[Ovmsdev] Urgent TLS root certificate issue (Let's Encrypt)
    Tue Sep 28 20:32:23 HKT 2021
Shall we release a full update? The last 3.2?
What we have now in master seems stable.
Mark
> On 28 Sep 2021, at 5:39 PM, Michael Balzer <dexter at expeedo.de> wrote:
>  Everyone,
> the DST root certificate we include (DST Root CA X3) expires on September 30, i.e. in two days.
> OVMS# tls trust list
> DST Root CA X3 length 1200 bytes
> 1200 byte certificate: DST Root CA X3
>   cert. version     : 3
>   serial number     : 44:AF:B0:80:D6:A3:27:BA:89:30:39:86:2E:F8:40:6B
>   issuer name       : O=Digital Signature Trust Co., CN=DST Root CA X3
>   subject name      : O=Digital Signature Trust Co., CN=DST Root CA X3
>   issued  on        : 2000-09-30 21:12:19
>   expires on        : 2021-09-30 14:01:15
>   signed using      : RSA with SHA1
>   RSA key size      : 2048 bits
>   basic constraints : CA=true
>   key usage         : Key Cert Sign, CRL Sign
> AFAICT, this root certificate is currently used by the OVMS to validate Let's Encrypt certificates.
> https://letsencrypt.org/docs/dst-root-ca-x3-expiration-september-2021/
> https://letsencrypt.org/docs/certificate-compatibility/
> Unfortunately, we missed adding the followup LE root certificate "ISRG Root X1" in time.
> I've just added that certificate to our builtin certificate repository, but it's too late now to roll out a "main" update in time (isn't it?).
> So, to prevent losing TLS connectivity with LE servers, users need to manually add the ISRG Root X1 certificate to their TLS repositories.
> I've added a section on this to our user manual:
> https://docs.openvehicles.com/en/latest/userguide/ssltls.html
> If users contact you, point them to that page.
> We probably should also remove the expired DST root certificate after September 30.
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20210928/41af75ff/attachment.htm>
Type: application/octet-stream
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20210928/41af75ff/attachment.obj>
