[Ovmsdev] TLS CA question
Fri Mar 12 12:07:00 HKT 2021
The for-v3.3 branch should be up-to-date and merged from master. It should have everything that master has.
I see it has this:
commit 9607979e91da7a53da1cd0bd8325ab390abe18bb
Author: Stephen Casner <casner at acm.org>
Date: Wed Feb 24 23:53:28 2021 -0800
SSH: Don't emit error message if wolfssl debugging is unconfigured
diff --git a/vehicle/OVMS.V3/components/console_ssh/src/console_ssh.cpp b/vehicle/OVMS.V3/components/console_ssh/src/console_ssh.cpp
index 21549bad..6fa0e5e5 100644
--- a/vehicle/OVMS.V3/components/console_ssh/src/console_ssh.cpp
+++ b/vehicle/OVMS.V3/components/console_ssh/src/console_ssh.cpp
@@ -177,9 +177,8 @@ void OvmsSSH::NetManInit(std::string event, void* data)
ESP_LOGI(tag, "Launching SSH Server");
wolfSSH_SetLoggingCb(&wolfssh_logger);
wolfSSH_Debugging_ON();
- if ((ret=wolfSSL_SetLoggingCb(&wolfssl_logger)) || (ret=wolfSSL_Debugging_ON()))
- ESP_LOGW(tag, "Couldn't initialize wolfSSL debugging, error %d: %s", ret,
- GetErrorString(ret));
+ wolfSSL_SetLoggingCb(&wolfssl_logger);
+ wolfSSL_Debugging_ON();
ret = wolfSSH_Init();
if (ret != WS_SUCCESS)
But current code in both master and for-v3.3 branches is:
Seems commit c6911c91432cada337bef46f6a541af46304b5cf seems to have brought back the old code?
Mark
> On 12 Mar 2021, at 11:34 AM, Stephen Casner <casner at acm.org> wrote:
> Craig and Mark,
> I do have the OvmsSSH::NetManInit() function calling
> wolfSSL_Debugging_ON() which would be expected to return -174 meaning
> NOT_COMPILED_IN as Mark correctly found. At one point I had code to
> print that error messge because I was having trouble getting the
> wolfSSL debugging to work, but I took out that error message in
> commit 9607979e91da7a53da1cd0bd8325ab390abe18bb so now the return
> value is ignored. I'm baffled. I'll have to look deeper after
> dinner.
> My mongoose-wolfssl branch is off of master on 2/17. I should
> probably have rebased to the current master or perhaps merged it to
> for-v3.3 as Mark recently requested. Have you guys done that merge
> for what you are testing now?
> -- Steve
> On Fri, 12 Mar 2021, Mark Webb-Johnson wrote:
>> P.S. Error code -174 seems to be 'NOT_COMPILED_IN’.
>>> On 12 Mar 2021, at 9:56 AM, Mark Webb-Johnson <mark at webb-johnson.net> wrote:
>>> Craig,
>>> I get the same (with for-v3.3):
>>> W (2940) ssh: Couldn't initialize wolfSSL debugging, error -174: Unknown error code
>>> I guess it is just a warning. Probably some debugging config setting.
>>> But wifi, web and others work ok for me. Only problems I have with for-v3.3 branch are (a) the web dashboard modem status, and (b) the TLS certificate verification against api.openvehicles.com <http://api.openvehicles.com/>. I am working on both.
>>>> On 12 Mar 2021, at 9:46 AM, Craig Leres <leres at xse.com <mailto:leres at xse.com>> wrote:
>>>> On 3/10/21 11:23 PM, Stephen Casner wrote:
>>>>> Michael and anyone else who's game:
>>>>> I now have an updated mongoose-wolfssl branch ready to be tested. The
>>>>> reason for the 90-second lockup mentioned in the previous post is a
>>>>> whole lot of math for a prime-number validation that's part of the
>>>>> Diffie-Hellman step. It was actually 87 seconds for Mark's server and
>>>>> 28 seconds for Michael's due to differences in certificates. That
>>>>> prime-number validation is required for FIPS compliance, which WolfSSL
>>>>> supports, but we don't need it. I spent quite a while digging into
>>>>> this to find where the process was getting stuck. Finally I got help
>>>>> from WolfSSL support suggesting a configuration option that avoids
>>>>> this extra check.
>>>>> So now I have an implementation using mongoose with wolfssl that
>>>>> connects successfully to both servers with a 3-4 second delay. (I
>>>>> don't recall what the delay was for the MBEDTLS-based implementation.)
>>>>> I think the memory usage looks OK. I still have not taken any steps
>>>>> to reduce any resources used by the MBEDTLS code as accessed for other
>>>>> purposes.
>>>>> Included in the debugging was another version update on the Wolf code
>>>>> to wolfssh 1.4.6 and wolfssl 4.7.0.
>>>> I tried building/booting this on my dev module( 3.2.016-66-g93e0cf3e); but for some time now the for-v3.3 branch has been broken for me. When the module first boots the web gui works long enough for me to login and then it times out. From that point on I can't get the web gui or ssh to respond. It will return pings. The serial console is fine (and that's how I switch back to build based on master).
>>>> I just did a fresh reboot and captured the serial console output and noticed this:
>>>> W (4484) ssh: Couldn't initialize wolfSSL debugging, error -174: Unknown error code
>>>> I think it happened around the time I lost wifi connectivity.
>>>> My sdkconfig is close to support/sdkconfig.default.hw31, I have CONFIG_SPIRAM_CACHE_WORKAROUND turned off along with a lot of vehicles.
>>>> Craig
>>>> OvmsDev mailing list
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20210312/a3e94016/attachment.htm>
