[Ovmsdev] MCP2515 driver bug?
    Fri Jun  4 14:29:38 HKT 2021
Mark,
the handler is meant to read both buffers sequentially, and on a quick
glance I don't see why it wouldn't. But it can't hurt if you do an audit
of the code.
I remember having had that out-of-order discussion when handling both RX
buffers before here, but don't remember the outcome. Too bad the list
archives cannot be searched.
I think it was the MCP not doing overflows from RX buffer 1 to 0. I.e.
if buffer 1 still has a frame on arrival, the new frame will be lost.
That means losing a frame if the handler cannot react fast enough, but
receiving out of order would be worse.
Am 04.06.21 um 04:16 schrieb Mark Webb-Johnson:
> Michael,
> Good suggestion on the timing. I think it best to use the same timings
> as the Arduino library, and have committed that change. No vehicle
> modules currently use 1Mbps on MCP2515 anyway. Unfortunately, it
> didn’t resolve my problem.
> Looking at the error flags I see:
>     Error flag:  0x23401c01
>     intstat 0x23
>           ERRIF Error Interrupt pending
>           RX0IF Rx buffer 0 full interrupt
>           RX1IF Rx buffer 1 full interrupt
>     errflag 0x40
>           RX0OVR Rx buffer 0 overflow
>     intflag 0x1c01
>           0x01 Implied from Rx buffer 0 full
>           0x1c = 0001 1100
>           Means RXB0 overflow. No data lost in this case
(it went into
>     RXB1)
>           Means (errflag & EFLG_RX01OVR), clear RX buffer overflow flags
>           Means (intstat & (CANINTF_MERRF | CANINTF_WAKIF |
>     CANINTF_ERRIF)), clear error & wakeup interrupts
> So we have CAN frames in BOTH rx buffers #0 and #1. Looking at our
> driver code (mcp2515::AsynchronousInterruptHandler), it seems in that
> case we only read from buffer #0. From the flow I can see, we are
> going to lose that second frame. We’re not really handling the issue
> of two frames being in the buffers when the interrupt handler is called.
> As the architecture of mcp2515::AsynchronousInterruptHandler can only
> receive one frame, it is not so simple to fix. We could simply read
> and return the frame in buffer #0, requesting to be called again
> (return true), but another frame may arrive (into buffer #0) before we
> get called again, and that is going to result in out-of-order frames.
> I’ll work on improving the handling of this case.
>> On 3 Jun 2021, at 3:07 PM, Michael Balzer <dexter at expeedo.de
>> Signed PGP part
>> Mark,
>> I'd give the bit timing a try first, the MCP2515 seems to be very
>> sensitive for this. I've even had some trouble finding a working
>> configuration for the 50 kbit timing I've added a couple weeks ago.
>> We currently use 00 / D0 / 82 which is also the result of the old
>> Intrepid timing calculator. That's a propagation segment of 1 Tq and
>> 3 Tq per phase, resulting in samling between 50% - 62.5%.
>> The Arduino MCP CAN lib by Cory Fowler also had this previously, but
>> then changed in…
>> https://github.com/coryjfowler/MCP_CAN_lib/commit/ece730cf697fef1cbe8a90111694868168d41000
>> …to 00 / CA / 81, which is a propagation segment of 3 Tq and 2
Tq per
>> phase, shifting the sampling window to 62.5 - 75%.
>> Our current configuration scheme for the internal SJA1000 compatible
>> CAN seems to sample at 62.5 - 75% as well, so that would also match.
>> Am 03.06.21 um 07:36 schrieb Mark Webb-Johnson:
>>> I’m working on an implementation of IP stack over CAN for the
Tesla
>>> Roadster. IP frames are encoded as a length followed by a sequence
>>> of CAN frames, all on the same ID. This runs over a 1MHz bus, so
>>> presumably the traffic volume could be high at times.
>>> I was having problems with this running on CAN2, so tried CAN1 and
>>> it worked perfectly. Here are some simple dumps of a single PING
>>> packet (and single PING response packet):
>>> ID #111 is used to transmit an IP packet, and ID #110 is used to
>>> receive an IP packet. The special empty data frame is an acknowledgment.
>>> Using latest master branch code (3.2.016-196-g0aad1a9f/ota_1/edge
>>> (build idf v3.3.4-848-g1ff5e24b1 Jun  2 2021 09:28:58)).
>>> So, first let’s test with traffic on CAN1 (active, 1Mbps), and
>>> listening on CAN2 (listen, 1Mbps):
>>>         TCPDUMP:
>>>             05:57:55.980291 IP (tos 0x0, ttl 64, id 43101, offset 0,
>>>             flags [DF], proto ICMP (1), length 84)
>>>               10.10.99.3 > 10.10.99.2: ICMP echo request, id 23372,
>>>             seq 1, length 64
>>>             0x0000:  4500 0054 a85d 4000 4001 b832 0a0a 6303
>>>             E..T.]@. at ..2..c.
>>>             0x0010:  0a0a 6302 0800 7df8 5b4c 0001 5361 b860
>>>              ..c...}.[L..Sa.`
>>>             0x0020:  19f5 0e00 0809 0a0b 0c0d 0e0f 1011 1213
>>>             0x0030:  1415 1617 1819 1a1b 1c1d 1e1f 2021 2223
>>>             0x0040:  2425 2627 2829 2a2b 2c2d 2e2f 3031 3233
>>>              $%&'()*+,-./0123
>>>             0x0050:  3435 3637    4567
>>>             05:57:56.436190 IP (tos 0x0, ttl 64, id 14937, offset 0,
>>>             flags [none], proto ICMP (1), length 84)
>>>               10.10.99.2 > 10.10.99.3: ICMP echo reply, id 23372,
>>>             seq 1, length 64
>>>             0x0000:  4500 0054 3a59 0000 4001 6637 0a0a 6302
>>>             E..T:Y.. at .f7..c.
>>>             0x0010:  0a0a 6303 0000 85f8 5b4c 0001 5361 b860
>>>              ..c.....[L..Sa.`
>>>              $%&'()*+,-./0123
>>>         Traffic (as shown on PC the other end of the can log tcp
>>>         connection):
>>>             tx: #111 54 00
>>>             tx: #111 45 00 00 54 a8 5d 40 00
>>>             tx: #111 40 01 b8 32 0a 0a 63 03
>>>             tx: #111 0a 0a 63 02 08 00 7d f8
>>>             tx: #111 5b 4c 00 01 53 61 b8 60
>>>             tx: #111 19 f5 0e 00 08 09 0a 0b
>>>             tx: #111 0c 0d 0e 0f 10 11 12 13
>>>             tx: #111 14 15 16 17 18 19 1a 1b
>>>             tx: #111 1c 1d 1e 1f 20 21 22 23
>>>             tx: #111 24 25 26 27 28 29 2a 2b
>>>             tx: #111 2c 2d 2e 2f 30 31 32 33
>>>             tx: #111 34 35 36 37
>>>             rx: #110
>>>             rx: #110 54 00
>>>             rx: #110 45 00 00 54 3a 59 00 00
>>>             rx: #110 40 01 66 37 0a 0a 63 02
>>>             rx: #110 0a 0a 63 03 00 00 85 f8
>>>             rx: #110 5b 4c 00 01 53 61 b8 60
>>>             rx: #110 19 f5 0e 00 08 09 0a 0b
>>>             rx: #110 0c 0d 0e 0f 10 11 12 13
>>>             rx: #110 14 15 16 17 18 19 1a 1b
>>>             rx: #110 1c 1d 1e 1f 20 21 22 23
>>>             rx: #110 24 25 26 27 28 29 2a 2b
>>>             rx: #110 2c 2d 2e 2f 30 31 32 33
>>>             rx: #110 34 35 36 37
>>>         CAN1 active:
>>>             1T11 111 54 00
>>>             1R11 110
>>>             1CER TX_Queue T11 111 40 01 b8 32 0a 0a 63 03
>>>             1T11 111 45 00 00 54 a8 5d 40 00
>>>             1T11 111 40 01 b8 32 0a 0a 63 03
>>>             1CER TX_Queue T11 111 5b 4c 00 01 53 61 b8 60
>>>             1T11 111 0a 0a 63 02 08 00 7d f8
>>>             1T11 111 5b 4c 00 01 53 61 b8 60
>>>             1CER TX_Queue T11 111 0c 0d 0e 0f 10 11 12 13
>>>             1T11 111 19 f5 0e 00 08 09 0a 0b
>>>             1T11 111 0c 0d 0e 0f 10 11 12 13
>>>             1CER TX_Queue T11 111 1c 1d 1e 1f 20 21 22 23
>>>             1T11 111 14 15 16 17 18 19 1a 1b
>>>             1T11 111 1c 1d 1e 1f 20 21 22 23
>>>             1CER TX_Queue T11 111 2c 2d 2e 2f 30 31 32 33
>>>             1T11 111 24 25 26 27 28 29 2a 2b
>>>             1T11 111 2c 2d 2e 2f 30 31 32 33
>>>             1T11 111 34 35 36 37
>>>             1R11 110 54 00
>>>             1R11 110 45 00 00 54 3a 59 00 00
>>>             1R11 110 40 01 66 37 0a 0a 63 02
>>>             1R11 110 0a 0a 63 03 00 00 85 f8
>>>             1R11 110 5b 4c 00 01 53 61 b8 60
>>>             1R11 110 19 f5 0e 00 08 09 0a 0b
>>>             1R11 110 0c 0d 0e 0f 10 11 12 13
>>>             1R11 110 14 15 16 17 18 19 1a 1b
>>>             1R11 110 1c 1d 1e 1f 20 21 22 23
>>>             1R11 110 24 25 26 27 28 29 2a 2b
>>>             1R11 110 2c 2d 2e 2f 30 31 32 33
>>>             1R11 110 34 35 36 37
>>>         CAN2 listen:
>>>             2R11 111 54 00
>>>             2R11 110
>>>             2R11 111 45 00 00 54 a8 5d 40 00
>>>             2R11 111 40 01 b8 32 0a 0a 63 03
>>>             2R11 111 0a 0a 63 02 08 00 7d f8
>>>             2R11 111 5b 4c 00 01 53 61 b8 60
>>>             2R11 111 19 f5 0e 00 08 09 0a 0b
>>>             2R11 111 0c 0d 0e 0f 10 11 12 13
>>>             2R11 111 14 15 16 17 18 19 1a 1b
>>>             2R11 111 1c 1d 1e 1f 20 21 22 23
>>>             2R11 111 24 25 26 27 28 29 2a 2b
>>>             2R11 111 2c 2d 2e 2f 30 31 32 33
>>>             2R11 111 34 35 36 37
>>>             2R11 110 54 00
>>>             2CER Error intr=10 rxpkt=14 txpkt=0 errflags=0x23401c01
>>>             rxerr=0 txerr=0 rxinval=0 rxovr=0 txovr=0 txdelay=0
>>>             txfail=0 wdgreset=0 errreset=0
>>>             2R11 110 40 01 66 37 0a 0a 63 02
>>>             2R11 110 19 f5 0e 00 08 09 0a 0b
>>>             2R11 110 34 35 36 37
>>>             2R11 110 45 00 00 54 3a 59 00 00
>>> Conclusion is that the CAN1 traffic looks fine, and the PING packet
>>> gets a good reply. All successful. But the CAN2 listen is missing a
>>> few packets and the last packet is out of order.
>>> Now, let’s test with traffic on CAN2 (active, 1Mbps), and listening
>>> on CAN1 (listen, 1Mbps):
>>>     TCPDUMP:
>>>         06:00:33.004060 IP (tos 0x0, ttl 64, id 58240, offset 0,
>>>             10.10.99.3 > 10.10.99.2: ICMP echo request, id 23393,
>>>         seq 1, length 64
>>>         0x0000:  4500 0054 e380 4000 4001 7d0f 0a0a 6303
>>>         E..T.. at .@.}...c.
>>>         0x0010:  0a0a 6302 0800 7cc8 5b61 0001 f161 b860
>>>          ..c...|.[a...a.`
>>>         0x0020:  8b0f 0000 0809 0a0b 0c0d 0e0f 1011 1213
>>>          $%&'()*+,-./0123
>>>     connection):
>>>             tx: #111 54 00
>>>             tx: #111 45 00 00 54 e3 80 40 00
>>>             tx: #111 40 01 7d 0f 0a 0a 63 03
>>>             tx: #111 0a 0a 63 02 08 00 7c c8
>>>             tx: #111 5b 61 00 01 f1 61 b8 60
>>>             tx: #111 8b 0f 00 00 08 09 0a 0b
>>>             rx: #110
>>>             rx: #110 54 00
>>>             rx: #110 45 00 00 54 3a 5a 00 00
>>>             rx: #110 0a 0a 63 03 00 00 84 c8
>>>             rx: #110 8b 0f 00 00 08 09 0a 0b
>>>             rx: #110 40 01 66 36 0a 0a 63 02
>>>     CAN2 active:
>>>         2T11 111 54 00
>>>         2R11 110
>>>         2CER TX_Queue T11 111 40 01 7d 0f 0a 0a 63 03
>>>         2T11 111 45 00 00 54 e3 80 40 00
>>>         2T11 111 40 01 7d 0f 0a 0a 63 03
>>>         2CER TX_Queue T11 111 5b 61 00 01 f1 61 b8 60
>>>         2T11 111 0a 0a 63 02 08 00 7c c8
>>>         2T11 111 5b 61 00 01 f1 61 b8 60
>>>         2CER TX_Queue T11 111 0c 0d 0e 0f 10 11 12 13
>>>         2T11 111 8b 0f 00 00 08 09 0a 0b
>>>         2T11 111 0c 0d 0e 0f 10 11 12 13
>>>         2CER TX_Queue T11 111 1c 1d 1e 1f 20 21 22 23
>>>         2T11 111 14 15 16 17 18 19 1a 1b
>>>         2T11 111 1c 1d 1e 1f 20 21 22 23
>>>         2CER TX_Queue T11 111 2c 2d 2e 2f 30 31 32 33
>>>         2T11 111 24 25 26 27 28 29 2a 2b
>>>         2T11 111 2c 2d 2e 2f 30 31 32 33
>>>         2T11 111 34 35 36 37
>>>         2R11 110 54 00
>>>         2R11 110 45 00 00 54 3a 5a 00 00
>>>         2CER Error intr=15 rxpkt=3 txpkt=12 errflags=0x23401c01
>>>         rxerr=0 txerr=0 rxinval=0 rxovr=0 txovr=0 txdelay=5 txfail=0
>>>         2R11 110 0a 0a 63 03 00 00 84 c8
>>>         2R11 110 8b 0f 00 00 08 09 0a 0b
>>>         2R11 110 40 01 66 36 0a 0a 63 02
>>>     CAN1 listen:
>>>         1R11 111 54 00
>>>         1R11 110
>>>         1R11 111 45 00 00 54 e3 80 40 00
>>>         1R11 111 40 01 7d 0f 0a 0a 63 03
>>>         1R11 111 0a 0a 63 02 08 00 7c c8
>>>         1R11 111 5b 61 00 01 f1 61 b8 60
>>>         1R11 111 8b 0f 00 00 08 09 0a 0b
>>>         1R11 111 0c 0d 0e 0f 10 11 12 13
>>>         1R11 111 14 15 16 17 18 19 1a 1b
>>>         1R11 111 1c 1d 1e 1f 20 21 22 23
>>>         1R11 111 24 25 26 27 28 29 2a 2b
>>>         1R11 111 2c 2d 2e 2f 30 31 32 33
>>>         1R11 111 34 35 36 37
>>>         1R11 110 54 00
>>>         1R11 110 45 00 00 54 3a 5a 00 00
>>>         1R11 110 40 01 66 36 0a 0a 63 02
>>>         1R11 110 0a 0a 63 03 00 00 84 c8
>>>         1R11 110 5b 61 00 01 f1 61 b8 60
>>>         1R11 110 8b 0f 00 00 08 09 0a 0b
>>> Conclusion is that the CAN2 transmit traffic looks fine, but no PING
>>> reply received via CAN. The CAN1 listen shows the reply just fine.
>>> Here is that last CAN1 listen, with timestamps:
>>>     1622696433.080107 1R11 111 54 00
>>>     1622696433.081657 1R11 110
>>>     1622696433.227479 1R11 111 45 00 00 54 e3 80 40 00
>>>     1622696433.228318 1R11 111 40 01 7d 0f 0a 0a 63 03
>>>     1622696433.245727 1R11 111 0a 0a 63 02 08 00 7c c8
>>>     1622696433.246214 1R11 111 5b 61 00 01 f1 61 b8 60
>>>     1622696433.248219 1R11 111 8b 0f 00 00 08 09 0a 0b
>>>     1622696433.248772 1R11 111 0c 0d 0e 0f 10 11 12 13
>>>     1622696433.250774 1R11 111 14 15 16 17 18 19 1a 1b
>>>     1622696433.251338 1R11 111 1c 1d 1e 1f 20 21 22 23
>>>     1622696433.253380 1R11 111 24 25 26 27 28 29 2a 2b
>>>     1622696433.253944 1R11 111 2c 2d 2e 2f 30 31 32 33
>>>     1622696433.265937 1R11 111 34 35 36 37
>>>     1622696433.269221 1R11 110 54 00
>>>     1622696433.272095 1R11 110 45 00 00 54 3a 5a 00 00
>>>     1622696433.272125 1R11 110 40 01 66 36 0a 0a 63 02
>>>     1622696433.272156 1R11 110 0a 0a 63 03 00 00 84 c8
>>>     1622696433.272193 1R11 110 5b 61 00 01 f1 61 b8 60
>>>     1622696433.272245 1R11 110 8b 0f 00 00 08 09 0a 0b
>>>     1622696433.272277 1R11 110 0c 0d 0e 0f 10 11 12 13
>>>     1622696433.272314 1R11 110 14 15 16 17 18 19 1a 1b
>>>     1622696433.272354 1R11 110 1c 1d 1e 1f 20 21 22 23
>>>     1622696433.272387 1R11 110 24 25 26 27 28 29 2a 2b
>>>     1622696433.272420 1R11 110 2c 2d 2e 2f 30 31 32 33
>>>     1622696433.272452 1R11 110 34 35 36 37
>>> It is 1Mbps, with 30us or so between each packet. This is the *only*
>>> traffic on the bus. Everything else is turned off. Roughly 12
>>> packets each way. Surely even if we were hitting a performance
>>> limit, our buffers can handle 12 packets?
>>> The good news is that I have a good environment to replicate this
>>> issue now, so any fix should be easy to test.
>>> I haven’t worked on the MCP2515 driver in our code in a long time,
>>> but it certainly seems something is messed up and that could be
>>> badly affecting vehicle modules using anything other than CAN1.
>>> I will start to look at this over the weekend, but has anyone got
>>> any ideas/suggestions? Perhaps the bit timing registers are off by a
>>> small amount (so it works on CAN1 but not on CAN2)? Or something
>>> more serious in our driver?
>> <MCP2515Calc-1000kbit.ods>
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20210604/d7e21808/attachment-0001.htm>
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20210604/d7e21808/attachment-0001.sig>
