[Ovmsdev] mongoose-wolfssl
    Craig Leres
    leres at xse.com
    Mon Mar 22 03:55:06 HKT 2021
> Your script creates a CA as well and takes care of optional details.
> That's much more simple if all you need is a cert/key pair for encryption.
I like it because I have many other devices configured to use it and I
have the root ca installed in my my browsers.
>> but when I upload the pem and key files it doesn't like the private key:
>>     Error!
>>     TLS private key must be in PEM PRIVATE KEY format
> You probably copied the wrong section. You need to copy the full PEM
> text including the BEGIN and END lines, as suggested by the placeholder
> for the textarea.
Ah, I see the problem. I searched for the error and it's looking for:
     -----BEGIN PRIVATE KEY-----
but my key says:
     -----BEGIN RSA PRIVATE KEY-----
I've never seen the former. This may describe the differences:
     https://stackoverflow.com/a/20065522
Anyway, I deleted the RSAs and it submitted ok and works! (I can't get a
screen grab of it but) if I click on the firefox lock icon it says,
"Connection Secure, Connection verified by a certificate issuer that is
not recognized by Mozilla." Chrome likes it as well.
I've attached screen grabs that show firefox rendering a page on my dev
module and also the "more information" page.
Should web_cfg.cpp be changed to accept either header?
>> I've never used "subjectAltName=IP:192.168.4.1", is that required?
> Only if you want to be able to access the OVMS AP by https://192.168.4.1/ .
Ah. Yeah, I don't need that. I always want to use the fqdn and only plan
to access it via my home wifi or via vpn.
ssh connect times seem a little worse for me: ~3.5 seconds with
3.2.016-5-g5b03f7fe and 3.2.016-55-g2edf7398.
Thanks to both of you for making this happen, I've wanted https into the
modules for a really long time!
		Craig
Type: image/png
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20210321/fab58df8/attachment-0002.png>
Type: image/png
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20210321/fab58df8/attachment-0003.png>
