[Ovmsdev] Urgent TLS root certificate issue (Let's Encrypt)
    Thu Sep 30 14:02:32 HKT 2021
Scott Helme has written some excellent articles on this:
  * https://scotthelme.co.uk/lets-encrypt-to-transition-to-isrg-root/
  * https://scotthelme.co.uk/lets-encrypt-old-root-expiration/
Am 30.09.21 um 07:02 schrieb Mark Webb-Johnson:
> Brian,
> Let’s Encrypt say that because there are a lot of embedded devices that do not update firmware / trusted CA lists, they did it this way. They are also worried about older Android devices that can’t be updated.
> IMHO, they made a bigger mess of it by using cross-signing and introducing SSL/TLS library compatibility issues. The X3 trusted CA cert that was expiring could have simply been renewed without requiring a new one, and maintaining compatibility and a smooth transition. These CA certs are self-signed anyway, so you can do whatever you want with them (and I’ve done the 10 year re-sign twice already for my day-job primary CA).
>> On 30 Sep 2021, at 12:42 PM, HONDA S2000 <s2000 at audiobanshee.com> wrote:
>> Sorry to jump in the middle (end?) of a long thread...
>> Working on another system at work a couple of years ago with embedded security, I recall a couple of topics from the design meetings.
>> 1) Certificate handling should be designed to allow for a transition period where two equivalent certificates are valid at the same time. That's because it's almost impossible to roll out a certificate change in the deployed fleet if only one can be valid at a time. The duration of the overlap needs to be long enough for all systems to transition, and only then can the old certs be removed.
>> 2) Intermediate certificates are what enables these changes. The top or root cert is usually too protected to allow easy changes, or managed by another entity, so the team / project gets an intermediate that can be used to sign multiple leaf certs with varying expirations.
>> Leaf certs change relatively quickly, while intermediates change relatively infrequently. In both cases, some overlap time needs to be supported. I suppose this means that the root cert also needs a plan for transition that doesn't abruptly cut off all working systems.
>> Unfortunately, you probably already know all of this, and I'm just not familiar with how OVMS handles certs. But basically, I'm wondering whether a smoother transition can be designed around the *next* expiration. ... or is this something that Let's Encrypt didn't plan for?
>> Brian Willoughby
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20210930/2f3ecdc1/attachment.htm>
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20210930/2f3ecdc1/attachment.sig>
