[Ovmsdev] Tesla Powered RAV4 EV support
    Sun Jul  4 02:06:55 HKT 2021
Michael,
Am 03.07.21 um 06:48 schrieb Michael Iimura:
> L:/OVMS/home/miimura/Open-Vehicle-Monitoring-System-3/vehicle/OVMS.V3/components/vehicle_toyotarav4ev/src/vehicle_toyotarav4ev.cpp:100:50:
> error: invalid use of member
> 'OvmsVehicleToyotaRav4Ev::m_v_bat_cool_in_temp' in static member function
>    c.printf("<p>Battery Coolant Inlet: %.1f C</p>",
> m_v_bat_cool_in_temp->AsFloat());
> In file included from
> L:/OVMS/home/miimura/Open-Vehicle-Monitoring-System-3/vehicle/OVMS.V3/components/vehicle_toyotarav4ev/src/vehicle_toyotarav4ev.cpp:38:0:
> L:/OVMS/home/miimura/Open-Vehicle-Monitoring-System-3/vehicle/OVMS.V3/components/vehicle_toyotarav4ev/src/vehicle_toyotarav4ev.h:90:22:
> note: declared here
>      OvmsMetricFloat *m_v_bat_cool_in_temp;
> Anybody have a clue what I'm doing wrong here?
as Steve already explained, if you want to access a member variable, you
need to get the object (vehicle) pointer. You could do so by calling
MyVehicleFactory.ActiveVehicle().
But do you really want a static metric value in a web page? Why not use
a standard metric display so you can see the dynamic value changes?
To do so, you simply need to add class "receiver" to e.g. your main
panel div, then do:
   c.printf("<p>Battery Coolant Inlet: <span class=\"metric\"
data-metric=\"xr4.v.b.t.cltin\">?</span> C</p>");
Or, using the metric number widget to get some default layout & style:
       <div  class="receiver">
         <div  class="metric number"  data-metric="xr4.v.b.t.cltin"  data-prec="1">
           <span  class="label">Battery Coolant Inlet:</span>
           <span  class="value">?</span>
           <span  class="unit">°C</span>
         </div>
       </div>
See
https://docs.openvehicles.com/en/latest/components/ovms_webserver/docs/metrics.html
for the full reference.
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20210703/fc59eda8/attachment-0001.htm>
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20210703/fc59eda8/attachment-0001.sig>
