[Ovmsdev] Automatic naming of CAN log files
    Ludovic LANGE
    ll-ovmsdev at lange.nom.fr
    Sat Dec  3 06:31:45 HKT 2022
Hi Michael,
Thanks for your encouraging feedback !
A few points:
> I assume "vfs-auto" will set another config instance to enable
> continuation after a crash/reboot?
In fact not at the moment :-) Based on the discussion we had in
https://github.com/openvehicles/Open-Vehicle-Monitoring-System-3/issues/766
, I settled on the attachment to `sd.*` events to start/stop the log.
It's working OK for the moment and starts as soon as the system is up
and SC card mounted.
> Please avoid "_" on event names.
Any technical reason for that ? Or is it for consistency ?
Should I replace with '-' or just have `can.log.rotatefiles` ?
> Maybe you should raise e.g. "can.log.rotate.pre" synchronously before
> the actual rotation, so handlers can add some last info to the file,
> and "can.log.rotate.post" after.
Interesting. How could we ensure that all handlers have finished
handling the event ? Waiting for some time ? I'm a little bit concerned
of having to introduce delay in the rotation itself, not wanting to drop
events.
> Adding a status dump before closing a file would be good so you can
> see if there were drops
Yes, that's useful to close the file with a dump of stats and counters.
(And you're right about clearing them)
> A command to log arbitrary comments would also make sense, that could
> be used by users and scripts.
Indeed. Maybe as a broadcast to all open logs, and/or having the option
to send the comments to a specific log.
Do you feel we should have all those features (pre/post events, status
dump, log comment, your previous suggestion of file logging sync period)
ready for a first PR candidate ? Or would you prefer that we try to
polish the first functionality (some docs are needed, event naming),
create a first PR, and then add incrementally those features as PRs ?
Ludovic
Le 02/12/2022 à 20:15, Michael Balzer a écrit :
> Ludovic,
> this is far more than I ever needed for my vehicle CAN logging, but I
> can see this making sense in vehicle or ECU development, and in
> gathering initial data for reverse engineering from users in the
> field. With this, users can easily collect data over a couple of days
> taking photos & notes, and then send the collected data to the
> developer. That's currently hard to do, as users would need to monitor
> & manage the continuous logging.
> Your config scheme looks appropriate. I assume "vfs-auto" will set
> another config instance to enable continuation after a crash/reboot?
> Please avoid "_" on event names. Maybe you should raise e.g.
> "can.log.rotate.pre" synchronously before the actual rotation, so
> handlers can add some last info to the file, and "can.log.rotate.post"
> after.
> see if there were drops. That currently needs a "can canX status" to
> be triggered. Maybe clearing the counters on transition to the next
> file then also makes sense.
> Am 26.11.22 um 23:31 schrieb Ludovic LANGE:
>> Hi,
>> To follow on this previous idea, I'd like to share a Proof Of Concept
>> of my proposal in the `748-split-can-log-files` branch for comments -
>> you can see the diff here
>> https://github.com/openvehicles/Open-Vehicle-Monitoring-System-3/compare/master...llange:Open-Vehicle-Monitoring-System-3:748-split-can-log-files
>> It does not (yet !) include all the suggestions received - notably
>> absent is the proposal of file logging sync period from Michael below
>> - but I'll try to take them into account.
>> There is an open issue
>> https://github.com/openvehicles/Open-Vehicle-Monitoring-System-3/issues/748
>> to gather public comments regarding the code if you prefer to do it
>> on GitHub.
>> (When talking of automatic naming, I mean in fact automatic file name
>> rotation based on different criterion)
>> Here it is:
>>   * A new command is introduced `can log start vfs-auto` which is
>>     exactly like `can log start vfs` but, you guessed it, with
>>     automatic file name rotation
>>       o The parameter to this command is not a file name any more,
>>         but a `prefix` (see below)
>>   * New configuration items are introduced:
>>       o `[can] log.file.maxsize_kb` : if the log file size exceeds
>>         this number, the file will be rotated
>>       o `[can] log.file.maxduration_s` : if the log file has logged
>>         for more than (this number) seconds, the file will be rotated
>>       o `[can] log.file.keep_empty` : in case a rotation would have
>>         created an empty file (no messages), should we rotate
>>         nevertheless (`true`) or not (`false`) ?
>>       o `[can] log.file.pattern` : this describes how to name the
>>         file with some variables (see below)
>>   * A new event `can.log.rotate_files` is introduced to allow one to
>>     force a file name rotation
>> The file name (`log.file.pattern`) can be configured with
>> (combination of) the following elements:
>>   * `strftime` format conversion specification (like`%Y` `%H` ...)
>>   * `{vehicleid}` will be replaced by the configured vehicle id
>>   * `{session}` will be replaced by the counter of restarts of the
>>     module (always incrementing) (See
>>     https://github.com/openvehicles/Open-Vehicle-Monitoring-System-3/pull/779
>>     for a discussion, will certainly evolve)
>>   * `{prefix}` is the argument to the log command `can log start
>>     vfs-auto <format> <prefix>`, so that you can configure multiple
>>     logs in parallel and have them log to different files (by varying
>>     `prefix`)
>>   * `{splits}` is a counter of the number of cycles that occurred to
>>     this very log file
>>   * `{extension}` is the preferred extension for the chosen log format
>> (Any non-existing directory will be created on the go during file
>> rotation)
>> The default for these variables are:
>> OVMS# con lis can
>> can (readable writeable)
>>   log.file.keep_empty: false
>>   log.file.maxduration_s: 1800
>>   log.file.maxsize_kb: 1024
>>   log.file.pattern:
>> /sd/log/{vehicleid}/{session}/{prefix}/{splits}-%Y%m%d-%H%M%S{extension}
>> To illustrate a sequence of file name rotation, here is an excerpt
>> with smaller values (maxduration: 120s / maxsize : 2kb), started by
>> the command `can log start vfs-auto crtd essai`.
>> The first two renames occur because of maxduration (>= 120s) while
>> the third rename occur because the log file exceeded 2048 bytes.
>> (In addition, SNTP synchro occurred just before the first rename, so
>> you see that the first file segment is dated 1970... while the second
>> one has proper date and time)
>> I (119937) canlog-vfs: canlog_vfs_autonaming::OutputMsg() size:172,
>> log duration: 120s
>> I (119957) canlog-vfs: Closed vfs log
>> '/sd/log/ovms-vehicle/00000390/essai/00000001-19700101-010008.crtd':
>> Size:172 Messages:2 Dropped:0 Filtered:0 Rate:0.0%
>> I (119967) canlog-vfs: Changing file name from
>> to '/sd/log/ovms-vehicle/00000390/essai/00000002-20221126-155952.crtd'
>> I (119977) canlog-vfs: Now logging CAN messages to
>> I (239967) canlog-vfs: canlog_vfs_autonaming::OutputMsg() size:1943,
>> log duration: 120s
>> I (239987) canlog-vfs: Closed vfs log
>> '/sd/log/ovms-vehicle/00000390/essai/00000002-20221126-155952.crtd':
>> Size:1.9k Messages:22 Dropped:0 Filtered:0 Rate:0.0%
>> I (239997) canlog-vfs: Changing file name from
>> to '/sd/log/ovms-vehicle/00000390/essai/00000003-20221126-160152.crtd'
>> I (240007) canlog-vfs: Now logging CAN messages to
>> I (334967) canlog-vfs: canlog_vfs_autonaming::OutputMsg() size:2111,
>> log duration: 95s
>> I (334987) canlog-vfs: Closed vfs log
>> '/sd/log/ovms-vehicle/00000390/essai/00000003-20221126-160152.crtd':
>> Size:2.1k Messages:24 Dropped:0 Filtered:0 Rate:0.0%
>> I (334997) canlog-vfs: Changing file name from
>> to '/sd/log/ovms-vehicle/00000390/essai/00000004-20221126-160327.crtd'
>> I (335007) canlog-vfs: Now logging CAN messages to
>> OVMS# vfs rls /sd/log/ovms-vehicle/00000390/essai/
>>      172  26-Nov-2022 15:59
>>     1.9k  26-Nov-2022 16:01
>>     2.1k  26-Nov-2022 16:03
>>        0  30-Nov-1979 00:00
>> Notes:
>>   * maxsize comparisons are done after writing, which means that you
>>     will have files slightly bigger than maxsize - not under maxsize.
>>     (for maxduration however it should be OK as the comparison is
>>     done before writing)
>>   * While the comparison of maxsize is done on the real number of
>>     bytes written, the concept of empty file (for `[can]
>>     log.file.keep_empty`) is based on the number of messages logged
>>     to the file.
>>     This, because most of the files will have a header written even
>>     if no messages are written ; which I considered to be
>>     nevertheless an empty file.
>>     Those "empty" files with no messages will not be rotated in that
>>     case (and kept open for logging).
>> Let me know what you think of this, if you have some remarks, and
>> even if you feel it has no interest whatsoever.
>> Ludovic
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20221202/b1a52a65/attachment-0001.htm>
