[Ovmsdev] for-v3.3: ota flash http crashes
Tue Nov 23 10:22:28 HKT 2021
I have merged in these reverts, and committed, then built a new edge on my server. I ran a few OTA updates with this, and it seems ok.
The code now uses the old ovms_http library, based on normal sockets (not mongoose). This should also workaround the ‘ota flash http’ issue we had with ssh client connections. I would prefer to use mongoose (apart from uniformity, this also gave us support for HTTPS), but it is quite tricky to do this in a blocking way with the ssh client also over mongoose. Would need to re-work to be non-blocking for these commands.
Sorry, but existing edge users will probably have to re-flash from SD card or USB.
> On 23 Nov 2021, at 8:24 AM, Mark Webb-Johnson <mark at webb-johnson.net> wrote:
> Signed PGP part
> Damn. I had made the change to roll that back, but forgot to merge my local branch with those changes.
> I just tried, but got some conflicts. I’ll fix those up, and then commit again.
>> On 23 Nov 2021, at 1:58 AM, Michael Balzer <dexter at expeedo.de <mailto:dexter at expeedo.de>> wrote:
>> Signed PGP part
>> Mark,
>> since updating to 3.3.001 my test module again crashes on any ota update attempt.
>> The signature is the same as below, and the code seems to be unchanged…?
>> Am 17.09.21 um 10:48 schrieb Mark Webb-Johnson:
>>> I’ll have a look at it over the weekend.
>>>> On 17 Sep 2021, at 4:39 PM, Michael Balzer <dexter at expeedo.de <mailto:dexter at expeedo.de>> wrote:
>>>> Signed PGP part
>>>> There is another fatal issue with OvmsSyncHttpClient besides the issue with running in the mongoose context: OTA updates are no longer possible.
>>>> When flashing via HTTP, the OvmsSyncHttpClient tries to allocate memory for a full firmware image, which of course fails:
>>>> OVMS# ota flash http
>>>> Current running partition is: factory
>>>> Target partition is: ota_0
>>>> Download firmware from ovms.dexters-web.de/firmware/ota/v3.1/edge/ovms3.bin <http://ovms.dexters-web.de/firmware/ota/v3.1/edge/ovms3.bin> to ota_0
>>>> Guru Meditation Error: Core 1 panic'ed (StoreProhibited). Exception was unhandled.
>>>> Core 1 register dump:
>>>> PC : 0x4022438b PS : 0x00060a30 A0 : 0x802245cd A1 : 0x3ffe9c70
>>>> A2 : 0x00000000 A3 : 0x3ffe6f5c A4 : 0x00000001 A5 : 0xffffffff
>>>> A6 : 0x3fabad7c A7 : 0xff000000 A8 : 0x00000000 A9 : 0x3ffe9c50
>>>> A10 : 0x00000000 A11 : 0x3ffe6f5c A12 : 0x00000001 A13 : 0x0000000a
>>>> A14 : 0x00000037 A15 : 0x00000057 SAR : 0x00000018 EXCCAUSE: 0x0000001d
>>>> EXCVADDR: 0x00000000 LBEG : 0x4008b179 LEND : 0x4008b19b LCOUNT : 0xffffffff
>>>> ELF file SHA256: 94a8e191baae33a5
>>>> Backtrace: 0x4022438b:0x3ffe9c70 0x402245ca:0x3ffe9c90 0x40132f93:0x3ffe9cc0 0x40132e51:0x3ffe9d10 0x40133609:0x3ffe9d40 0x402e7472:0x3ffe9d70 0x4010e229:0x3ffe9d90 0x4010fbd5:0x3ffe9dd0 0x40110015:0x3ffe9e00 0x401102de:0x3ffe9e70 0x4010c51a:0x3ffe9ed0 0x400f5a4f:0x3ffe9ef0 0x400f5afd:0x3ffe9f40
>>>> Rebooting...
>>>> 0x4022438b is in std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >::_S_copy(char*, char const*, unsigned int) (/builds/idf/crosstool-NG/.build/xtensa-esp32-elf/build/build-cc-gcc-final/xtensa-esp32-elf/esp32-psram/libstdc++-v3/include/bits/char_traits.h:243).
>>>> 0x402245ca is in std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >::reserve(unsigned int) (/builds/idf/crosstool-NG/.build/xtensa-esp32-elf/build/build-cc-gcc-final/xtensa-esp32-elf/esp32-psram/libstdc++-v3/include/bits/basic_string.tcc:298).
>>>> 0x40132f93 is in OvmsSyncHttpClient::ConnectionHeaders(mg_connection*) (/home/balzer/esp/Open-Vehicle-Monitoring-System-3/vehicle/OVMS.V3/components/ovms_http/src/ovms_http.cpp:381).
>>>> 376 else
>>>> 377 {
>>>> 378 if (header.compare(0,15,"Content-Length:") == 0)
>>>> 379 {
>>>> 380 m_bodysize = atoi(header.substr(15).c_str());
>>>> 381 m_body.reserve(m_bodysize+1);
>>>> 382 }
>>>> 383 else if (header.compare(0,5,"HTTP/") == 0)
>>>> 384 {
>>>> 385 size_t space = header.find(' ');
>>>> 0x40132e51 is in OvmsSyncHttpClient::ConnectionData(mg_connection*, unsigned char*, unsigned int) (/home/balzer/esp/Open-Vehicle-Monitoring-System-3/vehicle/OVMS.V3/components/ovms_http/src/ovms_http.cpp:316).
>>>> 311 data += len;
>>>> 312 consumed += len;
>>>> 313 len = 0;
>>>> 314 }
>>>> 315
>>>> 316 ConnectionHeaders(nc);
>>>> 317 }
>>>> 318
>>>> 319 if (! m_inheaders)
>>>> 320 {
>>>> 0x40133609 is in OvmsSyncHttpClient::MongooseCallback(mg_connection*, int, void*) (/home/balzer/esp/Open-Vehicle-Monitoring-System-3/vehicle/OVMS.V3/components/ovms_http/src/ovms_http.cpp:124).
>>>> 119 m_mgconn = NULL;
>>>> 120 }
>>>> 121 break;
>>>> 122
>>>> 123 case MG_EV_RECV:
>>>> 124 mbuf_remove(&nc->recv_mbuf, ConnectionData(nc,(uint8_t*)nc->recv_mbuf.buf, nc->recv_mbuf.len));
>>>> 125 break;
>>>> 126
>>>> 127 default:
>>>> 128 break;
>>>> Can we switch back to using the old async client?
>>>> Regards,
>>>> Michael
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20211123/dc995b47/attachment-0001.htm>
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20211123/dc995b47/attachment-0001.sig>
