                                         now
>>>>>>>>>>                                                         after
>>>>>>>>>>                                                         a
>>>>>>>>>>                                                         couple
>>>>>>>>>>                                                         of
>>>>>>>>>>                                                         stupid
>>>>>>>>>>                                                         mistakes
>>>>>>>>>>                                                         slipped
>>>>>>>>>>                                                         through.
>>>>>>>>>>                                                          This
>>>>>>>>>>                                                         absolutely
>>>>>>>>>>                                                         needs
>>>>>>>>>>                                                         somebody
>>>>>>>>>>                                                         to
>>>>>>>>>>                                                         review
>>>>>>>>>>                                                         it
>>>>>>>>>>                                                         please!
>>>>>>>>>>                                                         (There's
>>>>>>>>>>                                                         a
>>>>>>>>>>                                                         reason
>>>>>>>>>>                                                         why
>>>>>>>>>>                                                         I've
>>>>>>>>>>                                                         converted
>>>>>>>>>>                                                         some
>>>>>>>>>>                                                         if()'s
>>>>>>>>>>                                                         to
>>>>>>>>>>                                                         switch()
>>>>>>>>>>                                                         which
>>>>>>>>>>                                                         is
>>>>>>>>>>                                                         that
>>>>>>>>>>                                                         it
>>>>>>>>>>                                                         will
>>>>>>>>>>                                                         be
>>>>>>>>>>                                                         used
>>>>>>>>>>                                                         in
>>>>>>>>>>                                                         the
>>>>>>>>>>                                                         follow-up
>>>>>>>>>>                                                         commit).
>>>>>>>>>>                                                         The
>>>>>>>>>>                                                         commit
>>>>>>>>>>                                                         that
>>>>>>>>>>                                                         will
>>>>>>>>>>                                                         follow
>>>>>>>>>>                                                         on
>>>>>>>>>>                                                         from
>>>>>>>>>>                                                         that
>>>>>>>>>>                                                         it
>>>>>>>>>>                                                         implements
>>>>>>>>>>                                                         the
>>>>>>>>>>                                                         new
>>>>>>>>>>                                                         Units:
>>>>>>>>>>                                                         kWh/100km,
>>>>>>>>>>                                                         km/kWh
>>>>>>>>>>                                                         and
>>>>>>>>>>                                                         mi/kWh.
>>>>>>>>>>                                                         This
>>>>>>>>>>                                                         is a
>>>>>>>>>>                                                         summary
>>>>>>>>>>                                                         of
>>>>>>>>>>                                                         what
>>>>>>>>>>                                                         I've
>>>>>>>>>>                                                         implemented
>>>>>>>>>>                                                         for
>>>>>>>>>>                                                         scripting
>>>>>>>>>>                                                         including
>>>>>>>>>>                                                         showing
>>>>>>>>>>                                                         the
>>>>>>>>>>                                                         unit
>>>>>>>>>>                                                         codes
>>>>>>>>>>                                                         I
>>>>>>>>>>                                                         have
>>>>>>>>>>                                                         so far.
>>>>>>>>>>                                                         I've
>>>>>>>>>>                                                         considered
>>>>>>>>>>                                                         a few
>>>>>>>>>>                                                         things:
>>>>>>>>>>                                                         Should
>>>>>>>>>>                                                         some
>>>>>>>>>>                                                         of
>>>>>>>>>>                                                         the
>>>>>>>>>>                                                         longer
>>>>>>>>>>                                                         unit
>>>>>>>>>>                                                         codes
>>>>>>>>>>                                                         be
>>>>>>>>>>                                                         shortened
>>>>>>>>>>                                                         (eg
>>>>>>>>>>                                                         mi,
>>>>>>>>>>                                                         mins,
>>>>>>>>>>                                                         m,
>>>>>>>>>>                                                         ft,
>>>>>>>>>>                                                         deg,
>>>>>>>>>>                                                         perc)
>>>>>>>>>>                                                         The
>>>>>>>>>>                                                         unit
>>>>>>>>>>                                                         codes
>>>>>>>>>>                                                         could
>>>>>>>>>>                                                         be
>>>>>>>>>>                                                         much
>>>>>>>>>>                                                         more
>>>>>>>>>>                                                         regular
>>>>>>>>>>                                                         and
>>>>>>>>>>                                                         separated
>>>>>>>>>>                                                         by
>>>>>>>>>>                                                         dots
>>>>>>>>>>                                                         eg:
>>>>>>>>>>                                                         watthours
>>>>>>>>>>                                                         -> w.h
>>>>>>>>>>                                                         kwhp100km
>>>>>>>>>>                                                         kw.h_100km
>>>>>>>>>>                                                         or
>>>>>>>>>>                                                         kw.h/100km
>>>>>>>>>>                                                         miph
>>>>>>>>>>                                                         mi_h
>>>>>>>>>>                                                         or
>>>>>>>>>>                                                         mi/h
>>>>>>>>>>                                                         (or
>>>>>>>>>>                                                         should
>>>>>>>>>>                                                         it be
>>>>>>>>>>                                                         mph).
>>>>>>>>>>                                                         psi
>>>>>>>>>>                                                         p_in.in
>>>>>>>>>>                                                         <http://p_in.in/>
>>>>>>>>>>                                                         or
>>>>>>>>>>                                                         p/in.in
>>>>>>>>>>                                                         <http://in.in/>
>>>>>>>>>>                                                         or
>>>>>>>>>>                                                         lb_in.in
>>>>>>>>>>                                                         <http://lb_in.in/>
>>>>>>>>>>                                                         (yes,
>>>>>>>>>>                                                         slightly
>>>>>>>>>>                                                         weird,
>>>>>>>>>>                                                         but
>>>>>>>>>>                                                         predictable)
>>>>>>>>>>                                                         *OVMS#
>>>>>>>>>>                                                         metric
>>>>>>>>>>                                                         units*
>>>>>>>>>>                                                           km : km
>>>>>>>>>>                                                          miles
>>>>>>>>>>                                                         : M
>>>>>>>>>>                                                         meters
>>>>>>>>>>                                                         : m
>>>>>>>>>>                                                         feet : ft
>>>>>>>>>>                                                          celcius
>>>>>>>>>>                                                         : °C
>>>>>>>>>>                                                         fahrenheit
>>>>>>>>>>                                                         : °F
>>>>>>>>>>                                                          kpa
>>>>>>>>>>                                                         : kPa
>>>>>>>>>>                                                           pa : Pa
>>>>>>>>>>                                                          psi
>>>>>>>>>>                                                         : psi
>>>>>>>>>>                                                          volts
>>>>>>>>>>                                                         : V
>>>>>>>>>>                                                         amps : A
>>>>>>>>>>                                                         amphours:
>>>>>>>>>>                                                         Ah
>>>>>>>>>>                                                           kw : kW
>>>>>>>>>>                                                          kwh
>>>>>>>>>>                                                         : kWh
>>>>>>>>>>                                                          watts
>>>>>>>>>>                                                         : W
>>>>>>>>>>                                                         watthours:
>>>>>>>>>>                                                         Wh
>>>>>>>>>>                                                          seconds
>>>>>>>>>>                                                         : Sec
>>>>>>>>>>                                                          minutes
>>>>>>>>>>                                                         : Min
>>>>>>>>>>                                                          hours
>>>>>>>>>>                                                         : Hour
>>>>>>>>>>                                                          utc
>>>>>>>>>>                                                         : UTC
>>>>>>>>>>                                                          degrees
>>>>>>>>>>                                                         kmph
>>>>>>>>>>                                                         : km/h
>>>>>>>>>>                                                         miph: Mph
>>>>>>>>>>                                                         kmphps:
>>>>>>>>>>                                                         km/h/s
>>>>>>>>>>                                                         miphps:
>>>>>>>>>>                                                         Mph/s
>>>>>>>>>>                                                         mpss
>>>>>>>>>>                                                         : m/s²
>>>>>>>>>>                                                          dbm
>>>>>>>>>>                                                         : dBm
>>>>>>>>>>                                                           sq : sq
>>>>>>>>>>                                                          percent
>>>>>>>>>>                                                          whpkm
>>>>>>>>>>                                                         : Wh/km
>>>>>>>>>>                                                         whpmi:
>>>>>>>>>>                                                         Wh/mi
>>>>>>>>>>                                                          kwhp100km
>>>>>>>>>>                                                         kWh/100km
>>>>>>>>>>                                                         kmpkwh:
>>>>>>>>>>                                                         km/kWh
>>>>>>>>>>                                                         mipkwh:
>>>>>>>>>>                                                         mi/kWh
>>>>>>>>>>                                                           nm : Nm
>>>>>>>>>>                                                         *OVMS#
>>>>>>>>>>                                                         metric
>>>>>>>>>>                                                         unit mi*
>>>>>>>>>>                                                          miles
>>>>>>>>>>                                                         : M
>>>         _______________________________________________
>>>         OvmsDev mailing list
>>>         OvmsDev at lists.openvehicles.com
>>>         http://lists.openvehicles.com/mailman/listinfo/ovmsdev
>>         Michael Balzer * Helkenberger Weg 9 * D-58256 Ennepetal
>>         Fon 02333 / 833 5735 * Handy 0176 / 206 989 26
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20221213/3bbba277/attachment-0001.htm>
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20221213/3bbba277/attachment-0001.sig>
