[Ovmsdev] Update WolfSSH/SSL
Stephen Casner
casner at acm.org
Thu Jan 28 10:03:42 HKT 2021
On Sun, 24 Jan 2021, Michael Balzer wrote:
> The higher base memory footprint due to the higher NetMan stack size + some
> additional buffer it seems (some 512 bytes?) means this needs to be checked
> with complex vehicle modules in live operation before merging, but I think
> that won't be an issue.
As suggested to me by WolfSSL support, there is a configuration
parameter for wolfssl to use heap allocation rather than stack for
some buffers and structures. With that change, I can restore the
NetMan stack to 8K. Now the comparison of memory usage is as follows:
- With the current master code the max NetMan stack depth on my OVMS
was 5616 whereas after the update it is 5760.
- With the current master code, the amount of memory added by NetMan
when an ssh connection was established was 2557 D/IRAM and 6108
SPIRAM for 8665 total. With the update it was 1056 D/IRAM and
7532 SPIRAM for 8588 total.
I think this change should clear the way for merging into master.
