[Ovmsdev] Doubs in implementation with nodejs.
gregg hansen gregg at rabbitev.com
Thu Aug 4 11:21:11 HKT 2022
This is the library we are using it encrypt some data and use the MP
commands to call some functionalities to the car with this we retrieve some
data like the battery status.
NPM Lib
https://www.npmjs.com/package/ovms-client?activeTab=readme
Github
https://github.com/birkir/ovms-client
(in the Github is an instruction that explains how does the library works)
It has a function to send shell commands like 'stat' commands, but when we
send a command looks like the car is receiving the command but it seems
like the car gets the commands but does not interact with it.
There is other function that allows us to send raw data to the car that is
the MP commands, but in this case when I send a Raw command this don't
connect with the car and its stock loading waiting for a response that is
never returned.
I have been trying to make a script that lets me connect to the car, but I
only could connect to the ovms-server that let us make the connection with
the car, but I can not set the carId and password on that socket to make
the connection to the car.
We are using OVMS v2 in the cars.
Thanks for your help and we are going to be glad to read you answers
On Wed, Aug 3, 2022 at 10:07 PM Mark Webb-Johnson <mark at webb-johnson.net>
wrote:
> Gregg,
> We really need to know exactly what he is doing, and with what protocols.
> From the way you seem to describe it, you:
>    1. Have a custom app, in react native
>    2. You have a custom server, in NodeJS
>    3. You presumably have some custom protocol/api between your app and
>    server
>    4. Your NodeJS server is talking to the OVMS server using your own
>    implementation of v2 protocol
> Is that correct? If so, then #4 is the only issue. The V2 protocol is
> fairly well documented, here:
> https://docs.openvehicles.com/en/latest/protocol_v2/index.html
> It is proprietary and the initial negotiation is complicated, but if you
> have established the crypto connection and received the data, then you have
> done the hard part. Issuing commands should be easy.
> In v2 protocol, locking/unlocking is performed via the ā€œCā€ command.
> Probably easiest to look at the sample code in the iOS or Android Apps to
> see how that is done. For iOS, see:
> https://github.com/openvehicles/Open-Vehicle-iOS/blob/master/OpenVehicleApp/ovms/ovmsAppDelegate.m
> (The commandIssue method, and how it is called)
> On 3 Aug 2022, at 11:03 PM, gregg hansen <gregg at rabbitev.com> wrote:
> Pablo has not been able to access the list.  He is getting authentication
> errors, so while he works through that I thought I would answer for him...
> "The MP commands are the raw data I am trying to send to the car to open
> and close the car."
> The devices are using the V2 server, so I think fixed MP commands make the
> most sense.  Pablo is trying to figure out how to make that work, and so
> far has not been successful.
> On Sun, Jul 31, 2022 at 2:26 AM Michael Balzer <dexter at expeedo.de> wrote:
>> Pablo,
>> a bit more information on how you connect to the car would be helpful
>> here.
>> Arbitrary remote shell command execution is supported by the module's
>> HTTP API (/api/execute), the module's SSH server, the "V2 protocol" server
>> via MP command 7 and any "V3" (MQTT) server via the /client/command topic
>> scheme. Plus there's a secondary (non-standard) HTTP command API available
>> on my server ovms.dexters-web.de (public API of my custom web shell).
>> Lock & unlock are also available as fixed MP commands (20,22) on a V2
>> server, along with a set of other standard App calls. These do not run via
>> the shell but translate to direct internal execution.
>> Command execution has not yet been implemented for the "V2" server's HTTP
>> API. But you can of course implement that if you use that API.
>> Docs:
>>    https://docs.openvehicles.com/en/latest/components/ovms_webserver/docs/index.html#authorization
>>    https://docs.openvehicles.com/en/latest/userguide/console.html#ssh-console
>>    https://docs.openvehicles.com/en/latest/protocol_v2/commands.html#execute-sms-command
>>       https://docs.openvehicles.com/en/latest/protocol_v2/commands.html#lock-car
>>       https://docs.openvehicles.com/en/latest/protocol_v2/commands.html#unlock-car
>>    http://lists.openvehicles.com/pipermail/ovmsdev/2018-July/012641.html
>>    http://lists.openvehicles.com/pipermail/ovmsdev/2018-July/012696.html
>>    https://docs.openvehicles.com/en/latest/protocol_httpapi/requests.html#not-yet-implemented
>> Which one are you referring to?
>> Am 29.07.22 um 19:28 schrieb Pablo Cabrera:
>> Hello OVMS team, we are currently working with an implementation with
>> OVMS in a react native app with a NodeJS back-end.
>> Currently we can connect with the cars and rescue some data like the
>> status of the battery or GPS location, but now we need to send commands to
>> lock and unlock the cars from the same app, when we send a command I get a
>> response that the command is received in the car, but the command is not
>> executed in the bash.
>> I don't know if you can send me more info about how to make the car
>> receive bash commands from remote connections, or how can I send it from
>> the NodeJs server into the bash of the car.
>> Thanks for your time and help.
>> OvmsDev mailing listOvmsDev at lists.openvehicles.comhttp://lists.openvehicles.com/mailman/listinfo/ovmsdev
>> Michael Balzer * Helkenberger Weg 9 * D-58256 Ennepetal <https://www.google.com/maps/search/Helkenberger+Weg+9+*+D-58256+Ennepetal?entry=gmail&source=g>
> RabbitEV
> Driving Electric Cars
> RabbitEV.com
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20220803/12c6a36c/attachment-0001.htm>
