[Ovmsdev] mongoose-wolfssl
    Craig Leres
    leres at xse.com
    Mon Mar 22 00:43:45 HKT 2021
On 3/21/21 6:31 AM, Michael Balzer wrote:
> I have now added that as a standard feature and included an info on how
> to create a cert + key in the webserver configuration.
This is awesome!
But I'm having trouble getting it to work. I suspect I don't understand
how certs work with ovms.
A long time ago, with the help of some friends, I wrote a /bin/sh script
to generate self signed certs:
     https://ee.lbl.gov/downloads/create-cert/create-cert.tar.gz
What I am expecting is the cn in the certificate to match the https
hostname, e.g. ovms-dev.alameda.xse.com and I know my browser does not
like it if I navigate to https://ovms-dev.alameda.xse.com/ and the
certificate returned does not match.
I have:
     dot 60 % openssl x509 -text -noout -in
certs/ovms-dev.alameda.xse.com.pem
     Certificate:
         Data:
             Version: 3 (0x2)
             Serial Number: 56 (0x38)
             Signature Algorithm: sha256WithRSAEncryption
             Issuer: C = US, ST = CA, L = Alameda, O = XSE, OU =
Certificate Authorities, CN = XSE Root CA 4, emailAddress = root at xse.com
             Validity
                 Not Before: Mar 21 16:28:03 2021 GMT
                 Not After : Mar  5 16:28:03 2087 GMT
             Subject: CN = ovms-dev.alameda.xse.com, emailAddress =
root at xse.com
             Subject Public Key Info:
                 Public Key Algorithm: rsaEncryption
                     RSA Public-Key: (2048 bit)
but when I upload the pem and key files it doesn't like the private key:
     Error!
     TLS private key must be in PEM PRIVATE KEY format
I've never used "subjectAltName=IP:192.168.4.1", is that required?
FYI I also use the certificates generated with create-cert for client
certificate authentication.
		Craig
