[Ovmsdev] Urgent TLS root certificate issue (Let's Encrypt)
    Stephen Casner
    casner at acm.org
    Thu Sep 30 07:34:11 HKT 2021
On Wed, 29 Sep 2021, Craig Leres wrote:
> And I assume switching to mbedTLS is why I can no longer use https with my
> modules? Is there any reason I can't just continue using wolfssl?
If the certificates you are using work with WolfSSL (and will continue
to do so), then go ahead and build with the configuration changed to
use WolfSSL.
