[Ovmsdev] Proposed new config option
Wed Jan 27 08:58:29 HKT 2021
This seems fine to me. The
Component config > Open Vehicle Monitoring System (OVMS) > Developer Options
Is the correct place to put it.
> On 25 Jan 2021, at 8:53 AM, Stephen Casner <casner at acm.org> wrote:
> When I'm working with my bench OVMS unit attached with USB and
> frequently rebooting, I don't want to have to log in each time.
> To avoid this I have patched console_async.cpp to SetSecure(true) in
> the constructor. But I have to be careful to omit that patched file
> when committing my changes. I proposed to add a Kconfig developer
> option to control whether that SetSecure(true) statement is included.
> Then I can commit this functionality into the code base where it will
> normally be excluded but can be included for a developer build
> configuration. This is similar to OVMS_DEV_CONFIGVFS option that
> allows read access to the ovms_config file.
> My proposed change is attached. Any objections?
> -- Steve<secureasync.diff>_______________________________________________
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20210127/6c89d6a5/attachment.htm>
