[Ovmsdev] for-v3.3: ota flash http crashes
    Fri Sep 17 16:39:16 HKT 2021
There is another fatal issue with OvmsSyncHttpClient besides the issue
with running in the mongoose context: OTA updates are no longer possible.
When flashing via HTTP, the OvmsSyncHttpClient tries to allocate memory
for a full firmware image, which of course fails:
OVMS# ota flash http
Current running partition is: factory
Target partition is: ota_0
Download firmware from
ovms.dexters-web.de/firmware/ota/v3.1/edge/ovms3.bin to ota_0
Guru Meditation Error: Core  1 panic'ed (StoreProhibited). Exception was
unhandled.
Core 1 register dump:
PC      : 0x4022438b  PS      : 0x00060a30  A0      : 0x802245cd A1
: 0x3ffe9c70
A2      : 0x00000000  A3      : 0x3ffe6f5c  A4      : 0x00000001 A5
: 0xffffffff
A6      : 0x3fabad7c  A7      : 0xff000000  A8      : 0x00000000 A9
: 0x3ffe9c50
A10     : 0x00000000  A11     : 0x3ffe6f5c  A12     : 0x00000001 A13
: 0x0000000a
A14     : 0x00000037  A15     : 0x00000057  SAR     : 0x00000018
EXCCAUSE: 0x0000001d
EXCVADDR: 0x00000000  LBEG    : 0x4008b179  LEND    : 0x4008b19b LCOUNT
: 0xffffffff
ELF file SHA256: 94a8e191baae33a5
Backtrace: 0x4022438b:0x3ffe9c70 0x402245ca:0x3ffe9c90
0x40132f93:0x3ffe9cc0 0x40132e51:0x3ffe9d10 0x40133609:0x3ffe9d40
0x402e7472:0x3ffe9d70 0x4010e229:0x3ffe9d90 0x4010fbd5:0x3ffe9dd0
0x40110015:0x3ffe9e00 0x401102de:0x3ffe9e70 0x4010c51a:0x3ffe9ed0
0x400f5a4f:0x3ffe9ef0 0x400f5afd:0x3ffe9f40
Rebooting...
0x4022438b is in std::__cxx11::basic_string<char,
std::char_traits<char>, std::allocator<char> >::_S_copy(char*, char
const*, unsigned int)
(/builds/idf/crosstool-NG/.build/xtensa-esp32-elf/build/build-cc-gcc-final/xtensa-esp32-elf/esp32-psram/libstdc++-v3/include/bits/char_traits.h:243).
0x402245ca is in std::__cxx11::basic_string<char,
std::char_traits<char>, std::allocator<char> >::reserve(unsigned int)
(/builds/idf/crosstool-NG/.build/xtensa-esp32-elf/build/build-cc-gcc-final/xtensa-esp32-elf/esp32-psram/libstdc++-v3/include/bits/basic_string.tcc:298).
0x40132f93 is in OvmsSyncHttpClient::ConnectionHeaders(mg_connection*)
(/home/balzer/esp/Open-Vehicle-Monitoring-System-3/vehicle/OVMS.V3/components/ovms_http/src/ovms_http.cpp:381).
376         else
377           {
378           if (header.compare(0,15,"Content-Length:") == 0)
379             {
380             m_bodysize = atoi(header.substr(15).c_str());
*381             m_body.reserve(m_bodysize+1);*
382             }
383           else if (header.compare(0,5,"HTTP/") == 0)
384             {
385             size_t space = header.find(' ');
0x40132e51 is in OvmsSyncHttpClient::ConnectionData(mg_connection*,
unsigned char*, unsigned int)
(/home/balzer/esp/Open-Vehicle-Monitoring-System-3/vehicle/OVMS.V3/components/ovms_http/src/ovms_http.cpp:316).
311           data += len;
312           consumed += len;
313           len = 0;
314           }
315
316         ConnectionHeaders(nc);
317         }
318
319       if (! m_inheaders)
320         {
0x40133609 is in OvmsSyncHttpClient::MongooseCallback(mg_connection*,
int, void*)
(/home/balzer/esp/Open-Vehicle-Monitoring-System-3/vehicle/OVMS.V3/components/ovms_http/src/ovms_http.cpp:124).
119           m_mgconn = NULL;
120           }
121           break;
122
123         case MG_EV_RECV:
124           mbuf_remove(&nc->recv_mbuf,
ConnectionData(nc,(uint8_t*)nc->recv_mbuf.buf, nc->recv_mbuf.len));
125           break;
126
127         default:
128           break;
Can we switch back to using the old async client?
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20210917/63f84a5b/attachment.htm>
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20210917/63f84a5b/attachment.sig>
