[Ovmsdev] TLS CA question
Fri Mar 12 13:05:34 HKT 2021
IDF should be the same. I use the same one for compiling both master for for-v3.3.
But if you are switching branches, perhaps safest to do a ‘make clean’ between each build.
> On 12 Mar 2021, at 12:47 PM, Craig Leres <leres at xse.com> wrote:
> I just updated to 3.2.016-68-g8e10c6b7 and still get the network hang immediately after booting and logging into the web gui.
> But I see now my problem is likely that I'm not using the right esp-idf (duh). Is there a way I can have master build using ~/esp/esp-idf and have for-v3.3 use a different path?)
> 		Craig
