[Ovmsdev] OVMS going comatose
Sun Mar 28 17:08:51 HKT 2021
Steve,
I haven't seen any lockups like yours recently. A single report on a
forum about 4 weeks ago was due to a corrupted config store partition,
and I'm not sure that was already with the new WolfSSL code.
I've just scanned the current crash reports on my server (updated
hourly: https://dexters-web.de/f/firmware/developer/crashreport.csv) for
anything WolfSSL related and found only one crash clearly originating
within WolfSSL (decoded backtrace attached). That seems to be unlocking
a mutex from the wrong task.
What's more often now is the abort from the failed assertion in
lock_acquire_generic, which seems to be caused by an ESP_LOG call from
within a critical section. According to this info…
https://github.com/espressif/esp-idf/issues/4412#issuecomment-559208996
…that could be the source for our primary issue of unexplained WDTs. But
I think that can only either trigger the dog or trigger an abort
immediately, not freeze the module.
So… sorry, no clue here.
Am 28.03.21 um 04:31 schrieb Stephen Casner:
> On Thu, 25 Mar 2021, Stephen Casner wrote:
>> Since updating my in-car OVMS with a build from the master branch
>> after my WolfSSL update I've experienced a couple of instances where
>> connectivity from app was lost.  The first time I needed a quick
>> resolution so I just reset OVMS.  It happened again during the night
>> while charging, and this time I connected to the console to check
>> conditions before resetting.  What I found was that the async console
>> was not responding at all.  Since I have OVMS configured to drop into
>> gdb on a crash, I should have seen something.  I've turned on logging
>> to file to see if that sheds any light.
> I had another apparent crash today, now with file logging enabled.
> This occurred while on a drive, so away from the home wifi.  The last
> log messages indicate that the crash happened when bringing up
> networking via the modem connection:
> 2021-03-27 12:48:39.688 PDT I (176007218) netmanager: MODEM up (with WIFI client down): starting network with MODEM
> 2021-03-27 12:48:39.698 PDT I (176007228) time: Starting SNTP client
> 2021-03-27 12:48:39.708 PDT I (176007238) webserver: Launching Web Server
> 2021-03-27 12:48:39.708 PDT I (176007238) webserver: Binding to port 80 (http)
> 2021-03-27 12:48:39.708 PDT I (176007238) webserver: Binding to port 443 (https)
> 2021-03-27 12:48:39.768 PDT I (176007298) telnet: Launching Telnet Server
> 2021-03-27 12:48:39.768 PDT I (176007298) ssh: Launching SSH Server
> 2021-03-27 12:48:39.788 PDT I (176007318) ovms-server-v2: Status: Network is up, so attempt network connection
> The last logged activity is to start server v2, and I do have TLS
> enabled, so this may indicate a problem with the new WolfSSL
> integration.  Does this sound similar to any of the other crashes seen
> recently?
>                                                          -- Steve
Using elf file: tmp/3.2.016-46-gf7523a8a-elf/ovms3.elf
0x4008e58e is in invoke_abort (/home/balzer/esp/esp-idf/components/esp32/panic.c:156).
151	#endif
152	    while (1) {
153	        if (esp_cpu_in_ocd_debug_mode()) {
154	            __asm__ ("break 0,0");
155	        }
156	        *((int *) 0) = 0;
157	    }
158	}
159
160	void abort()
0x4008e829 is in abort (/home/balzer/esp/esp-idf/components/esp32/panic.c:171).
166	     * don't overwrite that.
167	     */
168	    if (esp_reset_reason_get_hint() == ESP_RST_UNKNOWN) {
169	        esp_reset_reason_set_hint(ESP_RST_PANIC);
170	    }
171	    invoke_abort();
172	}
173
174
175	static const char *edesc[] = {
0x40090e7f is in xTaskPriorityDisinherit (/home/balzer/esp/esp-idf/components/freertos/tasks.c:4116).
4111		BaseType_t xReturn = pdFALSE;
4112			taskENTER_CRITICAL(&xTaskQueueMutex);
4113
4114			if( pxMutexHolder != NULL )
4115			{
4116				configASSERT( pxTCB->uxMutexesHeld );
4117				( pxTCB->uxMutexesHeld )--;
4118
4119				if( pxTCB->uxPriority != pxTCB->uxBasePriority )
4120				{
0x400912f3 is in prvCopyDataToQueue (/home/balzer/esp/esp-idf/components/freertos/queue.c:1876).
1871			#if ( configUSE_MUTEXES == 1 )
1872			{
1873				if( pxQueue->uxQueueType == queueQUEUE_IS_MUTEX )
1874				{
1875					/* The mutex is no longer being held. */
1876					xReturn = xTaskPriorityDisinherit( ( void * ) pxQueue->pxMutexHolder );
1877					pxQueue->pxMutexHolder = NULL;
1878				}
1879				else
1880				{
0x400915e9 is in xQueueGenericSend (/home/balzer/esp/esp-idf/components/freertos/queue.c:743).
738				the head item in the queue is to be overwritten then it does
739				not matter if the queue is full. */
740				if( ( pxQueue->uxMessagesWaiting < pxQueue->uxLength ) || ( xCopyPosition == queueOVERWRITE ) )
741				{
742					traceQUEUE_SEND( pxQueue );
743					xYieldRequired = prvCopyDataToQueue( pxQueue, pvItemToQueue, xCopyPosition );
744
745					#if ( configUSE_QUEUE_SETS == 1 )
746					{
747						if( pxQueue->pxQueueSetContainer != NULL )
0x401faa62 is in wc_UnLockMutex (/home/balzer/esp/Open-Vehicle-Monitoring-System-3/vehicle/OVMS.V3/components/wolfssl/wolfcrypt/src/wc_port.c:983).
978	        return 0;
979	    }
980
981	    int wc_UnLockMutex(wolfSSL_Mutex* m)
982	    {
983	        xSemaphoreGive( *m );
984	        return 0;
985	    }
986
987	#elif defined(RTTHREAD)
0x401f3f29 is in esp_CryptHwMutexUnLock (/home/balzer/esp/Open-Vehicle-Monitoring-System-3/vehicle/OVMS.V3/components/wolfssl/wolfcrypt/src/port/Espressif/esp32_util.c:43).
38	    return ((xSemaphoreTake( *mutex, xBlockTime ) == pdTRUE) ? 0 : BAD_MUTEX_E);
39	#endif
40	}
41
42	int esp_CryptHwMutexUnLock(wolfSSL_Mutex* mutex) {
43	    return wc_UnLockMutex(mutex);
44	}
45
46	#endif
47
0x401f3d6f is in esp_sha_hw_unlock (/home/balzer/esp/Open-Vehicle-Monitoring-System-3/vehicle/OVMS.V3/components/wolfssl/wolfcrypt/src/port/Espressif/esp32_sha.c:183).
178	    periph_module_disable(PERIPH_SHA_MODULE);
179	#if defined(SINGLE_THREADED)
180	    InUse = 0;
181	#else
182	    /* unlock hw engine for next use */
183	    esp_CryptHwMutexUnLock(&sha_mutex);
184	#endif
185	    ESP_LOGV(TAG, "leave esp_sha_hw_unlock");
186	}
187	/*
0x401fa20d is in wc_InitSha512_ex (/home/balzer/esp/Open-Vehicle-Monitoring-System-3/vehicle/OVMS.V3/components/wolfssl/wolfcrypt/src/sha512.c:224).
219	    sha512->ctx.sha_type = SHA2_512;
220	     /* always start firstblock = 1 when using hw engine */
221	    sha512->ctx.isfirstblock = 1;
222	    if(sha512->ctx.mode == ESP32_SHA_HW) {
223	        /* release hw */
224	        esp_sha_hw_unlock();
225	    }
226	    /* always set mode as INIT
227	    *  whether using HW or SW is determined at first call of update()
228	    */
0x401fa2f1 is in wc_InitSha512 (/home/balzer/esp/Open-Vehicle-Monitoring-System-3/vehicle/OVMS.V3/components/wolfssl/wolfcrypt/src/sha512.c:900).
895	    return InitSha512(sha512);  /* reset state */
896	}
897
898	int wc_InitSha512(wc_Sha512* sha512)
899	{
900	    return wc_InitSha512_ex(sha512, NULL, INVALID_DEVID);
901	}
902
903	void wc_Sha512Free(wc_Sha512* sha512)
904	{
0x401eed2a is in wc_Sha512Hash (/home/balzer/esp/Open-Vehicle-Monitoring-System-3/vehicle/OVMS.V3/components/wolfssl/wolfcrypt/src/hash.c:1169).
1164	            DYNAMIC_TYPE_TMP_BUFFER);
1165	        if (sha512 == NULL)
1166	            return MEMORY_E;
1167	    #endif
1168
1169	        if ((ret = wc_InitSha512(sha512)) != 0) {
1170	            WOLFSSL_MSG("InitSha512 failed");
1171	        }
1172	        else {
1173	            if ((ret = wc_Sha512Update(sha512, data, len)) != 0) {
0x401eedf9 is in wc_Hash (/home/balzer/esp/Open-Vehicle-Monitoring-System-3/vehicle/OVMS.V3/components/wolfssl/wolfcrypt/src/hash.c:497).
492	            ret = wc_Sha384Hash(data, data_len, hash);
493	#endif
494	            break;
495	        case WC_HASH_TYPE_SHA512:
496	#ifdef WOLFSSL_SHA512
497	            ret = wc_Sha512Hash(data, data_len, hash);
498	#endif
499	            break;
500	        case WC_HASH_TYPE_MD5_SHA:
501	#if !defined(NO_MD5) && !defined(NO_SHA)
0x401d8d35 is in DoServerKeyExchange (/home/balzer/esp/Open-Vehicle-Monitoring-System-3/vehicle/OVMS.V3/components/wolfssl/src/internal.c:22493).
22488	                        if (ssl->buffers.digest.buffer == NULL) {
22489	                            ERROR_OUT(MEMORY_E, exit_dske);
22490	                        }
22491
22492	                        /* Perform hash */
22493	                        ret = wc_Hash(hashType, ssl->buffers.sig.buffer,
22494	                                                    ssl->buffers.sig.length,
22495	                                                    ssl->buffers.digest.buffer,
22496	                                                    ssl->buffers.digest.length);
22497	                        if (ret != 0) {
0x401dc9d5 is in DoHandShakeMsgType (/home/balzer/esp/Open-Vehicle-Monitoring-System-3/vehicle/OVMS.V3/components/wolfssl/src/internal.c:12885).
12880	        break;
12881	#endif
12882
12883	    case server_key_exchange:
12884	        WOLFSSL_MSG("processing server key exchange");
12885	        ret = DoServerKeyExchange(ssl, input, inOutIdx, size);
12886	        break;
12887
12888	#ifdef HAVE_SESSION_TICKET
12889	    case session_ticket:
0x401ddc9c is in ProcessReply (/home/balzer/esp/Open-Vehicle-Monitoring-System-3/vehicle/OVMS.V3/components/wolfssl/src/internal.c:13112).
13107	            ssl->arrays->pendingMsgOffset = inputLength;
13108	            *inOutIdx += inputLength - HANDSHAKE_HEADER_SZ;
13109	            return 0;
13110	        }
13111
13112	        ret = DoHandShakeMsgType(ssl, input, inOutIdx, type, size, totalSz);
13113	    }
13114	    else {
13115	        word32 pendSz =
13116	            ssl->arrays->pendingMsgSz - ssl->arrays->pendingMsgOffset;
0x401e0532 is in wolfSSL_connect (/home/balzer/esp/Open-Vehicle-Monitoring-System-3/vehicle/OVMS.V3/components/wolfssl/src/ssl.c:12506).
12501	            while (ssl->options.serverState < neededState) {
12502	                #ifdef WOLFSSL_TLS13
12503	                    if (ssl->options.tls1_3)
12504	                        return wolfSSL_connect_TLSv13(ssl);
12505	                #endif
12506	                if ( (ssl->error = ProcessReply(ssl)) < 0) {
12507	                    WOLFSSL_ERROR(ssl->error);
12508	                    return WOLFSSL_FATAL_ERROR;
12509	                }
12510	                /* if resumption failed, reset needed state */
0x401099d3 is in mg_ssl_if_handshake (/home/balzer/esp/Open-Vehicle-Monitoring-System-3/vehicle/OVMS.V3/components/mongoose/mongoose/mongoose.c:4534).
4529	  int res;
4530	  /* If descriptor is not yet set, do it now. */
4531	  if (SSL_get_fd(ctx->ssl) < 0) {
4532	    if (SSL_set_fd(ctx->ssl, nc->sock) != 1) return MG_SSL_ERROR;
4533	  }
4534	  res = server_side ? SSL_accept(ctx->ssl) : SSL_connect(ctx->ssl);
4535	  if (res != 1) return mg_ssl_if_ssl_err(nc, res);
4536	  return MG_SSL_OK;
4537	}
4538
0x4010b13d is in mg_ssl_begin (/home/balzer/esp/Open-Vehicle-Monitoring-System-3/vehicle/OVMS.V3/components/mongoose/mongoose/mongoose.c:3765).
3760	}
3761
3762	#if MG_ENABLE_SSL
3763	static void mg_ssl_begin(struct mg_connection *nc) {
3764	  int server_side = (nc->listener != NULL);
3765	  enum mg_ssl_if_result res = mg_ssl_if_handshake(nc);
3766	  DBG(("%p %d res %d", nc, server_side, res));
3767
3768	  if (res == MG_SSL_OK) {
3769	    nc->flags |= MG_F_SSL_HANDSHAKE_DONE;
0x4010ca32 is in mg_mgr_handle_conn (/home/balzer/esp/Open-Vehicle-Monitoring-System-3/vehicle/OVMS.V3/components/mongoose/mongoose/mongoose.c:3820).
3815	       */
3816	      err = nc->err;
3817	#endif
3818	#if MG_ENABLE_SSL
3819	      if ((nc->flags & MG_F_SSL) && err == 0) {
3820	        mg_ssl_begin(nc);
3821	      } else {
3822	        mg_if_connect_cb(nc, err);
3823	      }
3824	#else
0x4010cf86 is in mg_socket_if_poll (/home/balzer/esp/Open-Vehicle-Monitoring-System-3/vehicle/OVMS.V3/components/mongoose/mongoose/mongoose.c:4042).
4037	        fd_flags |= _MG_F_FD_CAN_WRITE;
4038	      }
4039	#endif
4040	    }
4041	    tmp = nc->next;
4042	    mg_mgr_handle_conn(nc, fd_flags, now);
4043	  }
4044
4045	  for (nc = mgr->active_connections; nc != NULL; nc = tmp) {
4046	    tmp = nc->next;
0x401091c2 is in mg_mgr_poll (/home/balzer/esp/Open-Vehicle-Monitoring-System-3/vehicle/OVMS.V3/components/mongoose/mongoose/mongoose.c:2538).
2533	    LOG(LL_ERROR, ("cannot poll: no interfaces"));
2534	    return 0;
2535	  }
2536
2537	  for (i = 0; i < m->num_ifaces; i++) {
2538	    now = m->ifaces[i]->vtable->poll(m->ifaces[i], timeout_ms);
2539	  }
2540	  return now;
2541	}
2542
0x400f3427 is in OvmsNetManager::MongooseTask() (/home/balzer/esp/Open-Vehicle-Monitoring-System-3/vehicle/OVMS.V3/main/ovms_netmanager.cpp:751).
746
747	  // Main event loop
748	  while (m_mongoose_running)
749	    {
750	    // poll interfaces:
751	    if (mg_mgr_poll(&m_mongoose_mgr, 250) == 0)
752	      {
753	      ESP_LOGD(TAG, "MongooseTask: no interfaces available => exit");
754	      break;
755	      }
0x400f34d5 is in MongooseRawTask(void*) (/home/balzer/esp/Open-Vehicle-Monitoring-System-3/vehicle/OVMS.V3/main/ovms_netmanager.cpp:733).
728	#ifdef CONFIG_OVMS_SC_GPL_MONGOOSE
729
730	static void MongooseRawTask(void *pvParameters)
731	  {
732	  OvmsNetManager* me = (OvmsNetManager*)pvParameters;
733	  me->MongooseTask();
734	  }
735
736	void OvmsNetManager::MongooseTask()
737	  {
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20210328/bfa37d94/attachment.sig>
