[Ovmsdev] Urgent TLS root certificate issue (Let's Encrypt)
    Tue Sep 28 22:42:59 HKT 2021
More info:
All my browsers already have a builtin ISRG X1 certificate signed by
ISRG only, that's the new version:
https://crt.sh/?id=9314791
My server still sends the ISRG X1 certificate cross signed / issued by
DST Root CA X3. That's the chain it got from Let's Encrypt (via certbot)
on the last renewal (last month!):
https://crt.sh/?id=3958242236
Without the DST root cert, WolfSSL then fails validating the DST signed
X1 root certificate (I assume):
https://www.wolfssl.com/docs/wolfssl-manual/ch7/
My servers will continue sending that chain including the outdated root
cert probably until the next renewal, so it's possible having added the
new X1 root certificate didn't solve the issue.
The browsers seem to know how to substitute the DST signed certificate
by the builtin self-signed (?). Is there a similar option in WolfSSL,
and do we need to enable that?
Steve, can you confirm this, do you know a solution?
Am 28.09.21 um 15:34 schrieb Michael Balzer:
> I've tried adding the intermediate cert ("R3") and then also my site
> certificate, that didn't help.
> Only adding the DST cert again fixes the connection.
> Any ideas?
> OVMS# tls trust list
> ISRG Root X1 length 1939 bytes
> 1939 byte certificate: ISRG Root X1
>   cert. version     : 3
>   serial number     : 82:10:CF:B0:D2:40:E3:59:44:63:E0:BB:63:82:8B:00
>   issuer name       : C=US, O=Internet Security Research Group,
> CN=ISRG Root X1
>   subject name      : C=US, O=Internet Security Research Group,
> CN=ISRG Root X1
>   issued  on        : 2015-06-04 11:04:38
>   expires on        : 2035-06-04 11:04:38
>   signed using      : RSA with SHA-256
>   RSA key size      : 4096 bits
>   basic constraints : CA=true
>   key usage         : Key Cert Sign, CRL Sign
> dexter length 1972 bytes
> 1972 byte certificate: dexter
>   cert. version     : 3
>   serial number     :
> 04:55:1D:F4:27:A3:7D:E9:E4:A8:5C:37:F6:A1:61:87:3C:E5
>   issuer name       : C=US, O=Let's Encrypt, CN=R3
>   subject name      : CN=dexter.shopdriver.de
>   issued  on        : 2021-08-07 05:47:57
>   expires on        : 2021-11-05 05:47:55
>   RSA key size      : 2048 bits
>   basic constraints : CA=false
>   subject alt name  : dexter.shopdriver.de, dexters-web.de,
> ovms.dexters-web.de, www.dexter.shopdriver.de, www.dexters-web.de
>   key usage         : Digital Signature, Key Encipherment
>   ext key usage     : TLS Web Server Authentication, TLS Web Client
> Authentication
> r3 length 1826 bytes
> 1826 byte certificate: r3
>   cert. version     : 3
>   serial number     : 91:2B:08:4A:CF:0C:18:A7:53:F6:D6:2E:25:A7:5F:5A
> CN=ISRG Root X1
>   subject name      : C=US, O=Let's Encrypt, CN=R3
>   issued  on        : 2020-09-04 00:00:00
>   expires on        : 2025-09-15 16:00:00
>   basic constraints : CA=true, max_pathlen=0
>   key usage         : Digital Signature, Key Cert Sign, CRL Sign
>   ext key usage     : TLS Web Client Authentication, TLS Web Server
> Authentication
> Am 28.09.21 um 15:07 schrieb Michael Balzer:
>> We would need to bypass / shortcut the "eap" test phase.
>> But I agree, "master" is stable, I haven't had any issues or reports,
>> so I think we could do that. The FreeRTOS timer issue I'm working on
>> only affects very specific conditions, so not necessary to wait for that.
>> Should we remove the expiring DST certificate in that release then?
>> …uh oh: just tried removing the DST certificate: the module cannot
>> connect to my server anymore…!?
>> I (490213) ovms-server-v2: Connection is ovms.dexters-web.de:6870 TEST1
>> I (490213) ovms-server-v2: Status: Connecting...
>> V (490723) ovms-server-v2: OvmsServerV2MongooseCallback(MG_EV_CONNECT=-3)
>> W (490723) ovms-server-v2: Connection failed
>> E (490723) ovms-server-v2: Status: Error: Connection failed
>> V (490723) ovms-server-v2: OvmsServerV2MongooseCallback(MG_EV_CLOSE)
>> I (490723) ovms-server-v2: Status: Disconnected
>> Am 28.09.21 um 14:32 schrieb Mark Webb-Johnson:
>>> Shall we release a full update? The last 3.2?
>>> What we have now in master seems stable.
>>> Mark
>>>> On 28 Sep 2021, at 5:39 PM, Michael Balzer <dexter at expeedo.de> wrote:
>>>>  Everyone,
>>>> the DST root certificate we include (DST Root CA X3) expires on
>>>> September 30, i.e. in two days.
>>>> DST Root CA X3 length 1200 bytes
>>>> 1200 byte certificate: DST Root CA X3
>>>>   cert. version     : 3
>>>>   serial number     : 44:AF:B0:80:D6:A3:27:BA:89:30:39:86:2E:F8:40:6B
>>>>   issuer name       : O=Digital Signature Trust Co., CN=DST Root CA X3
>>>>   subject name      : O=Digital Signature Trust Co., CN=DST Root CA X3
>>>>   issued  on        : 2000-09-30 21:12:19
>>>> *  expires on        : 2021-09-30 14:01:15*
>>>>   signed using      : RSA with SHA1
>>>> AFAICT, this root certificate is currently used by the OVMS to
>>>> validate Let's Encrypt certificates.
>>>>   * https://letsencrypt.org/docs/dst-root-ca-x3-expiration-september-2021/
>>>>   * https://letsencrypt.org/docs/certificate-compatibility/
>>>> Unfortunately, we missed adding the followup LE root certificate
>>>> "ISRG Root X1" in time.
>>>> I've just added that certificate to our builtin certificate
>>>> repository, but it's too late now to roll out a "main" update in
>>>> time (isn't it?).
>>>> So, to prevent losing TLS connectivity with LE servers, users need
>>>> to manually add the ISRG Root X1 certificate to their TLS repositories.
>>>> I've added a section on this to our user manual:
>>>>   * https://docs.openvehicles.com/en/latest/userguide/ssltls.html
>>>> If users contact you, point them to that page.
>>>> We probably should also remove the expired DST root certificate
>>>> after September 30.
>>>> Regards,
>>>> Michael
>>>> OvmsDev mailing list
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20210928/e2ade66e/attachment-0001.htm>
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20210928/e2ade66e/attachment-0001.sig>
