[Ovmsdev] MCP2515 driver bug?
    Mon Jun  7 23:43:02 HKT 2021
Collin,
totally agreed. The CAN-IP draft you linked has a fragmentation protocol
inspired by ISO-TP, including frame sequence numbering & flow control
with frame timing. And if frames come in at an acceptable rate, the
issue isn't triggered.
I assume the much more simple IP-over-CAN protocol Mark tries to
implement leaves this all to the transport layer (TCP/UDP) and is
optimized for speed on a bus with known participants (i.e. the Tesla
Roadster devices).
I think the RX buffers of the MCP2515 were not meant to form a FIFO
first place, they were meant to be used with separate acceptance
filters. The whole rollover feature looks like some later addition to
the chip design. IMO the spec sheet totally lacks an explanation
regarding the proper handling of this, and the SPI command set lacks a
specific command to read the buffers in sequence of reception or to
retrieve that info.
The other issue for us is the bad interrupt performance of the ESP32 /
esp-idf. The ESP32 CAN controller has a real 64 byte FIFO _and_ is
mapped into the ESP32 address space, but we still sometimes cannot read
the FIFO fast enough to avoid overflows, even with 500 kbit. I still
think some framework components (Wifi / SPI / …) sometimes disable
interrupts for longer periods of time.
Am 07.06.21 um 15:44 schrieb Collin Kidder:
> I totally do not disagree with you. The handling is not very good at
> all - and I might have even written that part... Surely it could be
> handled better. However, nobody has fixed it yet. Perhaps I ought to
> create an issue on GitHub to remind myself that someone has to revisit
> that code at some point.
> One thing I would like to inject into this discussion, though, is that
> counting on proper in-order reception and no dropped frames is not
> generally advisable. CAN is best treated like UDP. Some packets might
> arrive out of order, some not at all. Any multiframe transmission over
> CAN really needs to include some sort of means to identify lost or out
> of order frames. You simply cannot count on CAN traffic to reliably
> get from point A to point B 100% of the time. This is especially true
> once you get onto a real bus where other frames are coming in and the
> bus is loaded up. It's one thing to try this on an empty bus and get
> it to work but that work is not likely to transition over reliably to
> "the real thing." It's best to not even entertain the notion that it
> could be possible. Some form of higher level protocol that keeps track
> of the order and sequence is necessary. Yes, I know technically no
> dropped frames and in order reception are possible if the drivers on
> both sides are properly coded. But, in practice it tends to be quite
> difficult to ensure this 100% of the time. Once again, this is JUST
> like UDP. It can be reliable... most of the time. But, it isn't
> guaranteed to be so and it's best to take proper precautions against
> the problem. This is why things like ISO-TP have sequence bytes. Also,
> see here: https://datatracker.ietf.org/doc/html/draft-cafi-can-ip-00
> On Sun, Jun 6, 2021 at 4:16 PM Michael Balzer <dexter at expeedo.de> wrote:
>> That issue isn't addressed by that driver as well, in fact their
>> handling is much worse than ours, even without rollover enabled. As you
>> can see in their interrupt handler…
>> https://github.com/collin80/esp32_can/blob/master/src/mcp2515.cpp#L892
>> …they read the interrupt flags, then check & read both buffers
based on
>> the flags read, then clear all (!) interrupt flags.
>> So if an interrupt occurs for buffer 0, and the next frame comes in for
>> buffer 1 right after the driver read the interrupts, their driver will
>> only read buffer 0 and then clear all interrupts, thus losing that for
>> buffer 1.
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20210607/d22d1a26/attachment.sig>
