[Ovmsdev] for-v3.3: ota flash http crashes
Tue Nov 23 01:58:27 HKT 2021
Mark,
since updating to 3.3.001 my test module again crashes on any ota update
attempt.
The signature is the same as below, and the code seems to be unchanged…?
Am 17.09.21 um 10:48 schrieb Mark Webb-Johnson:
> I’ll have a look at it over the weekend.
>> On 17 Sep 2021, at 4:39 PM, Michael Balzer <dexter at expeedo.de
>> Signed PGP part
>> There is another fatal issue with OvmsSyncHttpClient besides the
>> issue with running in the mongoose context: OTA updates are no longer
>> possible.
>> When flashing via HTTP, the OvmsSyncHttpClient tries to allocate
>> memory for a full firmware image, which of course fails:
>> OVMS# ota flash http
>> Current running partition is: factory
>> Target partition is: ota_0
>> Download firmware from
>> ovms.dexters-web.de/firmware/ota/v3.1/edge/ovms3.bin
>> <http://ovms.dexters-web.de/firmware/ota/v3.1/edge/ovms3.bin> to ota_0
>> Guru Meditation Error: Core 1 panic'ed (StoreProhibited). Exception
>> was unhandled.
>> Core 1 register dump:
>> PC : 0x4022438b PS : 0x00060a30 A0 : 0x802245cd
>> A1 : 0x3ffe9c70
>> A2 : 0x00000000 A3 : 0x3ffe6f5c A4 : 0x00000001
>> A5 : 0xffffffff
>> A6 : 0x3fabad7c A7 : 0xff000000 A8 : 0x00000000
>> A9 : 0x3ffe9c50
>> A10 : 0x00000000 A11 : 0x3ffe6f5c A12 : 0x00000001
>> A13 : 0x0000000a
>> A14 : 0x00000037 A15 : 0x00000057 SAR : 0x00000018
>> EXCCAUSE: 0x0000001d
>> EXCVADDR: 0x00000000 LBEG : 0x4008b179 LEND : 0x4008b19b
>> LCOUNT : 0xffffffff
>> ELF file SHA256: 94a8e191baae33a5
>> Backtrace: 0x4022438b:0x3ffe9c70 0x402245ca:0x3ffe9c90
>> 0x40132f93:0x3ffe9cc0 0x40132e51:0x3ffe9d10 0x40133609:0x3ffe9d40
>> 0x402e7472:0x3ffe9d70 0x4010e229:0x3ffe9d90 0x4010fbd5:0x3ffe9dd0
>> 0x40110015:0x3ffe9e00 0x401102de:0x3ffe9e70 0x4010c51a:0x3ffe9ed0
>> 0x400f5a4f:0x3ffe9ef0 0x400f5afd:0x3ffe9f40
>> Rebooting...
>> 0x4022438b is in std::__cxx11::basic_string<char,
>> std::char_traits<char>, std::allocator<char> >::_S_copy(char*, char
>> const*, unsigned int)
>> (/builds/idf/crosstool-NG/.build/xtensa-esp32-elf/build/build-cc-gcc-final/xtensa-esp32-elf/esp32-psram/libstdc++-v3/include/bits/char_traits.h:243).
>> 0x402245ca is in std::__cxx11::basic_string<char,
>> std::char_traits<char>, std::allocator<char> >::reserve(unsigned int)
>> (/builds/idf/crosstool-NG/.build/xtensa-esp32-elf/build/build-cc-gcc-final/xtensa-esp32-elf/esp32-psram/libstdc++-v3/include/bits/basic_string.tcc:298).
>> 0x40132f93 is in
>> OvmsSyncHttpClient::ConnectionHeaders(mg_connection*)
>> (/home/balzer/esp/Open-Vehicle-Monitoring-System-3/vehicle/OVMS.V3/components/ovms_http/src/ovms_http.cpp:381).
>> 376 else
>> 377 {
>> 378 if (header.compare(0,15,"Content-Length:") == 0)
>> 379 {
>> 380 m_bodysize = atoi(header.substr(15).c_str());
>> *381 m_body.reserve(m_bodysize+1);*
>> 382 }
>> 383 else if (header.compare(0,5,"HTTP/") == 0)
>> 384 {
>> 385 size_t space = header.find(' ');
>> 0x40132e51 is in OvmsSyncHttpClient::ConnectionData(mg_connection*,
>> unsigned char*, unsigned int)
>> (/home/balzer/esp/Open-Vehicle-Monitoring-System-3/vehicle/OVMS.V3/components/ovms_http/src/ovms_http.cpp:316).
>> 311 data += len;
>> 312 consumed += len;
>> 313 len = 0;
>> 314 }
>> 315
>> 316 ConnectionHeaders(nc);
>> 317 }
>> 318
>> 319 if (! m_inheaders)
>> 320 {
>> 0x40133609 is in OvmsSyncHttpClient::MongooseCallback(mg_connection*,
>> int, void*)
>> (/home/balzer/esp/Open-Vehicle-Monitoring-System-3/vehicle/OVMS.V3/components/ovms_http/src/ovms_http.cpp:124).
>> 119 m_mgconn = NULL;
>> 120 }
>> 121 break;
>> 122
>> 123 case MG_EV_RECV:
>> 124 mbuf_remove(&nc->recv_mbuf,
>> ConnectionData(nc,(uint8_t*)nc->recv_mbuf.buf, nc->recv_mbuf.len));
>> 125 break;
>> 126
>> 127 default:
>> 128 break;
>> Can we switch back to using the old async client?
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20211122/ad9476b0/attachment-0001.htm>
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20211122/ad9476b0/attachment-0001.sig>
