[Ovmsdev] indirect TPMS in app
Sun Jan 24 00:26:51 HKT 2021
sharkcow,
my proposal followed your request:
Am 08.01.21 um 15:12 schrieb sharkcow:
> Since the values are relative, I would like to transmit them to the app
> as raw data and only display a percentage (100% means everything is ok).
I don't know what "diffusion" means in regards to tyres, and I assume no
user will know that. So it would be a useless and/or confusing display
in the App. I suggest deriving a health percentage from that, as you
initially wrote.
And "emergency" seems to be mappable to the "alert" metric?
Am 23.01.21 um 17:13 schrieb sharkcow:
> Michael,
> this looks great, thanks!
> However, at least for the e-Up we get two values per wheel (diffusion
> and tyre emergency). I personally would like to display both in the app.
> From what I understand, I can't easily extend the current metric layout
> for that, right?
> If this approach is completely unacceptable, I could also try to merge
> the two values per wheel into one "health" indicator.
> sharkcow
> Am 17.01.21 um 18:51 schrieb Michael Balzer:
>> Everyone,
>> this is now fully implemented and committed.
>> Please note I did a slight change regarding the wheel layout and "Y"
>> message structure, to better support custom layouts.
>> * The TPMS wheel layout now is defined by
>> OvmsVehicle::GetTpmsLayout(), which can be overridden by a vehicle
>> to implement custom layouts. The default is the proposed
>> FL,FR,RL,RR.
>> * The wheel layout is included in the "Y" message as the first part,
>> and the number of values is included for each vector.
>> See updated MP documentation here:
>> https://docs.openvehicles.com/en/latest/protocol_v2/messages.html#car-tpms-message-0x59-y
>> Example messages from the DEMO vehicle:
>> Y4,FL,FR,RL,RR,4,206.8,216.5,275.8,175.8,0,4,33.0,33.0,34.0,38.0,0,4,95.0,93.0,96.0,74.0,0,4,0,0,0,1,0
>> W31.3982,33,25.4962,38,30,33,40,34,1
>> I'll take care of supporting "Y" in the Android App.
>> I've also added an automatic TPMS alert triggered by changes to the
>> v.t.alert vector. Example alert text:
>> TPMS ALERT:
>> FR wheel ALERT: Health=91% Pressure=9.1kPa Temp=21C
>> RR wheel WARNING: Health=90% Pressure=9kPa Temp=9C
>> No alerts will be set automatically, you need to add setting some proper
>> alert level if you'd like to use this new feature.
>> Am 10.01.21 um 22:40 schrieb Michael Balzer:
>>> I read something about this being typical for all (or many?) VW
>>> vehicles, apparently they don't have dedicated TPMS sensors but derive
>>> the tyre "health" from the ESP sensors.
>>> If that's correct, there is no way we will ever be able to map the
>>> values to actual temperatures & pressures.
>>> So… how about adding new relative TPMS metrics & warning/alert
>>> indicators to be used alternatively to the current absolute
>>> temperatures & pressures?
>>> We could add these now as vectors, and replace the previous single
>>> metrics for temperatures & pressures by vectors as well. That would
>>> reduce the metric payload size on both MQTT and the WebSocket
>>> transport, and also adapt nicely to vehicles with more or less than
>>> four wheels.
>>> Proposal: numbering scheme rows front to back, left to right per row.
>>> For four wheels:
>>> v.t.pressure fl,fr,rl,rr [kPa]
>>> v.t.temp fl,fr,rl,rr [°C]
>>> v.t.health fl,fr,rl,rr [%]
>>> v.t.alert fl,fr,rl,rr [0/1/2]
>>> The alert vector can use the same scheme as with the battery cells,
>>> i.e. 0 = OK, 1 = warning, 2 = alert.
>>> The MP message "W" can be replaced by a new one. Proposal: Code "Y",
>>> data:
>>> * number of wheels
>>> * pressure values + staleness
>>> * temp values + staleness
>>> * health values + staleness
>>> * alert values + staleness
>>> We can continue producing "W" messages for old clients in the field.
>>> Anything missing?
>>> If that's OK for all, I can make the necessary changes.
>>> Am 09.01.21 um 19:35 schrieb sharkcow:
>>>> Thanks for your input, Michael.
>>>> I agree that we could use the relative metrics to roughly estimate the
>>>> current assumed pressure from a reference value (which would have
>>>> to be
>>>> updated every time a user presses the TPMS reset button...).
>>>> But: I'm afraid the correlation is not linear, probably not even
>>>> reproducible. Also, we have two pressure-related values per wheel,
>>>> while
>>>> OVMS for now has a pressure and a temperature value.
>>>> So... I think I'd still prefer two relative indicators for the e-up in
>>>> the app. I can try to work on implementing a custom MP record.
>>>> sharkcow
>>>> Am 08.01.21 um 18:33 schrieb Michael Balzer:
>>>>> Sharkcow,
>>>>> as we don't have a new capabilities message scheme yet, conditional
>>>>> blocks are the way it works right now in the App.
>>>>> The meanings of standard metrics and message data fields should
>>>>> not be
>>>>> changed. Introducing custom metrics and a custom MP record is a
>>>>> possible
>>>>> solution.
>>>>> But having custom solutions for common things like this is a PITA.
>>>>> Maybe
>>>>> we can work something out to convert the readings into the standard
>>>>> metrics?
>>>>> For example: if you get a "health percentage", we could introduce a
>>>>> configuration for the "100%" health pressure level, so we can get an
>>>>> absolute value from that.
>>>>> Regards,
>>>>> Michael
>>>>>> I have now figured out how to read and partly how to interpret the
>>>>>> metrics of the indirect TPMS on the e-up.
>>>>>> We get a "tyre emergency" and a "pressure diffusion" value for each
>>>>>> wheel.
>>>>>> app
>>>>>> ok).
>>>>>> Would it be ok to just introduce an if-statement in the app to
>>>>>> detect
>>>>>> whether the vehicle type is an e-up and change the default displays
>>>>>> accordingly?
>>>>>> sharkcow
>>>>>> PS: I feel this value (incl. a useful alert value) would be very
>>>>>> beneficial: I just found out that I had lost quite some pressure
>>>>>> over
>>>>>> the 2 years I own the vehicle without TPMS reacting. The metrics on
>>>>>> OBD
>>>>>> showed a nicely measureable change however, which could easily be
>>>>>> used
>>>>>> to have OVMS notify me. (Yes, I should have checked the pressure
>>>>>> regularly, but hey: what's a TPMS for?!)
>>>>>> OvmsDev mailing list
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20210123/80671075/attachment.sig>
