[Ovmsdev] Implementing advanced charge control
Fri Jan 29 14:52:14 HKT 2021
On Thu, 28 Jan 2021, Michael Balzer wrote:
> just a note on the ACC capabilities: the system should also support SOC and
> 12V level guards, i.e. start the charge when the SOC or 12V level drops below
> a configured threshold while parked at a charging location.
This is an interesting concept we haven't talked about before.  There
could be booleans in the profile to enable those two guard conditions.
I think these should also depend upon a time element, say that the the
car has been connected to the charger for several hours in addition to
the SOC or 12V level trigger being hit.  That is because I might come
home and plug in with a low state of change but not want charging to
start yet because I want to to finish at a specfied time.
> In addition to that, it should be possible to set custom commands/scripts for
> starting and stopping the charge process depending on the location, to support
> controlling smart plugs or home automation systems.
The profile could have members to hold the names of scripts for charge
start and charge stop if set.
