[Ovmsdev] 3.2.018 release
Wed Nov 24 10:37:27 HKT 2021
Craig,
From what you sent before, it just seemed that the PPP link could not be established. The CSQ figures you show below indicate the dev board has a better signal (and production is marginal):
Value	RSSI dBm	Condition
2	-109	Marginal
3	-107	Marginal
4	-105	Marginal
5	-103	Marginal
6	-101	Marginal
7	-99	Marginal
8	-97	Marginal
9	-95	Marginal
10	-93	OK
11	-91	OK
12	-89	OK
13	-87	OK
14	-85	OK
15	-83	Good
16	-81	Good
17	-79	Good
18	-77	Good
19	-75	Good
20	-73	Excellent
21	-71	Excellent
22	-69	Excellent
23	-67	Excellent
24	-65	Excellent
25	-63	Excellent
26	-61	Excellent
27	-59	Excellent
28	-57	Excellent
29	-55	Excellent
30	-53	Excellent
I am not aware of any limitation / restriction on inactive PPP cellular data connections - I guess that would depend on the configuration of individual operators. Can you configure the dev board to send some data?
I am not really sure how to help here, seeing the little extracts of logs you send and not knowing your environment. From a troubleshooting point of view, the logs should show the cellular activity and behaviour of the modem.
> On 24 Nov 2021, at 4:38 AM, Craig Leres <leres at xse.com> wrote:
> On 11/22/21 18:43, Mark Webb-Johnson wrote:
>> From the logs, it seems the GSM link is established, but PPP could not be connected.
>> Could this be a merging coverage area (although the CSQ of 13 seems fine), or some other problem with data connection?
>> The error messages 'NO CARRIER’ and '+PPPD: DISCONNECTED’ are from the modem itself.
> There aren't any ppp error messages until 12 hours after bootup. I ran the dev and a normal module in side-by-side windows and the verbose cellular/simcom messages look similar for the first 12 hours.
> I can also see the dev module (sim7600) is active on https://dashboard.hologram.io
> Any ideas on how to troubleshoot this?
> Is it a problem that the dev box is not configured to upload anything to the V2 server?
> 		Craig
> # dev right after bootup
> D (287003) cellular: mux-tx #3: AT+CREG?;+CCLK?;+CSQ;+CPSI?;+COPS?
> D (287013) cellular: mux-rx-line #3: +CPSI: LTE,Online,310-410,0x8B44,169982472,7,EUTRAN-BAND2,800,5,5,-125,-1205,-881,12
> D (287023) cellular: mux-rx-line #3: +CREG: 1,5
> D (287023) cellular: mux-rx-line #3: +CCLK: "21/11/22,23:48:12-32"
> D (287023) cellular: mux-rx-line #3: +CSQ: 13,99
> D (287023) cellular: mux-rx-line #3: +COPS: 0,0,"AT&T Hologram",7
> # production right after bootup
> D (191983) cellular: mux-tx #3: AT+CREG?;+CCLK?;+CSQ;+CPSI?;+COPS?
> D (192003) cellular: mux-rx-line #3: +CPSI: WCDMA,Online,310-410,0xDE74,5704608,WCDMA 850,29,4385,0,6.0,95,36,19,500
> D (192013) cellular: mux-rx-line #3: +CREG: 1,5
> D (192013) cellular: mux-rx-line #3: +CCLK: "21/11/22,23:54:15-32"
> D (192013) cellular: mux-rx-line #3: +CSQ: 9,99
> D (192013) cellular: mux-rx-line #3: +COPS: 0,0,"AT&T Hologram",2
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20211124/6038afbf/attachment-0001.htm>
