[Ovmsdev] Scan and discover process for 29bits PID
Tue Jan 26 02:51:10 HKT 2021
Didier,
support for CAN extended frame mode hasn't yet been implemented on the
RE scanner or the OBD poller.
As I wrote before, that's totally rare in vehicles, there wasn't any
need to support this up to now.
If you need it, you're welcome to implement it. But I doubt you need it.
You can possibly check by sending some strategic CAN extended frames
manually, see command "can can1 tx extended".
Am 25.01.21 um 19:38 schrieb didier at ernotte.com:
> Hi,
> Thanks to all the help you provide me here, I was able to identify
> most of the 11bits ECU with broadcast request and SavvyCAN, and
> relative PID with the PID scanner.
> I am a bit confused how I can scan ECU/PID with the extended mode (29
> bits). How can I do the same kind of investigation and scanning with
> the extended mode ?
> Didier
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20210125/8e05a13e/attachment.htm>
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20210125/8e05a13e/attachment.sig>
