[Ovmsdev] Urgent TLS root certificate issue (Let's Encrypt)
    Stephen Casner
    casner at acm.org
    Wed Sep 29 03:53:47 HKT 2021
I wonder if we are hitting a key size limit in the WolfSSL code.  I
know there are configuration parameters in user_settings.h for
different SHA sizes, but I don't recall one for RSA keys.
On Tue, 28 Sep 2021, Michael Balzer wrote:
> Still no luck, and getting clueless... :-/
> Let's Encrypt have a live test server:
> https://valid-isrgrootx1.letsencrypt.org/
> Here's a simple test script to access that server:
> (function(){
>     HTTP.request({
>       url: "https://valid-isrgrootx1.letsencrypt.org/",
>       always: function() { JSON.print(this); }
> Just copy this into the editor and evaluate.
> After commenting out the DST certificate from the TLS source, the http request
> terminates with an SSL error (-3) with installed...
>  * self-signed ISRG certificate
>  * cross-signed ISRG / DST root certificate
>  * LE R3 certificate
>  * any combination of these three.
> But the access works immediately after reinstalling the old DST root
> certificate. There is no DST reference in the chain of that server...
> I found another ESP32 project -- not using WolfSSL but the esp-idf SSL & MQTT
> lib --; apparently all they needed to do was to add the very same self-signed
> ISRG X1 certificate I added:
> https://github.com/LibreSolar/esp32-edge-firmware/commit/d6b6307cbdb60feb118355fda973eba11d52f8f5
> So: why would WolfSSL not use the supplied ISRG certificate? Why would it use
> the DST cert without DST being present as an issuer?
> The ISRG certificate is the only one having...
>   signed using      : RSA with SHA-256
>   RSA key size      : 4096 bits
> But that would surely be supported by WolfSSL, wouldn't it?
> I'm running out of ideas, and this really isn't my primary area. Any help is
> appreciated.
> Am 28.09.21 um 19:15 schrieb Stephen Casner:
> > Michael,
> > Certainly within our code as it stands there is not any mechanism to
> > tell the WolfSSL code to adjust its certificate validation procedure.
> > The browser certificate substitution that you hypothesize is not clear
> > to me.  I would expect the validation to simply follow the chain.
> >                                                          -- Steve
> > > More info:
> > > All my browsers already have a builtin ISRG X1 certificate signed by ISRG
> > > only, that's the new version:
> > > https://crt.sh/?id=9314791
> > > My server still sends the ISRG X1 certificate cross signed / issued by DST
> > > Root CA X3. That's the chain it got from Let's Encrypt (via certbot) on
> > > the
> > > last renewal (last month!):
> > > https://crt.sh/?id=3958242236
> > > Without the DST root cert, WolfSSL then fails validating the DST signed X1
> > > root certificate (I assume):
> > > https://www.wolfssl.com/docs/wolfssl-manual/ch7/
> > > My servers will continue sending that chain including the outdated root
> > > cert
> > > probably until the next renewal, so it's possible having added the new X1
> > > root
> > > certificate didn't solve the issue.
> > > The browsers seem to know how to substitute the DST signed certificate by
> > > the
> > > builtin self-signed (?). Is there a similar option in WolfSSL, and do we
> > > need
> > > to enable that?
> > > Steve, can you confirm this, do you know a solution?
> > > Regards,
> > > Michael
> > > Am 28.09.21 um 15:34 schrieb Michael Balzer:
> > > > I've tried adding the intermediate cert ("R3") and then also my site
> > > > certificate, that didn't help.
> > > > Only adding the DST cert again fixes the connection.
> > > > Any ideas?
> > > > OVMS# tls trust list
> > > > ISRG Root X1 length 1939 bytes
> > > > 1939 byte certificate: ISRG Root X1
> > > >    cert. version     : 3
> > > >    serial number     : 82:10:CF:B0:D2:40:E3:59:44:63:E0:BB:63:82:8B:00
> > > >    issuer name       : C=US, O=Internet Security Research Group, CN=ISRG
> > > > Root
> > > > X1
> > > >    subject name      : C=US, O=Internet Security Research Group, CN=ISRG
> > > > Root
> > > > X1
> > > >    issued  on        : 2015-06-04 11:04:38
> > > >    expires on        : 2035-06-04 11:04:38
> > > >    basic constraints : CA=true
> > > >    key usage         : Key Cert Sign, CRL Sign
> > > > dexter length 1972 bytes
> > > > 1972 byte certificate: dexter
> > > >    cert. version     : 3
> > > >    serial number     :
> > > > 04:55:1D:F4:27:A3:7D:E9:E4:A8:5C:37:F6:A1:61:87:3C:E5
> > > >    issuer name       : C=US, O=Let's Encrypt, CN=R3
> > > >    subject name      : CN=dexter.shopdriver.de
> > > >    issued  on        : 2021-08-07 05:47:57
> > > >    expires on        : 2021-11-05 05:47:55
> > > >    RSA key size      : 2048 bits
> > > >    basic constraints : CA=false
> > > >    subject alt name  : dexter.shopdriver.de, dexters-web.de,
> > > > ovms.dexters-web.de, www.dexter.shopdriver.de, www.dexters-web.de
> > > >    key usage         : Digital Signature, Key Encipherment
> > > >    ext key usage     : TLS Web Server Authentication, TLS Web Client
> > > > Authentication
> > > > r3 length 1826 bytes
> > > > 1826 byte certificate: r3
> > > >    cert. version     : 3
> > > >    serial number     : 91:2B:08:4A:CF:0C:18:A7:53:F6:D6:2E:25:A7:5F:5A
> > > > Root
> > > > X1
> > > >    subject name      : C=US, O=Let's Encrypt, CN=R3
> > > >    issued  on        : 2020-09-04 00:00:00
> > > >    expires on        : 2025-09-15 16:00:00
> > > >    basic constraints : CA=true, max_pathlen=0
> > > >    key usage         : Digital Signature, Key Cert Sign, CRL Sign
> > > >    ext key usage     : TLS Web Client Authentication, TLS Web Server
> > > > Authentication
> > > > Am 28.09.21 um 15:07 schrieb Michael Balzer:
> > > > > We would need to bypass / shortcut the "eap" test phase.
> > > > > But I agree, "master" is stable, I haven't had any issues or reports,
> > > > > so I
> > > > > think we could do that. The FreeRTOS timer issue I'm working on only
> > > > > affects very specific conditions, so not necessary to wait for that.
> > > > > Should we remove the expiring DST certificate in that release then?
> > > > > ...uh oh: just tried removing the DST certificate: the module cannot
> > > > > connect to my server anymore...!?
> > > > > I (490213) ovms-server-v2: Connection is ovms.dexters-web.de:6870
> > > > > TEST1
> > > > > I (490213) ovms-server-v2: Status: Connecting...
> > > > > V (490723) ovms-server-v2:
> > > > > OvmsServerV2MongooseCallback(MG_EV_CONNECT=-3)
> > > > > W (490723) ovms-server-v2: Connection failed
> > > > > E (490723) ovms-server-v2: Status: Error: Connection failed
> > > > > V (490723) ovms-server-v2: OvmsServerV2MongooseCallback(MG_EV_CLOSE)
> > > > > I (490723) ovms-server-v2: Status: Disconnected
> > > > > Am 28.09.21 um 14:32 schrieb Mark Webb-Johnson:
> > > > > > Shall we release a full update? The last 3.2?
> > > > > > What we have now in master seems stable.
> > > > > > Mark
> > > > > > > On 28 Sep 2021, at 5:39 PM, Michael Balzer <dexter at expeedo.de>
> > > > > > > wrote:
> > > > > > >   Everyone,
> > > > > > > the DST root certificate we include (DST Root CA X3) expires on
> > > > > > > September 30, i.e. in two days.
> > > > > > > DST Root CA X3 length 1200 bytes
> > > > > > > 1200 byte certificate: DST Root CA X3
> > > > > > >    cert. version     : 3
> > > > > > >    serial number     :
> > > > > > > 44:AF:B0:80:D6:A3:27:BA:89:30:39:86:2E:F8:40:6B
> > > > > > >    issuer name       : O=Digital Signature Trust Co., CN=DST Root
> > > > > > > CA X3
> > > > > > >    subject name      : O=Digital Signature Trust Co., CN=DST Root
> > > > > > > CA X3
> > > > > > >    issued  on        : 2000-09-30 21:12:19
> > > > > > > *  expires on        : 2021-09-30 14:01:15*
> > > > > > >    signed using      : RSA with SHA1
> > > > > > > AFAICT, this root certificate is currently used by the OVMS to
> > > > > > > validate Let's Encrypt certificates.
> > > > > > > https://letsencrypt.org/docs/dst-root-ca-x3-expiration-september-2021/
> > > > > > >    * https://letsencrypt.org/docs/certificate-compatibility/
> > > > > > > Unfortunately, we missed adding the followup LE root certificate
> > > > > > > "ISRG
> > > > > > > Root X1" in time.
> > > > > > > I've just added that certificate to our builtin certificate
> > > > > > > repository, but it's too late now to roll out a "main" update in
> > > > > > > time
> > > > > > > (isn't it?).
> > > > > > > So, to prevent losing TLS connectivity with LE servers, users need
> > > > > > > to
> > > > > > > manually add the ISRG Root X1 certificate to their TLS
> > > > > > > repositories.
> > > > > > > I've added a section on this to our user manual:
> > > > > > >    * https://docs.openvehicles.com/en/latest/userguide/ssltls.html
> > > > > > > If users contact you, point them to that page.
> > > > > > > We probably should also remove the expired DST root certificate
> > > > > > > after
> > > > > > > September 30.
> > > > > > > Regards,
> > > > > > > Michael
> > > > > > > Michael Balzer * Helkenberger Weg 9 * D-58256 Ennepetal
> > > > > > > Fon 02333 / 833 5735 * Handy 0176 / 206 989 26
> > > > > > > _______________________________________________
> > > > > > > OvmsDev mailing list
> > > > > > > OvmsDev at lists.openvehicles.com
> > > > > > > http://lists.openvehicles.com/mailman/listinfo/ovmsdev
