[Ovmsdev] Duktape heap memory management
    Craig Leres
    leres at xse.com
    Mon Sep  6 11:40:42 HKT 2021
Progress!
I was a little worried because I was measuring ~2 ohms between the
antenna pin and ground but I tried it anyway and I have signal now. I
saw crashes the first few times the cell network came up but it
eventually settled down and is working now. Maybe an edge case in the
dhcp code vs. first time network registration?
FYI I'm running 3.2.016-377-g1e6da7e5 (for-v3.3 branch).
		Craig
[initial boot/crash]
OVMS>
I (30972) cellular: State: Enter NetWait state
I (30972) gsm-nmea: Startup
OVMS> ena
Password:
I (31422) webserver: HTTP GET /
I (31502) webserver: HTTP GET /assets/script.js
I (31882) webserver: HTTP GET /apple-touch-icon.png
I (32022) webserver: HTTP GET /cfg/cellular
OVMS#
I (35972) cellular: Network Registration status: DeniedRegistration
I (36172) cellular: Signal Quality is: 24 (-65 dBm)
OVMS# simcom
Unrecognised command
I (40322) cellular: Signal Quality is: 20 (-73 dBm)
OVMS# cell
MODEM Status
   Model: SIM7600
   Network Registration: DeniedRegistration
     Provider:
     Signal: -73 dBm
     Mode:
   State: NetWait
   Mux: Status up
   PPP: Not running
   GPS: Connected on channel: #1
I (43042) cellular: Network Registration status: RegisteredRoaming
I (43972) cellular: State: Enter NetStart state
I (45032) cellular: PPP Connection is ready to start
I (45972) cellular: State: Enter NetMode state
I (45972) gsm-ppp: Initialising...
OVMS# log level verbose cellular
Logging level for cellular set to verbose
OVMS# cell
MODEM Status
   Model: SIM7600
   Network Registration: RegisteredRoaming
     Provider:
     Signal: -73 dBm
     Mode:
   State: NetMode
   Mux: Status up
   PPP: Not connected
D (52362) cellular: mux-rx-line #3: NO CARRIER
D (52362) cellular: mux-rx-line #4: NO CARRIER
D (52372) cellular: mux-rx-line #3: +PPPD: DISCONNECTED
I (52372) cellular: PPP Connection disconnected
D (52372) cellular: mux-rx-line #4: +PPPD: DISCONNECTED
OVMS# Guru Meditation Error: Core  1 panic'ed (LoadProhibited).
Exception was un                              handled.
Core 1 register dump:
PC      : 0x400fd4b8  PS      : 0x00060830  A0      : 0x800fd5c5  A1
  : 0x3f                              fca010
A2      : 0x3ffb5140  A3      : 0xa5a5a5a5  A4      : 0x3f488bd6  A5
  : 0x3f                              fb5148
A6      : 0x00000073  A7      : 0x000000a5  A8      : 0x800fd481  A9
  : 0x3f                              fc9ff0
A10     : 0x3ffca058  A11     : 0x3ffca050  A12     : 0x400f895c  A13
  : 0x00                              000000
A14     : 0x3ffc91ac  A15     : 0x00000001  SAR     : 0x00000008
EXCCAUSE: 0x00                              00001c
EXCVADDR: 0xa5a5a663  LBEG    : 0x4000c2e0  LEND    : 0x4000c2f6  LCOUNT
  : 0xff                              ffffff
ELF file SHA256: f80a889fca6f51ca
Backtrace: 0x400fd4b8:0x3ffca010 0x400fd5c2:0x3ffca090
0x4022dfa9:0x3ffca0b0
Rebooting...
ets Jul 29 2019 12:21:46
rst:0xc (SW_CPU_RESET),boot:0x1b (SPI_FAST_FLASH_BOOT)
configsip: 0, SPIWP:0xee
[decoded backtace]
ice 485 % ./backtrace.sh 0x400fd4b8:0x3ffca010 0x400fd5c2:0x3ffca090
+ xtensa-esp32-elf-addr2line -e build/ovms3.elf 0x400fd4b8:0x3ffca010
0x400fd5c2:0x3ffca090 0x4022dfa9:0x3ffca0b0
main/ovms_notify.cpp:739
/home/ice/u0/leres/esp/openvehicles-xtensa-esp32-elf/components/lwip/lwip/src/core/ipv4/dhcp.c:916
[later successful boot/network registration]
      OVMS# cell
MODEM Status
   Model: SIM7600
     Provider: T-Mobile Hologram
     Signal: -73 dBm
     Mode: LTE,Online
   State: NetMode
   Mux: Status up
   PPP: Connected on channel: #2
D (174995) cellular: mux-tx #3: AT+CREG?;+CCLK?;+CSQ;+CPSI?;+COPS?
D (175015) cellular: mux-rx-line #3: +CPSI:
LTE,Online,310-260,0x417B,23125765,176,EUTRAN-BAND12,5035,2,2,-132,-1012,-741,9
D (175015) cellular: mux-rx-line #3: +CREG: 1,5
D (175015) cellular: mux-rx-line #3: +CCLK: "21/09/05,20:29:00-28"
D (175015) cellular: mux-rx-line #3: +CSQ: 20,99
D (175015) cellular: mux-rx-line #3: +COPS: 0,0,"T-Mobile Hologram",7
